Old 07-10-2013, 06:12 PM
lomant lomant is offline
Mein Auto: 2004 530I
Brake pad code will not reset
I have a 2004 530i i tried to reset the brake pad code after i change the brakes . It will not reset i dont know what to do if someone could help me out
Old 07-12-2013, 08:38 AM
Elpulpo42 Elpulpo42 is offline
Mein Auto: Bmw E60 530i 04
Re: Brake pad code will not reset
After you change the pads you have to reset it manually. If you dont know how to check con youtube and type reset warning brake light con e60. Good luck with that.
Sent from my C5170 using BimmerApp mobile app
Old 07-12-2013, 09:10 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Maybe I was wrong, but I thought it reset after lock-to-lock left and right on steering wheel.
Old 07-12-2013, 09:28 AM
Adamo99 Adamo99 is offline
Mein Auto: e39 530i, e93 335i
If it's anything like the e39 or e46, it should shut off on its own after approx 50kms/35 miles.
Old 07-12-2013, 11:28 AM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
No, it doesn't reset itself in anyway. It's manual. As suggested check on youtube for video instructions. It is reset in using the odometer reset hidden menu.
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 07-12-2013, 05:53 PM
l1tech l1tech is offline
Mein Auto: 09 528i
Are you trying te reset the brake check interval inspection or the pad warning sensor? I just turn the key oin with the car off for about a minute and the pad warning sensor resets...of course you need to replace the pad sensor first
Old 07-13-2013, 11:04 AM
thanks for all your guys help
Old 07-14-2013, 05:14 PM
bschmidt25 bschmidt25 is offline
Mein Auto: '07 530xi, '01 525iT
+1. I needed to reset mine manually after replacing the pads. It won't reset if the circuit on the pad sensor is broken, but it will otherwise.
1) Turn on ignition (don't start car)
2) Hold the odometer button until you see the service indicator (about 4-5 seconds)
3) Press the odometer button quickly to scroll through the list of service items until you see the item you want to reset
4) Hold odometer button a little longer once you see it. It will ask you to confirm reset. Hit the button once more (hold it for a second or so). You should see the mileage change to indicate it has been reset.
Done!
Old 07-15-2013, 07:37 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Since no one mentioned this, OP did you replace the wear sensor? The service indicator will not reset if the wear sensor is worn.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 07-19-2013, 06:21 PM
MADBMWX1 MADBMWX1 is offline
Mein Auto: 2013 BMW X1
Stupid question...I am about to replace rotors, pad and sensor (the sensor light is not tripped)...question is...do I need to disconnect the battery prior removing the sensor?
Old 07-19-2013, 06:37 PM
Mein Auto: 09 528i
No
Old 07-19-2013, 07:43 PM
Thanks!
