Old 07-21-2013, 01:19 PM
ins1dez ins1dez is offline
Mein Auto: 320d
Hello
please PM the VIN for internet also
My car is stuck when I click Update BMW Services
It stays there,nothing happens, what could be the problem?
Old 08-03-2013, 09:43 AM
kaxasia kaxasia is offline
Mein Auto: BMW F10 550 M
Hi. Can you send me also fake vin ? best regards
Old 08-04-2013, 05:45 AM
someone have FAKE VIN? or how i can find
Old 08-04-2013, 06:31 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
So, I went and looked through all my old FA's, and found the VIN I used, which is from a Malaysian spec'd F10, which was PM1FP34070C466490.
Old 09-10-2013, 01:48 PM
Booris Booris is offline
Mein Auto: 5gt
Hey shawnsheridan and others!
Thanks for all info what you provide.
I have germany imported car and i would like to get bmw live+internet work via bluetooth since bmw online and bmw assist is not supported here in Finland and my Germany car wants only use car sim for data transfers
Do you think your method will work in my BMW F07 02/2012?
My car has next factory installed options:
S601A TV-FUNKTION
S609A NAVIGATIONSSYSTEM PROFESSIONAL
S610A HEAD-UP DISPLAY
S612A BMW ASSIST
S614A INTERNET VORBEREITUNG
S615A ERWEITERTE BMW ONLINE INFORMATION
S616A BMW ONLINE
S620A SPRACHEINGABESYSTEM
S633A HANDY VORB. BUSINESS/BLUETOOTH-SCH.
S677A HIFI SYSTEM PROFESSIONAL
S698A AREA-CODE 2
S6AAA BMW TELESERVICES
S6ABA STEUERUNG TELESERVICES
S6FHA FOND-ENTERTAINMENT PROFESSIONAL
S6FLA USB-AUDIO-SCHNITTSTELLE
S6NFA MUSIC-SCHNITTSTELLE FUER SMARTPHONE
S6NRA APPS
S6VCA STEUERUNG COMBOX
Now if I understood correctly i dont need either a fake VIN and i need to do only following steps:
Change VO as follows:
- 612
- 633
+ 644
+ 6AL
VO CODE HU_CIC
VO CODE CMB_MEDIA
1) Enable Data Transfer Option Under Phone
2) Enable Bluetooth Data Tethering on Phone
3) Under Connected drive; Update services (should show BMW Live and Internet services)
4) Go to BMW Live and Internet and make sure it it working
Are these correct steps in my case ?
Thanks for the help and keep up good work
Booris
Old 09-10-2013, 09:34 PM
S601A TV-FUNKTION
S612A BMW ASSIST
S616A BMW ONLINE
S698A AREA-CODE 2
S6NRA APPS
- 612
- 633
+ 644
+ 6AL
VO CODE HU_CIC
VO CODE CMB_MEDIA
Booris
That looks right. Since you have 614 from factory, your own VIN should be fine. But Internet / BMW Live is difficult to get working, and it works for some and not others, so give it a shot and see what you get.
Old 09-15-2013, 11:17 PM
maisav maisav is offline
Mein Auto: BMW F11 530i
Yesterday i found a strange situation into my car BMW services.
Unless i upgraded services status, the car its self made it... Maybe during a BMWLIVE session..
Then now it shows assist services that i needed to disable to have BMWlive working...
I didn't try yet them but now I've bmwlive working and internet not. Internet function now says that my country doesn't have internet services (but they are sold here and until two days ago they worked).
It's a very unstable coding the BMW services session.
Old 10-06-2013, 10:25 AM
Mein Auto: 5gt
I've played with car now 2 days, but I cant get internet to work. Any I ideas what could be wrong?
BMW live and Internet are both under connected drive. Car updates available services nicely and connects to BMW live with bluetooth through cellphone, but when I start Internet browser it just stays in "starting internet", my phone does not show any hotspot connection and after couple of minutes browser shows same old message "Activate data services for bluetooth or connect to service".
Looks like car still tries to connect internet with car sim?
Any idea what could be wrong?
I removed from my VO 633, 612 and added 644,+ 6AL, Coded HU_CIC and CMB_MEDIA.
614, 615 are factory fitted so I didnt change vin.
Is there still some place to look that could stop BT tethering to work with internet?
Old 10-06-2013, 11:36 AM
In your FA, what are these set to?
Typschlüssel=????
Zeitkriterium=????
Old 10-06-2013, 11:49 AM
Mein Auto: 5gt
Typschlüssel=????
Zeitkriterium=????
SN81
0911
Car is F007, 612 assist factory fitted, but removed...
Old 10-06-2013, 11:55 AM
SN81
0911
Why would your car have both 633 and 612 to begin with? If 633 is present, 612 should not be.
BMW Live I do not think was an option for 0911. Change this date to 0712, and then VO Code CMB_MEDIA and HU_CIC again.
Old 10-06-2013, 12:51 PM
Mein Auto: 5gt
Dont know why 612 and 633 together, but seems to be in other cars in forum too.
I have also 616 Bmw online, maybe i have to remove it to test if its problem?
I tried date change to 0712, but nothing changed.
Its wierd that it uses tethering to load live and update, but not for browser?
