ABS,DCS,brake lights on and code P0221,p1633 - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 07-15-2013, 10:37 PM
clq456 clq456 is offline
Mein Auto: x5 3.0l
Exclamation ABS,DCS,brake lights on and code P0221,p1633
Hello!This is new member here.I need your help! the story is:
My suv 2002 BMW X5 3.0L.At the beginning the front wheels and steering wheel shake when use brake about 80-100km/h.later the DCS,brake,ABS,SES lights on.Now the engine safefair prog comimg and idle speed run about 1200 (a little high), idle speed not stable as well,sound very rough.using torque software got codes P0221 and p1633.I have cleaned the ICV and throttle body,valve but nothing changed.I also checked the 4 wheel speed sensors are all good.so I take off ABS moudle,take off battery half hour for reset,after that start engine it still proble.so question:Is it my ABS moudle damage?Do I need fix my ABS module?and does have anyelse proble on my car or just this module fault?
Thanks!I appreciate you will give me any suggestion!
Old 07-18-2013, 11:32 PM
Mein Auto: x5 3.0l
keeping going!
