Old 07-16-2013, 11:38 PM
55396 55396 is offline
Mein Auto: Z3,79 Olds,Duc,08 528,VTX
Yup. Just need to know the weight of the correct damper.
Old 07-16-2013, 11:47 PM
Real oem popped it right uo. Good tip. Thanks.
You Have Selected: 06/2007 E60N 528i Sedan N52N USA Left hand drive N
Old 07-17-2013, 07:52 AM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
FWIW, I've noticed that in my 530 my idle is just ever so slightly a bit rougher when I have the A/C running. When I turn off the A/C the idle is very smooth.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 07-17-2013, 09:21 AM
drinnird drinnird is offline
Mein Auto: 525i
That's interesting because there are different rpm maps for when the AC is on and when it is off.
I actually had a chance to look again at my inpa and found that you can change the idle by going to e60/f9/f5/f6 and then putting in 690 (rpm speed). i clicked end and backed out and exited inpa and the idle settings still remained after I turned off the car and turned it back on again. Hopefully the settings stick for good.
Old 07-17-2013, 03:31 PM
Interesting. I noticed the vibration before I bought my 08 528i and that I could just touch the accelerator enough to bring the RPM up like 100 and no vibration, so I figured it was a simple idle adjustment, but dealers tell me you can't adjust idle. That doesn't make sense to me because with electronics, you can adjust or tweak more and more, and idle is pretty basic.
Old 07-17-2013, 03:42 PM
imp.the.dimp imp.the.dimp is offline
Mein Auto: 2000 528i
vibration at idle 2007 525
Just my two cents but on an e39 vibration at idle can be caused by the idle control valve. I don't know if your engines even have one but it could be worth looking into. The exhaust damper might just be a fix
Old 07-17-2013, 06:37 PM
Mein Auto: 525i
Ok so turns out the settings didnt stick. I snooped around some more and found the option that permanently saves the changes.
/e60/MSV70 for N52/F9/F8 and start the engine (if the engine isnt started, there is an ecu conditions error from INPA when trying to read status etc..)
Adjust the offset for each item by entering a number which will be added to the base idle of 660... So if you want to adjust the idle in park up to 690 (660 is default idle) then put the offset as 30. Attached are my settings which I found smoothed out my idle.
With the AC on, it seemed to need a bit more rpms to smooth out the idle since the AC put more of a load on the engine.
Name:	idling change.jpg
Old 07-17-2013, 10:27 PM
Robert A Robert A is offline
Mein Auto: BMW 535d
Try bumping the idle about 50 rpm. I had the issue with my 530i and that took care of it.
Originally Posted by ChrisTO View Post
Anyone else have a slight vibration at idle? The vibration can only be felt in the steering wheel and the shift knob. I sat in another 525 with manual tranny and same thing.
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 07-18-2013, 09:56 AM
vk535i vk535i is offline
Mein Auto: 535i
I have same problem too. just little vibrate when idle. cold or hot or the car run for few hours when stop at idle I feel just a bit vibrate. Took to dealer 2 times, they didn't find any problem. Last time I had a loaner 2013, 528i, 3K ++ miles, and the vibrations is the same symptom my car has. So I assume is "normal" or I have to live with it. What I am thinking maybe the idling RPM kindda low. If they can adjust just the RPM about 50-100 rpm more for idle, then the vibration will be solved.
2014 550i, Jet Black / Black Dakota Black, Bamboo Anthracite Wood Trim, M-Sport Package, Executive Package, LED Lighting Package, M Aerodynamics Package, HUD, Adaptive LED Headlight, Harman/kardon Surround Sound System. Surround/top View Camera, BMW Apps via SmartPhone, Split fold-down-rear seat ...
Old 07-18-2013, 10:30 AM
Mein Auto: 535i
bro,
what type of OBD2 cable to use with this INPA, I want to get one so I can run diagnostic and change out my idle value little bit higher. please let me know.
