Old 07-17-2013, 02:10 PM
alcofribas's Avatar
alcofribas alcofribas is offline
ZSCCA Asheville volunteer
Mein Auto: 2001 Z3 2.5i
Effects of corrosion
Bought my z3 from a used-car dealer in June 2012, wet floor at first heavy rain. Got to wonder what the dealer knew and wouldn't reveal. Got a new top, leaks were sealed, no more water. Then my ABS system started going bonkers, first with very short brake applications, then finally the ABS and BRAKE lights came on, and took the dysfunctional subsystem out of computer circuit.
Brought the car to my indy BMW garage. Got a call a few days later to look at the car before work is performed. He pulled up the driver's side carpet, asking me if I smelled anything, since there was black mold under the carpet from years of saturation. Much of the car's floor was wet. He then pointed out a connector whose printed circuit board was heavily corroded (see arrow in the photo), indicating this was the problem, and will be replaced.
Anyone familiar with this connector? What else is often damaged by water remaining on the floor below the carpet? My ignorance: I would have thought a convertible would be protected from this kind of vulnerability to water.
Old 07-17-2013, 09:02 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
That could be the "yaw" sensor, a component of the DSC system. I say could be, because I've never had to service one before.
The yaw sensor compares the direction that the car is going, to where the steering wheel is pointed, sensing an insipient spin, and would employ the ABS to tap the individual wheel's brake, keeping the car on course.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 07-18-2013, 04:36 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
Looks just like a side airbag sensor.
http://compare.ebay.com/like/2711168...Types&var=sbar
1999 528iA
2000 Z3 2.3
2003 M5
Old 07-23-2013, 03:01 PM
alcofribas's Avatar
Z3 swamp under carpet / yaw sensor
You were right on the button - it was the "yaw" sensor, which my mechanic refers to by BMW's nomenclature, the rotation speed sensor. The unit in the other photo in this thread is the side impact sensor, cruddy but in good condition. The attached photo is the current state of affairs. With the heat and A/C controls detached, I looked for the hot-air gate, which sticks when in the closed position because of bare adhesive, but didn't locate it.
Old 07-24-2013, 03:39 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
http://www.bimmerfest.com/forums/sho...d.php?t=318432 post 11 has a picture of the bowden cable connector and the blend door arm.
My memory is when moving the blend door you can see a small bit of the blend door.
connector, corrosion, floor, mold, wet, z3
