The X5 SAV Forum
Old 07-21-2013, 09:31 AM
syaufu syaufu is offline
Mein Auto: 2005 bmwx-5 4.4i
xenon headlight out
I have a 2005 bmw x-5 4.4i. The driver's side xenon headlight is out. I checked (by switching with the passenger side) and the light bulb and igniter are good. Does that mean that the ballast is bad? The ring around the headlight (I think that is the daytime driving light) still works.
There isn't a relay or fuse for this that I need to check is there?
If it is the ballast, how do I change it?
BTW, I now have a new pair of Morioto D2S 3Five (35w) 4300k bulbs that I bought and do not need.
Also, I thought that the outside light was the low beam and the inside light was the high beam. But when I turned on the high beams, the outside light gets brighter, but the inside light doesn't light up. The inside light only comes on when I "flash" the high beams. Is this the way it should work? The "flasher" light is working on the driver's side, but neither the high nor low beam setting is working on the driver's side.
Thanks for any help!
Old 07-21-2013, 11:50 AM
Ok, so I found the answer to my question re: high beam/flasher:
The flasher is just that - a flasher not high-beam mode.
The Bi-xenons have a lid that covers it in low-beam mode. When you actually engage the high-beam mode the lid retracts - that is why its called bi-xenon.
Still trying to figure out if I have to remove the bumper to change the ballast....
Old 07-22-2013, 09:13 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Subscribed...keep us informed to your progress...and pics if possible.
Q {BMW CCA Member #191509}
(SOLD)
Old 07-23-2013, 10:54 PM
So now I have learned that in deed the front bumper needs to be removed to replace the ballast/control unit. I am now exploring buying the OEM Hella ballast, then having a mechanic replace it for me. If you get the part from BMW, it costs around $500. I think I should be able to pick one up myself for $150-$200.
Old 09-30-2013, 07:14 PM
TOOT77 TOOT77 is offline
Mein Auto: X5
Red face
Hello, where did you get your parts from. Do you know or have the part numbers? I'm a female and I'm trying to find the best deal and not to be taken advantage of. I was told it was the bulb and it wasn't the bulb and I was told its the Hid computer/transformer. Is that the same as ballast control unit? I'm unable to drive at night because its the drivers side! Thanks
Old 09-30-2013, 07:56 PM
Toot77, I am also female, so I understand where you are coming from. At first I thought it was my light bulb, so I bought a pair from The Retrofit Source Inc.(see my first thread), which I now do not need. I'd offer to sell you this pair of bulbs, but they're in Utah, and I am in Arizona until mid-Oct. I figured out, after I bought them that it wasn't the bulb because I put the new bulb in, and it didn't help. The best ting to do is to take the good bulb and put it on the bad side to see if that makes a difference. This isn't too hard to do, but you have to be willing to get your hands a little dirty and move some parts around. Best to go onto Youtube for a video on how to change the xenon bulb.
If it's not the bulb, then most likely it is the ballast (which is the computer/transformer). I got this part on ebay: NEW Hella Xenon HID Ballast OEM Germany 5DV 008 290-00 Headlight Unit Igniter from "genuinexenon" for $145. I found a mechanic that was willing to just provide the labor for changing the ballast. If you have to buy the part from the BMW dealer or if the mechanic gets it for you, it's about twice as much.
Good luck, hope this helps!
Old 10-01-2013, 06:48 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
If you have an E53, you should be able to change the ballast by removing the complete headlight assembly. The bumper doesn't need to be removed, but the trim piece under the headlight does. There are two screws on the top of the headlight, and two more underneath it. The bottom two are a challenge to remove (1/4 socket extension with a u-joint will do it).
The trim strip under the headlight is removed by GENTLY pinching the mounting tabs together on the inside end (the end nearest the grille) with a pick or small screwdriver. You need to pry the rubber seal back a bit to see these little tabs. If you break the tabs off, the trim strip will rattle. Once the clip is free, carefully pull it back at a slight angle and remove the other end from the slot (no clip on the outer end). There are two more tabs on the bottom of the strip, these usually pull right out.
Once the assembly is out, you need to remove the headlight itself from the mounting bracket and then you can R+R the ballast. I ALWAYS replace the turn signal bulb when the unit it out, as preventative maintenance (the light has to come out again to replace these bulbs). The bottom seal on the trim strip usually needs to be reglued with some silicone seal.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 10-01-2013, 10:23 AM
QSilver7's Avatar
Originally Posted by Scott ZHP View Post
If you have an E53, you should be able to change the ballast by removing the complete headlight assembly. The bumper doesn't need to be removed, but the trim piece under the headlight does...
The facelift E53 (2004-2006) doesn't have a removable trim piece below the headlight. Which makes this DIY a little more complicated. If you don't have the headlamp washers...you may be able to finagle the headlamp assembly out...but I believe most 04-06 owners usually remove the bumper due to the slight change in how the front bumper, front fenders, and headlamp assemblies are designed and fit together.
facelift
(2004-2006) e53 X5 (note front bumper/fender/& no removable trim piece below headlight)
pre-facelift (2000-2003) e53 X5 (note front bumper/fender/trim piece below headlamp)
(SOLD)
Old 10-01-2013, 12:14 PM
Scott ZHP's Avatar
We want the Lion!
Ah right. Thanks; I have an 01 and forgot about the facelift changes.
I've had my bumpers off to retrofit PDC, it's only another 30-45 mins to yank the front bumper as I recall.