Old 07-18-2013, 10:48 AM
Mein Auto: 525i
Originally Posted by vk535i View Post
bro,
Depends on your cars build date. For e60s prior to 2007 build date (enter vin on realoem.com to find build date), you just need the cheap k-line cable on amazon...its the blue vag com cable. But for cars 2007 on, you'll apparently need the k+d can cable but do some research as some cables are better than others when using with inpa.
Old 07-18-2013, 11:02 AM
Mein Auto: 535i
My car built date as shown on the VIN tag at the door is 05/09. So which cable I should get that allowed to program the setting? and software to download.
thanks
Old 07-18-2013, 08:52 PM
Mein Auto: 525i
thanks
Start here:
http://bmwcoders.com/forum/bmw-gt1-o...-software-328/
Then here:
http://www.bimmerfest.com/forums/sho...d.php?t=561237
Then here:
http://www.bimmerfest.com/forums/sho...d.php?t=505694
Old 07-19-2013, 10:37 AM
Mein Auto: 535i
Just purchased whole set of ODB2 cable interface. I looked at your referred links for software and installation, there are a lot of different version of software. All I need is a single software that I can use and program the new value to my car ( just the idle value). I am not trying to do anything fancy or whole lot of changing. Please point me to the software that I need.
thanks
Old 07-19-2013, 01:59 PM
Mein Auto: 525i
thanks
You will need to install inpa from those links. That is the software I use to adjust the idle.
Old 07-19-2013, 03:10 PM
Mein Auto: 535i
so all I need just the INPA software. that's it ?
Old 07-19-2013, 05:08 PM
Mein Auto: 525i
Yep, but for inpa to work you'll need to install the whole suite of applications since it comes in a package anyway. Ediabas, inpa, ncsexpert, winkfp etc.
Old 07-19-2013, 06:17 PM
Mein Auto: 535i
ok will get the software install and waiting for the cables kit arrive. Thanks bro
Old 07-27-2013, 04:07 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Re: vibration at idle 2007 525
Thanks for the explanation on how to use that section of INPA. I have been having the same problem and noticed that after cleaning my ICV (which is half good as per factory values) and clearing engine adaptation, my idle was fixed for few mins and the idle rpm went up to 790-800. But after few min the idle went down to 660 and problem re-appeared. That could be because of some electrical part not functioning optimally and the ecu calculates the load and reduces the rpm. So changing the idle in the software might not be the only solution. Has any body here having to this problem tested the ICV electrically. More details and options are available in one of my threads if you want to read further.
Sent from my Android Bug
Old 02-08-2014, 03:37 AM
dawood.zul dawood.zul is offline
Mein Auto: 2008 BMW 528i
Hi, I recently purchased a 2008 BMW 528i, after following this and few other forums I cannot find the fix for vibration at idle when car is running at optimal temperature. According to realoem.com production date is 04/2007 and engine is N52N (Left hand drive). I have also diagnosed my car with few BMW dealers and they said everything was normal.
I also told them to look at the BMW service bulletin 18 02 08, however, they said this was not valid for Canadian vehicles as their database does not show this bulletin. Can someone please tell me if its the brackets I need to change or just the damper it self. If so, which exact parts for both and frequency for the damper (83Hz or 32 Hz). Thank you in advance
Old 02-08-2014, 04:04 AM
kskane's Avatar
From DownUnder
You may want to read this thread, it has few options to fix. If you do try any and happen to find a solution, please post back on the following thread. I have been chasing this issue for quite some time.
http://www.bimmerfest.com/forums/sho...826&highlight=
Old 02-08-2014, 06:01 AM
Thanks for the info. I will definitely post a reply if I find a solution to this problem. If anyone has done a fix, please post it in this thread. Thanks
Old 02-09-2014, 12:55 AM
528i vibration bulletin
http://www.justanswer.com/bmw/2o5ry-...two-weeks.html
Old 02-10-2014, 04:45 AM
kskane's Avatar
From DownUnder
Originally Posted by 55396 View Post
Vibration damper is not a solution to this issue. For further details, read
Old 02-10-2014, 05:34 AM
I will be taking a look to possibly remove the exhaust bracket sometime soon and hopefully that will resolve the issue. Worth the try..
08 528i
