Old 07-15-2013, 09:55 PM
Teacher Blind Teacher Blind is offline
Mein Auto: 2006 BMW Z4 3.0si
2006 3.0 si Oil Check Indicator
When I push the dash button to check the oil I get 3 segments and then the OK light comes on. I am not sure but I think that prior to this I would get 4 segments and then the OK light. What does it mean when only 3 segments are indicated? Does that mean the oil is low but not enough to add 1 quart? Or am I just imagining that there were 4 segments? The OM does not address this. Thanks in advance for any input.
Old 07-16-2013, 07:16 AM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
It means you are a quarter quart down from full. It is ok.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors
Old 07-21-2013, 02:57 PM
I was on another forum, Duck Hunters talking about the oil used in their trucks, and came across this statement-
I tried using the vehicle manufacturers recommended oil viscosity with a new GMC pickup I bought several years ago and oil consumption began in hot weather especially while towing.
I called Valvoline and got one of their R&D people on the phone, he told me the thin oil was actually vaporizing with the high temperature's and added load and said to go to a thicker grade oil.
The oil level on my 06 3.0si never changed for the first 7500 miles that I owned it. It currently has 40K. I then changed the oil and used Castrol Edge full synthetic 5w-30 as per the strong recommendation of my indy mechanic.
Could vaporization be a possibility? I live where 100+ degrees for a week or two in a row is not uncommon. Our high here this summer was 113.
Is it nuts to even consider a thicker oil for summer driving? Are there some inherent problems with Castrol?
What are your thoughts? As per the original post, why would I lose oil when there are no leaks and no visible smoke when driving?
Thanks for your input.
Old 07-22-2013, 12:00 AM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
Castrol has a new full synthetic that's states on the front it's for BMW, Volkswagen and Mercedes... 5-40 and on the back it states it meets LL-01 specs. I found this right after doing an oil change. My oil consumption is about I litre in about 1000-12000 Km's or less. I intend to switch next oil change.
Old 07-22-2013, 07:14 AM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
Three bars means that your level is still OK. I personally do not worry until all bars are gone and then I will add a full quart. Better to be a bit low than to overfill. IMHO.