Its germany car, do u think I should change country (dunno know how)? I think internet through car is only available option in germany.
Is this all what ihave to fdl code or could there be something missing?
HU_CIC:
CONNECTED_DRIVE = aktiv
ONLINE_BROWSER = beide_aktiv
ONLINE_BROWSER_LIVE = aktiv (if also +6AL)
ONLINE_SERVICES = aktiv
ONLINE_SERVICES_GLS = aktiv
CMB_MEDIA:
SIM_ENABLED_MB = csim
DATACOMM_CSIM = aktiv
DUN_PROFILE = aktiv
Thanks again!
Old 10-06-2013, 12:57 PM
HU_CIC:
CMB_MEDIA:
DUN_PROFILE = aktiv
Thanks again!
I don't know why you are FDL Coding anything. I wrote VO Code. The only thing FDL Coded is TELEMATIK_VIN, but this does not apply to you as you are not using a Fake VIN as you have factory Option 614. And if you do not VO Code as I wrote, the Zeitkriterium=0712 won't even be used.
Old 10-06-2013, 01:24 PM
Mein Auto: 5gt
Connect => Read FA => Activate FA => Read VCM => Right-Click on HU_CIC (the ECU itself not the underlying CAFD) => Select CODE.
I maybe made mistake here, because i writed new FA to car first and after that coded CMB_MEDIA and HU_CIC? What u think.
After that values was not what stated here and i FDL coded those to correct ones?
So if i only VO code CMB_MEDIA and HU_CIC, without writing FA to car, will that make difference?
And I changed FA (VO)following Step-By-Step quide by MWPos. Same with date. Do i miss something? :/
Old 10-06-2013, 02:21 PM
If you change FA, and wrote FA to car, and then read FA back from car (verify changed FA is present by expanding it and looking at option codes) and then Activated FA and VO Coded (Right-Click on ECU => Code) CMB_MEDIA and HU_CIC, then that it is correct.
But above you wrote you made individual FDL Code changes, not that you VO Coded the two ECU's, so I really don't know what you did.
Old 10-06-2013, 02:44 PM
Mein Auto: 5gt
I did what is in red, but most values stayed different than under:
CMB_MEDIA:
DUN_PROFILE = aktiv
I was confused, because i thought VO code changes automatically correct Ecu values for written FA(VO).
So I changed corrected them with FDL.
I try it once again tomorrow and test what changes and what not.
Thanks again
Old 10-06-2013, 02:48 PM
CMB_MEDIA:
DUN_PROFILE = aktiv
Thanks again
VO Coding does make all the changes for you, but it is also based on the build date specified in the VO. If you use a build date that precedes the availability of the option code you added, the option code will simply be ignored during VO Coding. You also need to verify that the FA as read back from the car actually contains your VO Option Code changes.
Old 10-06-2013, 02:56 PM
Mein Auto: 5gt
VO Coding does make all the changes for you, but it is also based on the build date specified in the VO. If you use a build date that precedes the availability to the option code you added, the option code will simply be ignored during VO Coding. You also need to verify that the FA as read back from the car actually contains your VO Option Code changes.
Ok, I try again tomorrow, maybe I ****ed up something after date mod.
I did verified date from car and it was there, but after trying everything so many times I'm no sure anymore if I did VO code both ecus after that anymore...
I tell results tomorrow
Old 10-06-2013, 02:57 PM
Ok. Good luck.
Old 10-07-2013, 04:05 AM
pierreye pierreye is offline
Mein Auto: F10 528i
Recently got a Pre-LCI 528i with NBT unit. I'm having trouble enable BMW Live. My ride come with 6NK with USB and Bluetooth Data (I can enable Data connection under bluetooth). I had FA VO with option 6AL on NBT unit.
Also make changes to below code.
HU_NBT>
3003 > ONLINE_BROWSER = nur_bmw_internet_aktiv
3003 > ONLINE_SERVICES = aktiv
3003 > ONLINE_SERVICES_GLS = nicht_aktiv
3003 > ONLINE_BROWSER_LIVE = aktiv
Although I can see BMW Live under ConnectedDrive menu but it is grey out. Any idea? Do you connect your iPhone using USB cable or Bluetooth for internet access? Had try Bluetooth with Personal Hotspot enable and I can see the Globe icon on IDrive which I assume Data Transfer is enable.
Thanks in advance.
Old 10-07-2013, 05:15 AM
HU_NBT>
Thanks in advance.
Does Internet and BMW Live show up when you check available services?
Is this NBT Head Unit Factory or Retrofitted?
Old 10-07-2013, 06:21 AM
Mein Auto: F10 528i
Both Internet and BMW Live show in ConnectedDrive even before check available services (after coding FDL) but BMW Live is grey out. After I check the services, the BMW Live selection still grey out. NBT HU is factory fitted. My I-Step is current showing 07/13.
Old 10-07-2013, 07:19 AM
So, now you have your answer. BMW Live is not available as a service for your car, which means the VIN you have is not authorized BMW Live Portal access.
Old 10-07-2013, 07:43 AM
Mein Auto: F10 528i
Anyway to bypass that using another VIN?
Old 10-07-2013, 08:03 AM
With CIC, yes. With NBT, no.
