Z3 Coupe (E36/8) AC only works on high - Bimmerfest - BMW Forums
Old 07-19-2013, 01:16 PM
1999z3mike 1999z3mike is offline
Mein Auto: Z3
Can someone please help me out? I have a 1999 Z3 coupe hence the name. My AC only works on hig. Is it the switch or a solinoide? I figure with all the brilliant ppl on the site someone will tell me the simple answer.
Old 07-19-2013, 01:40 PM
Mein Auto: 1998 Z3 Roadster
What do you mean by "only works on high"? Do you mean the blower only works on high speed or do you mean the AC only works on "recirculate"?
Old 07-19-2013, 01:41 PM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Fairly easy and cheap DIY.
http://forums.bimmerforums.com/forum...on-4-write-up-)
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 07-19-2013, 02:14 PM
Mein Auto: Z3
The blower only works on high
1999 BMW Z3 Coupe
Old 07-19-2013, 02:18 PM
Mein Auto: Z3
Looks easy enough. Thank you for the link.
1999 BMW Z3 Coupe
Old 08-29-2013, 06:51 PM
Levy214 Levy214 is offline
Mein Auto: BMW 645CI and Cayenne GTS
Is it normal for mixed hot and cold air to blow thru the driver side window vent? Seems only to happen in the morning
1999 z3
