Old 07-28-2011, 07:42 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Originally Posted by Lindzybird View Post
I just brought my 2006 X3 to the dealer for saturated floorboards on the passenger side. He reacted as though I had a unique situation and said there is nothing wrong with the car after his mechanic looked for a problem. I expressed my concern that I had read that this is a widespread problem and that many people returned time and time again with this problem not getting fixed the first time. I'm concerned. I have only had the car for a few months. I noticed earlier on that my winter (plastic) floor mats on the passenger side would get loaded with condensation and assumed it had something to do with the weather changing; now I think I have had this problem all along. How do I get my service advisor to admit this is a problem? And fix it???
Why do SA's do this? It makes them look incompetent and dishonest. You would think that any reasonable person knows that you will just look it up on the internet.
It's a very common problem.
Sunroof is causing it due to blocked drain tubes
Door is causing it due to damaged vapor barrier
Rear window washer is causing it due to leaking tube to rear washer that runs from front to back.
Good Luck
I had a smart answer like this once and pulled out smart phone and showed him there on the spot that there was several thousand people complaining.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 07-29-2011, 02:26 PM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
SA's hate the internet!
Old 08-06-2011, 12:23 PM
fjcamry fjcamry is offline
Mein Auto: bmwx3
I have this problem now that it rained. I took the floor mats out and shop vacuum the carpet. Next I shop vacuum the leaves from the sides under the hood and on top and underneath the pollen filter. The plastic cover has 3 twist off screw cover that pops up with 1/4 turn. Exposed then the pollen filter and I shop vacuum underneath and found a paper advertisement stuck on the air hole.
Thanks to this post and the pics that helped. Now my carpet is drying and hope this solves the problem next rainfall.
Old 10-31-2011, 11:34 AM
gameday gameday is offline
Mein Auto: X3
This problem is rather annoying. AK65. Thanks for your help. After an october nor'easter with alot rain in my parts I am dealing with this issue now. One really specific question. The black "windscreen", I understand how this functions, but after inspecting (mine X3 2004) it appears that this is not ""Snug"" to the windshield. There seems to be a small gap and in my mind that will allow water to sneak behind. In this instance if the "drain hole" is clean but the the "windscreen" is not snug is your opinion could this also be the cause for the water to run in?
signed - cleaning up a stinky mess this weekend!
Old 11-01-2011, 10:05 PM
Terry J. Harris's Avatar
Terry J. Harris Terry J. Harris is offline
bimmerfest Supporting Member
Mein Auto: '05 Z4 3.0i & '08 X3.0si
AK65, sorry for this having happened to your X3! Also, though, thank you for this informative post and thread. I took a look at my '08 and, sure enough, lots of old leaf and seed debris in the area, including those two drain holes. Took it to the gas station and vacuumed it out. An easy maintenance procedure that quite obviously had NOT been performed, at least recently, by my dealer. I will show the service folks at the dealership what I did next time I have it in. I bet they are clueless, yet will appreciate the knowledge. Again, thanks for alerting all of us to this!
Old 10-08-2012, 06:49 AM
max2700 max2700 is offline
Mein Auto: NJ
Flooding in Footwell
Same Problem. My car is always parked outside under a tree. Severe flooding in footwells, vapor barriers ok, definitley not the sunroof.
I'm not an engineer, but I appreciate I'm not alone with this problem.
Old 10-09-2012, 11:43 AM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
Given your parking situation, I'd definitely check the cabin air filter receptacle; that's just about the only other source for water intrusion problems that collect in the footwells. It's just under the hood, back along the firewall, below the windshield wipers. Lift the hood, and you should see the cover, which is secured with a couple 'quick-turn' releases. Open it up, remove the filter, and examine the area for debris (e.g., leaves). There are a couple of drain holes in the receptacle that have a tendency to get clogged up if you aren't diligent about checking it, and backed-up rain water can enter the cabin through the opening for the cabin air intake.
After cleaning out the drains, slowly pour some water down into the holes to be sure there still isn't a blockage downstream, then replace the cabin air filter (use a clean one if your old one is dirty), and you should be good to go.
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 10-09-2012, 01:34 PM
Mein Auto: NJ
Flooded Footwell
Does this advice apply to the 530i?
Kudos to so many folks who know more about their BMW than trained mechanics.
Old 10-09-2012, 01:55 PM
timfitz63's Avatar
Does this advice apply to the 530i...?
I'm not familiar enough with the 530i to say definitively; but it's quite possible, if the cabin air filter intake on that model is in the same general location as the one on the E83 X3. And it likely is, since this is the area from which most manufacturers draw air into the cabin from the exterior, whether or not a filter is involved in the process. Generally speaking, it's best to keep debris and snow/ice clear of that area on any vehicle so the HVAC can perform properly.
Old 07-08-2013, 11:04 PM
G.K.Thomson G.K.Thomson is offline
Mein Auto: X3 and X5TD
2004 X3 - flooded footwells
Afte noticing puddle of water in front passenger footwell and rear passenger side also soaked,BMW informed me that the drain holes in the sunroof are plugged and the surrounding seals needed replaced for $1000.00.When I went to pick up vehicle I was informed that the panorama roof metal frame was rusted out and needed to be replaced also otherwise it could not be successfully fixed - $3300.00!!(The metal frame alone is nearly $2,000.00!).
My question is "Has anyone else heard of such a problem happening to the whole metal housing that the sunroof runs in?In all the postings concerning flooding problems with X3's there are none that mention the metal housing being effected or needing completely replaced.
Also has anyone encountered problem with passenger floor rusting out because this problem has gone unnoticed?
Old 07-09-2013, 07:52 AM
Mein Auto: NJ
I haven't seen my passenger floor without the carpet. But the flooding did short out most of the electrical system, dissolving many of the wires. Morristown BMW insisited it was the door seals. It was actually clogged drain holes that caused the flooding.
I'm baffled this great car company provides insufficient servicing, unable to diagnose this simple problem due to a minor design defect.
None of the dealers helped me. Only an independant mechanic helped me.
Old 07-11-2013, 08:06 PM
Dale Conrad Dale Conrad is offline
Mein Auto: 740I
Gallons of water
Great info on this post. Just bought our 2007 X3 on 7-06 2013, 64k miles. First thing to
do in the morning is to clear drains if clogged. I restore classic cars as a hobby. Currently
working on 1971 Jaguar E-Type convertible, typical rust. If any of you have found rust as
a result of water/removing all carpet, you can use OSPHO (phosphoric acid) which converts
iron oxide (rust) to iron phosphate, turns metal black. If you have a lot of scale, wire brush
to remove before and after. Wipe after applying. let dry overnight. If any white powder
residue, wipe clean, apply primer/sealer, let dry, apply coat of paint of your choice. If you
are looking at the rust area and can see your garage floor, too late, time to weld.
Old 02-10-2015, 12:45 PM
Ashmeer Ashmeer is offline
Mein Auto: 2010 535i
Hi, I've just experienced a similar issue on my 535i (F10) in that I was recently driving in a downpour of rain and have discovered that the right rear floor, behind the drivers seat was soaking wet.
I have taken the car back to BMW & they advised that it's the door panel vapor barrier that's causing the problem. They have ordered a new one from Germany for replacement. Holding thumbs, hope this resolves the problem
Old 02-13-2015, 09:06 AM
Mein Auto: bmwx3
My problem was the water drainage ports along the A pillar? They cleared out the drain ports and the issue was resolved. These ports can clog from leaves. My car was parked under a tree and in the fall usually get leaves on it. Now I see that no water collects in the rear seat floors by parking in the garage.
