Old 07-24-2013, 08:48 AM
mikewhomiko mikewhomiko is offline
Mein Auto: 2004 bmw 745li
power problems
hey, thanks for reading, Iwrote here about a week ago, my battery keeps on dieing. my alternator is great had it checked out twice.I registered new battery and nothing, do u think its the power moduel? or what can it be ? how much does that costs? thanks
Old 07-24-2013, 08:53 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
You need to have a current draw test performed on your car and see what modules aren't going to sleep. There is a special command you send to the car to force it to sleep right away, then you can monitor the current draw of all the systems.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 07-24-2013, 09:09 AM
thanks, how do I do that?
Old 07-24-2013, 10:42 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
power problems
Use the hidden menu to check your alternator output. Did you replace the battery? Doubt it is the power module.
Old 07-26-2013, 09:56 AM
how do i check that? i have had my alternator checked out , it is great.
some people say it is the ism or the power moduel.
yesterday i was driving, my a/c stop blowing as hard, my speakers were shifting from side to side, and then my abs, park, and transmission failsafe light when on.
after i shut it off , and let it sit , it will start up again, and then happen all over again.
Old 07-26-2013, 10:11 AM
Exclamation What is the best option to do? help please!
okay here i am again, i love my 2004 7 series and i want it fix because it is suppose to be reliable. the problems my car has are:
abs, park, brake lights come on while driving somtimes and then the transmission failsafe turns on. i turn it off for a bit then it all goes away for a while.
a/c blows very low speed on max when those lights start to turn on.
my speakers dont sound as well.\
all this happens when those lights to turn on.
ive changes my battery , had it registerd. (twice)
checked the alternator (twice) it is perfect.
people say it is the ISM, the power module , or the alternator.
what can it be?? ive checked the alternator and it is great.
battery dead
