Old 07-16-2013, 11:05 AM
stevo89 stevo89 is offline
Mein Auto: bmw 740
ineed 97 740i dme relay location ? pictures please
ihave no spark in my 97 bmw 740 ia it turns over fine NO codes are coming up . is there a coil relay . need help please help
Old 07-16-2013, 01:56 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
I doubt it's the DME itself. Sounds more like the crank position sensor. It tells the DME the car is cranking and to send the signal for spark and fuel. If it's bad, the DME does not know the car is cranking and will not send signals. The crank sensor does not always throw a code. It is located on the right hand side of the transmission.
If you google Crankshaft position sensor replacement, there are youtube videos that show how to test it and replace it if necessary.
Also look at the sensor on top of the thermostat housing to make sure it is not burnt. Coolant can leak from the plug, burn the sensor and then travel up the loom to the DME. There are 5 30A fuses that protect the DME. Look at post #33 here:
http://forums.bimmerforums.com/forum...ghlight=myself
Having said that, I have never seen this happen without a code but you want to make sure you don't have coolant getting into the ebox. Believe there is a pic on page 1 of that link of a burnt plug.
Old 07-16-2013, 06:05 PM
Mein Auto: bmw 740
where is the cps sensor . does that sensor cause it not to start
checkd computer no codes coming up as pass. ihear the dme turning on also
