Old 07-09-2013, 07:03 AM
AngelE66 AngelE66 is offline
Mein Auto: E66 Alpine White
Automatic Trunk not going down
When I press the button for the trunk to go down, It just sits idle and I hear the motor going but it does not drop/close.
What could be the problem and how much is the repair cost?
Old 07-09-2013, 07:47 AM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
Something may be binding. Try some WD-40. Do a search...several hav had trunk issues:
http://www.bimmerfest.com/forums/arc.../t-600271.html
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 07-09-2013, 11:49 AM
pass427's Avatar
pass427 pass427 is offline
Mein Auto: 750
Same thing happen to me a few weeks back and the dealer had to replace # 3 and 5 in the diagram below and the bleed the system.
http://realoem.com/bmw/showparts.do?...37&hg=41&fg=60
Old 07-09-2013, 12:13 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Don't use WD-40. Use a lithium grease or at least a silicone based grease. Silicone tends to make squeaking noises though.
WD-40 will eventually dry thing out.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 07-09-2013, 01:54 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Re: Automatic Trunk not going down
X1
Old 07-10-2013, 08:27 AM
+2....I don't even know why I said that. I do use wd-40 for all kinds of stuff but yeah...there are much better options.
