Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 05-05-2013, 06:08 PM
GMaur335d GMaur335d is offline
Mein Auto: N/A
No - it's just "tuned out".
The ECU doesn't open the EGR valve to let re-circultated air into the engine - it's 100% intake air.
The physical unit itself is still stock.
Old 05-05-2013, 06:13 PM
kakalika's Avatar
kakalika kakalika is offline
Mein Auto: 14 X5 35i, 02 530i
WOW!!! How did you do that? Is there a DIY or something we can follow. I remember how my EGR used to foul up on my 90's Mercedes 250D.
Run flat tires? Nein Danke!
Old 05-06-2013, 04:18 AM
Mein Auto: N/A
Sorry - it was part of my tune done by JR Auto.
I don't think there is DIY like some of the older cars...
Old 05-06-2013, 09:56 AM
Stugots's Avatar
Stugots Stugots is offline
Speed Demon
Mein Auto: '10 335d, '09 E93 M3
UPDATE - I now have the DEF Injection removed the from the car in software and the Injector and sensors all un-hooked.
The DEF tank has now been emptied and I have driven for about 1-2K without it.
I also had the tune dialled up a bit so I get a tad bit of smoke a WOT, but nothing with anything less.
We haven't had a chance to remove the SCR / DPF housing physically as the piping is odd. All of the links between the DPF and SCR are OVAL in shape, so it's not easy to just cut it out.
What we have been considering doing is creating a new down-pipe that goes in place of the DPF (eliminates Pre-cat) and goes all the way to muffler split after the SCR.
I do like how quiet the car is now, but Megaspeed has been seeing results of 350+HP and 550+TQ with the EU spec car so I'm tempted to try for that with the SCR and DPF!
In any case, something for the near future ..maybe.
Econtune already has a pipe fabbed for this expressed purpose, FYI. Might be something to look into.
'09 E93 DCT M3 - Jerez Black on Extended Black Novillo w/Carbon Leather Trim, BMW Indidivual Audio (752)
Custom Tork Tune, OEM Perf Mod, MS Stage 2 Intake, GTS DCT, Euro MDM - MR Hood Vents/sidemarkers, H8 160, tinted tails, Gloss black grilles w/metallic M fins, V1
LOOKING FOR: MS Perf Underdrive pulleys (19.00.011)
Old 05-06-2013, 04:53 PM
Mein Auto: N/A
Only for EU cars tho right?
The US exhaust system is quite a bit different from what I have heard.
Maybe now that it's more like the EU version (No SCR) it will be easier??
Old 05-07-2013, 03:37 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
I'm quite sure that a capable fabricator could modify an Ecotune pipe to have the same inlet/outlet parameters (shape and location that is) as our US spec DPF cannister. Is the Ecotune part stainless steel? Just need someone patient with a decent TIG welder and other fabrication equipment. From the other thread, a Florida road trip might be worth pondering. Perhaps in another year this capability (DPF decoding) will work its way to the gulf coast.
So the ultimate emission removal mod is
a) closing the EGR permanently (coding it off),
b) DFP removal with fabbed pipe, and
c) SCR removal and pipe replacement.
Am i missing something or is the cat delete happening too? Perhaps this was adressed in an old thread where Csnns (i likely butchered his alias) had a long pipe assy made by a muffler shop.
Old 05-09-2013, 04:40 AM
Axel61's Avatar
Axel61 Axel61 is offline
Mein Auto: 335d
If not mistaken ECOTUNE had sent me an email and they wanted a US DPF so that they could do a downpipe for us and that was a while ago, Stugots if you have yours available 3d scan it and send it to ECOTUNE.
Old 05-09-2013, 08:02 AM
Stugots's Avatar
Speed Demon
I've been talking to both Stan and Mark (Ecotune and Redline, respectively).
The US DPF and the UK DPF are different. The sensors are in different locations, so the Ecotune downpipe would require some changes to it. My DPF is still attached to the car atm, so I'm unable to send it, but I'm still working out some logistics with them.
In talking to Ecotune, the SCR cat is suggested to remain intact, as it is a high flow cat, and assists in backpressure, as well as more stable boost pressure for tuning purposes. Mine still remains, although it's empty now.
Old 05-09-2013, 09:07 AM
Axel61's Avatar
Mein Auto: 335d
great Stugots if you can get someone to do a 3d scan then they ecotune can work it from there, thats how WAGNER did for the IC although they did in their own house
Old 05-26-2013, 08:40 AM
kakalika's Avatar
OK, I think a trip to Canada is worth it. How do I get in touch with JR Auto?
