Old 07-11-2013, 10:18 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
DIY: Air filter replacement on 35d
Parts
BMW p/n: 13-71-7-798-342
Mann: C 33 001
Mahle: LX 2641
I also recommend some CRC 05110 Mass Air Flow Sensor Cleaner
Tools
A flathead screwdriver
Location
Under the engine cover
R&R Procedure
Remove the engine cover by lifting the front and pulling straight forward. Do not lift it too much, just enough to undo the clips and clear the oil filler cap
Undo the 5 clips holding the airbox cover. Using the screwdriver gently pry them undone
Using the screwdriver release the clamp between the MAF and the intake duct
Unplug the MAF electrical connector by pushing in on both tab and pulling the connector straight out
Pull the intake duct to separate it form the MAF
Lift the front of the airbox cover and pull straight out to remove
Place a clean rug into the intake duct to avoid dirt of tools to enter. Remember to remove it before reassembling
Remove the old air filter cartridge and replace it with the new one. Ensure the new one sits properly into the housing
I suggest you also clean the MAF with some MAF cleaner like the "CRC 05110 Mass Air Flow Sensor Cleaner": using the supplied straw, spray generously, let it dry, spray some more.
Reassembly is reverse. Again, remember to remove the rug from the intake duct.
Old 07-11-2013, 11:17 AM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
Nice write up, thanks for posting this one too.
2014 i3 Rex
Retired 2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
Old 07-11-2013, 11:36 AM
xx xx is offline
Mein Auto: E83 X3, F25 X3 and F15 X5
thank you lpcapital/ZetaTre
E83 X3 | E70 X5 (sold) | F25 X3 | F15 X5
Old 07-11-2013, 03:23 PM
kakalika's Avatar
kakalika kakalika is offline
Mein Auto: 14 X5 35i, 02 530i
Thanks.. Big help. I converted this to a PDF for future reference.
Run flat tires? Nein Danke!
Old 04-15-2014, 01:30 PM
da_menace da_menace is offline
Mein Auto:
Just did it in 15 minutes. Super easy!
Old 04-15-2014, 02:17 PM
ninja_zx11 ninja_zx11 is offline
Mein Auto: 2009 X5 35D
thanks lpcapital for this writeup...
Old 07-20-2014, 05:44 PM
hcch hcch is offline
Mein Auto: X5
What about replacement k&n for non diesel x3.5i?
Old 12-03-2015, 03:51 PM
DieselDonkey DieselDonkey is offline
Mein Auto: 2010 x35d
Just used this
Helped a bunch!
