Old 07-19-2013, 05:11 AM
carlov1 carlov1 is offline
Mein Auto: bmw
Need help with my 2007 530xi it won't start
Hi everyone, I really could use some help with my car, it does crank it turns over but just won't start, I replace the battery about a year ago as well the spark plugs an a coil (due to a miss fire) so now the car has 80,000mil. Does anyone have the same problem? Thanks in advance
Old 07-19-2013, 07:15 AM
pcy pcy is offline
See if there are any diagnostic codes set. How many miles on the car? You may need to check the fuel pressure on the rail during cranking.
Crankshaft position sensor can cause this kind of problem. Just listing various things that are likely culprit. You will need to go one by one and eliminate each of them as the culprit.
Good luck.
Old 08-11-2013, 06:56 PM
Mein Auto: bmw
Hi guys, just to let everyone know that it was the Security system that it was wrong on my car, after I checked the fuel system,
Spark plugs, coils, cam sensor, crank sensor, battery, fuse and lots of other things, I couldn't figure it out my self, I took it to the
Shop (bmw certified) they fix it in no time and they charge me $94 dollars, they said this "we scanned the car for related codes and
Found the EWS module was mis-aligned, we re-aligned the EWS to the DME and tested. Car runs and drives normally at this time."
So they said they don't know why it get mis-aligned or when it would happen again
So there you go guys if this could help someone it will be great
And thanks for the response PCY appreciate the intention
