Old 05-10-2011, 03:04 PM
dbflight dbflight is offline
Mein Auto: E85 Z4, E83 X3
Chipped paint on steering wheel - 07
My 2007 X3 has chipped paint on the trim around the buttons on the steering wheel. I have found replacement trim for the M wheel but not this one. Is it available?
If not, has anyone removed this trim to sand/paint it?
The dealer wants $400 for it, which is insane.
Old 05-10-2011, 08:31 PM
spokelizard spokelizard is offline
Mein Auto: 2007 X3 MT
I can't really tell from your picture exactly where it's chipped. I have an '07 and had peeling on the standard wheel. I just recently had the trim pieces around the buttons replaced by the dealer. It was done under the original warranty so no charge. If you're beyond warranty, I would think that still should be an item you can order.
Old 05-10-2011, 09:52 PM
Calixx3 Calixx3 is offline
Mein Auto: X3 & 328I
here you go... area in red
Old 05-10-2011, 09:56 PM
Ishniknork's Avatar
Ishniknork Ishniknork is offline
I hate doing dishes
Mein Auto: '05 X3 3.0i
I think these are what you're looking for, numbers 3 and 4:
http://www.realoem.com/bmw/showparts...57&hg=32&fg=35
'05 X3 3.0i Alpine White/Gray Leather/Alum. Trim
Sport/Steptronic/Servotronic/Panoramic
Premium Sound/Staggered Style 114 18"ers
Old 05-11-2011, 12:30 AM
Yes, that's what they replaced, thanks for looking it up.
I can see the chipping now. The part Ishniknork located should work fine, why don't you price out the part alone. I can't believe it's $400 parts and labor, even if you need an indie mechanic to install the part for you.
The stock part on my 2007 was kind of plasticized and the surface was peeling. Might be the same as what you're calling "chipping". The replacement part has a matte finish but doesn't have the plasticized surface, so it won't happen again. It's a little cheaper looking, but should be way more durable.
Old 05-11-2011, 08:15 AM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
Should be a warranty item
if warranty is still in effect that is
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 05-11-2011, 08:25 AM
madurodave's Avatar
BMW Enthusiast!
I had mine replaced 1.5 years ago under warranty. Common problem, unfortunately.
If you still have factory warranty, it is covered.
CPO may cover it for $50 if you have it.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 05-11-2011, 08:55 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Not something I would replace/repair for $400. Things wear out and become "used" over time. I have a "peeling" on the latch to the dash storage box (where the Nav goes -- if installed) but have no interest in paying anything to fix it.
Old 05-11-2011, 11:23 AM
The car is only 3000mi past the warranty so it was clearly a problem while covered, but the dealer is not helpful. CPO didn't help either.
Bought the parts online for $160. I hope I can install it by just popping them off and on.
Old 05-11-2011, 12:29 PM
madurodave's Avatar
BMW Enthusiast!
So you reported it before your warranty was up? It is covered by the factory warranty for sure. I had 2 pieces replaced due to chipping.
The flat coating did not adhere well. No more issues so far, but if it happens again I will live with it.
Madurodave
Member of BMWCCA!
Old 05-11-2011, 12:40 PM
Johancab Johancab is offline
Mein Auto: 330 Cab
I painted mine a week ago, too soon to say but fine for now. I did not sand it, just cleaned it with alchol which removed some of the paint to flaten the scratches.
Old 07-09-2013, 03:06 PM
Mein Auto: 330 Cab
More than two years later and it still look like the day I painted it, perfect an beautiful!
Old 07-09-2013, 03:31 PM
usaret usaret is offline
Mein Auto: A Gamma Goat
Thanks for the update.
Mine has started to peel too and I've been thinking about what to do about it.
Old 07-09-2013, 05:21 PM
x3brian x3brian is offline
Mein Auto: X3
Mine are starting to peel again too. First set was replaced around 50k under warranty. It's nice to hear his paint is holding up as I am not sure it's worth it buying a new piece. Part numbers below and if realoem prices are close...ouch...
