Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 08-20-2012, 11:22 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
For Those Of You Who Want To Access The Hidden Menu
For those of you who want to access the hidden menu please read. This option will allow you to check your current operating voltage level, engine temp an many more options which cannot be seen through the I drive follow these steps. 1st hold the reset button, the next light that would pop up would be "ABS". Ignore that and keep holding the reset button. There will be a second screen popping up, ignore that one as well and keep holding the reset button. As soon as the third screen pops up, release the reset button. This screen would have approx 15 or 16 options. Go the option which says "unlocking". Press and hold reset button. The unlocking menu will now appear on the right side. Input your unlocking code (for me it was 11 - add last 5 digits of your VIN number). As soon as you put the code, hold the reset button. The screen on right side would disappear now and you would be back to 15-16 option screen. Now go and select the desired option an press and hold the reset button while on the selected option. You would now see the info on the right side of the screen. I give all credit to "itsgonabeme".
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 08-21-2012, 05:17 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
On the 745 unlocking is item number 19.
Old 09-03-2012, 07:53 AM
Big N Fast Big N Fast is offline
Mein Auto: 03 BM760Li, 67 Mustang
Mine was 3...
Just like rookie 2008 said...add the last 5 digits together! Thanks rookie!
Old 03-01-2013, 09:52 AM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
Can anyone provide an explanation for each option available to select? Yes, ones like the charging mv reading are easily understood...but there are several that are not.
Old 07-22-2013, 04:56 PM
XaSeR XaSeR is offline
Mein Auto: E65 730D / Jeep's
What is the "SW-reset ?" ?
Old 07-24-2013, 07:02 AM
wjjklj's Avatar
Software reset.
Old 09-04-2013, 06:30 AM
Originally Posted by wjjklj View Post
Software reset.
Yeah but has anyone done it to see what it does?
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 09-10-2013, 12:05 PM
bluzplayer bluzplayer is offline
Mein Auto: 2007 BMW 760Li
I wanted to unlock so I could display my battery voltage in the Combi, but I was not able to find the code (i.e. 11, or 19). Also, the instructions above mention adding the last 5 digits of the VIN, how exactly is that done? I can use the button to advance 1, 2, 3, ...45 but cannot go past that limit. So is it something like 11 + 12345 = 26 or is it 1112345? Specifics are better! I read another post that mentioned turning the button on the Combi instead of pressing it, have not tried that yet...
Ed
America is a divided country. Liberals and progressives vs conservatives. One side is about fairness, the other side is about fairness. The difference is the definition of fairness.
Old 01-13-2014, 04:43 PM
If the last 5 digits of your vin were 12345, your unlocking code would be 1+2+3+4+5 which equals 15. Therefore, your unlocking code is 15. Keep pressing the button until you get to unlocking and then hold the button until it changes. Once there, tap the button until it counts up to 15 and then hold it when you are there. It will now be unlocked.