Old 06-16-2013, 11:45 PM
Sylvan Lake V35 Sylvan Lake V35 is offline
X5///M & tuned X5d
Mein Auto: X5M/X5 35d/700hp G35
How has this been going, any codes or errors from removing urea injection?
Old 06-17-2013, 09:45 AM
Hoooper Hoooper is offline
Mein Auto: 335D
IMO a plug and play solution to this, like an O2 sim, would be way better than an ECU tune. Once you tune the ECU to ignore the DPF pressure feedback you cant really put the DPF back on or it will never go into regen. It should be pretty easy to wire up a simulator that just constantly shows the equivalent of a 2 PSI difference so the ECU thinks there is a clean DPF still in the system but it wont go into regen. I dont really care about the smoke/sound portion of this, but if I want to keep this car for over 100k it sounds like the DPF might have to be replaced at some point, at least according to some of the reviews I have seen out of Europe. I dont really want to end up replacing a $2000 part that also is a power and economy restriction, but I also dont want to be stuck with an ECU that will kill the DPF in case I need to put it back on for emissions or to sell the car. I cant imagine that a flash is the only way to take care of this.
Old 07-11-2013, 02:52 PM
GreekboyD GreekboyD is offline
Mein Auto: 2009 BMW 335d
Link
Old 07-12-2013, 06:29 PM
kakalika's Avatar
Originally Posted by GreekboyD View Post
Thanks.
Old 07-13-2013, 08:11 PM
Thanks.
No problem. I plan on contacting Jarek very soon.
Old 07-14-2013, 10:10 PM
stoked335d stoked335d is offline
Mein Auto: 2014 S4
Someone please explain to me how you would pass the State inspection and emissions test with this modification?
Old 07-15-2013, 12:49 AM
montr montr is offline
Mein Auto: 335d 2010
Do you an inspection for Diesel cars in NJ? In GA, there is an inspection for gasoline powered cars but none for diesel.
Old 07-15-2013, 06:18 AM
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
DPF and DEF / SCR Removal
We have yearly inspections for all vehicles where my cars are registered. I assume this would be a fail, right?
Old 07-15-2013, 06:46 AM
F32Fleet F32Fleet is offline
Mein Auto: 435i, 335d sold.
Yes.
SCR DPF removal are for the @sshats who think they know better. Sorry but I'm going to call it like it is. People who remove emissions system on their personal vehicles reek of selfishness and irresponsibility. There's absolutely zero justification.
Old 07-15-2013, 07:03 AM
You would pass after you paid off the technician who performed the test. Seems very common in California for example.
Old 07-15-2013, 08:58 AM
Axel61's Avatar
Mein Auto: 335d
Re: DPF and DEF / SCR Removal
Originally Posted by BMWTurboDzl View Post
Yes.
Ok I respect your opinion but as soon as I get my 50k over its gone as in 3/4 of the world. I careless
Sent from my SPH-L710 using BimmerApp mobile app
Old 07-15-2013, 11:37 AM
SpeedyD SpeedyD is offline
Mein Auto: 2010 BMW 335d Sport
Yes.
I think you are proving his point.
2011 335d M-Sport, Black Sapphire Metallic/Saddle Brown, Premium, Nav
Retired: 2010 335d, Monaco Blue/Oyster, Sport, Premium, Nav, Logic 7 Sound, Comfort Access
Old 07-15-2013, 11:44 AM
Axel61's Avatar
Mein Auto: 335d
i cant changed other people's politically correct responses cause thats me let him go huge a tree i dont hug any i plant them, so i will be selfish LOL
Old 07-15-2013, 11:51 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
As long as the exhaust is routed into the cabin and you get the cancer caused by the particulates, it's fine with me.
And I DO NOT like your taking this lightly; cancer and lung function is not a laughing item.
Old 07-15-2013, 12:16 PM
Axel61's Avatar
Mein Auto: 335d
the only time exhaust will ever enter any cabin is when there is a LEAk in the exhaust system, otherwise cancer can be caught even eating PUNTANG just ask Michael Douglas the actor LOL jajajajajja and yes cancer is NO JOKE my mother passed away in part due to cancer. that said even if you dont smoke drink or whatever you maybe prone to cancer or any other issues
Btw floyd don't worry I don't like you taking the pipe in your cabin either lol. So you won't breathe the cancerous fumes lol
