Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 06-18-2013, 11:27 PM
psst psst is offline
Mein Auto: '14 335i
Will 17" style 393 wheel fit 2013 335i?
I would like to find style 393 wheels for winter tires but am a little concerned if they will fit.
Will the style 393 wheel fit a 2013 335i that came with 18" wheels?
TIA
Old 07-13-2013, 08:24 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Moderator
Mein Auto: 320i (F30)
I know that 335i M Sport has the largest brakes. Next are 328i M Sport , which is the same as the 335I.
However, I don't know the answer to your question. Also see how close the brakes get to your wheel.
Old 07-15-2013, 11:25 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
Are you sure about this?
It would be the first time that BMW has varied brake size based on package options on non M car three series cars. They have previously always been the same within a given engine size for North American models. IE: all 335i cars have the same brakes, all 328i cars have the same brakes, etc.
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 07-15-2013, 12:24 PM
Dave 20T's Avatar
Moderator
I'm an idiot, listen to Gary.
My info is based on unreliable observation and a post on another BMW forum. I tried to see, looking at cars on the street, the gap between the wheel and the brakes.
Old 07-17-2013, 10:42 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
incorrect.
the only difference with the brakes on a us market base/modern/luxury/sport 335i and an Msport 335i is the pad compound.
the same for the 328i, same brakes (calipers, rotors) across all lines, with the M sport getting different pad compound.
MY 2014 will have a factory option for upgraded brakes, which is essentially the current dealer/port upgrade. but the stock brakes the same same (aside from pad compound) across a model and lines.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 01-15-2014, 06:05 PM
ERSTD ERSTD is offline
Mein Auto: 08'E92 335xi
Bump, about to buy 393 set for sport line 335i and worried that they won't fit front brake rotors
Old 01-16-2014, 10:58 AM
Bump, looking to buy 393 set for 335i sport line, but worried that the front brake rotors and/or calipers clearance might be an issue.
Anyone has an oem 17inch set mounted on 335i sport line?
(Sorry for the double post, android crap out on me)
UPDATE: i did end up buying 393 set - they do fit.
