2006 330ci Low beams not working - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 07-23-2013, 09:54 AM
zhp009 zhp009 is offline
Mein Auto: 330ci
Hi
My 2006 330ci both low beams are not working. If i put the mode in auto, just orange lights are on in day time but when i pull into a dark place the high beams are on directly. If i change the mode to low beams its only orange light just as auto mode. Its happening for both lights.
What might be the issue? I dont think its lights since same thing for both sides. its driving me crazy. Please help
Old 07-23-2013, 01:06 PM
Mein Auto: 330ci
Any advise please ...?
Old 07-23-2013, 01:30 PM
Mein Auto: '04 330Ci 6-speed
Activity slow during the day. Sometimes you just have to wait till people see your post.
You have not told us which headlight option you have on your car.
Are you aware how your lights work normally? On my Bi-xenon adaptive lights, the low beam is only one light on each side. Is that what you mean?
First thing I'd want to check out is the stalk switch.
Old 07-23-2013, 02:35 PM
Mein Auto: 330ci
I recently bought the car and I am not sure what type it is. Attached are pics from auto mode to high beams. Its a zhp model if it helps. Car is in covered parking when i took the pics and auto has headlights on directly( I think its headlights because blue sign on the dash is on)
Please advise. Thanks.
Old 07-23-2013, 06:17 PM
Mein Auto: 330ci
Any help please..?
Old 07-24-2013, 06:03 AM
ahull's Avatar
ahull ahull is offline
Could be your stalk switch as mentioned. Or maybe a fault in your light module. A good scanner that can read the light module errors might help in that case. BMW scanner PA soft or something like that.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 07-24-2013, 07:28 AM
Mein Auto: 330ci
which light will be on for low beams normally ? Are high beams in the picture look good , its the bottom set in the pic.
thanks
Old 07-24-2013, 07:46 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I did angel eyes on an 06 ZHP one time and a few days afterward the lady called me and said her low beam on one side was bad. I figured it was a bad bulb, but it wasn't. So I did the old "reset" trick and it fixed her problem. Unhook your battery in the trunk for 20 minutes. Then short the two cables together with a metal wrench or something that conducts electricity (do NOT short them together while connected to the battery!). It resets the LCM and may resolve your issue for free.
Old 07-24-2013, 08:48 AM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
Your xenons will be on for high beam and low beam... there is a shutter that moves to direct light accordingly... the inside lights are there for DRL and "flash to pass", not high beams... they will also light to compensate for a burned out low beam bulb (or other issue with the lights)
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 07-24-2013, 09:28 AM
Mein Auto: 330ci
i feel so dumb now..the stack is pushed forward and so the high beams. i reset the stalk and lights are back to normal. I though its just the turn knob that controls the beams in bmw unlike other cars. sorry for my ignorance.
Appreciate all your help.
thanks
one more question..what does this do ?
Old 07-24-2013, 09:55 AM
Front Fog Lights... green indicator in lower left of cluster when on
Old 07-24-2013, 10:03 AM
Mein Auto: 330ci
Got it. Thank you
Old 07-24-2013, 11:35 AM
If you have your switch set to Auto and hit the fog button, it will kick on headlights and fogs together... also your headlights will come on when your wipers are on (rain sensor or manual)
Old 07-24-2013, 12:08 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
This is only for cars equipped with bi-xenons. Normal xenons only operate as low beams.
The inner lights ARE high beams. DRLs ARE high beams run at reduced power. Some BMWs have a set of xenon and halogen high beams.
If you flash someone with the inner lights, they are blinding. I doubt they turn on in the event of a low beam failure. That would be illegal and blinding to other drivers.
The halogen inner bulbs are a lower color temperature than the xenon bulbs. Halogens will allow you to see more of the road as the lower color temperature allows more usable output on the road.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 07-24-2013, 12:39 PM
I was speaking in terms of the OP's 2006 coupe... which I know for a fact is bi-xenon...
The inner lights DO come on at reduced power (DRL power I assume) during a low beam bulb failure... mine did this when I lost a xenon low beam bulb...
Old 07-24-2013, 03:28 PM
tturedraider's Avatar
Freedom isn't free!!
this
www.bmwcca.org
Old 07-24-2013, 05:43 PM
Mein Auto: 330ci
Sorry .. Lost in the technical terms.. Can I assume lights are alrite..?
