S S S S S S Struggling to stay alive!!!! - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 07-26-2013, 08:03 PM
thexpbogger thexpbogger is offline
Mein Auto: e28 1987 535i M Spec
G'day FOLKS,
Its been a while since I last had a problem with my KRAUT '87 535i......
YEP!!!!!!!..... got another few doozies that have just appeared and need a little bit of input as to how to fix......
1. My 535i recently farted (backfired) on starting and has since had the continual stalling problem some times as much as 10+ times starting to get the thing into REVERSE with the old 2 feet driving method just to keep the 5h1t alive......
2. About 5-10 minutes or so after starting the KRAUT starts to P155 water from under the engine....... Is it a common practice for this model to route the damn heater hoses under the engine sump right next to the cross member as I be thinking without checking that the hoses over time may have been rubbing and finally popped....
Thanks for your time and enjoy day.....
I know I won't be for a while
Stephen
Old 07-27-2013, 10:05 AM
catso's Avatar
catso catso is offline
catso
Originally Posted by thexpbogger View Post
G'day FOLKS,
Stephen
Have you carefully checked the ignition system? Wires, cap, rotor, coil, plugs, reference and speed sensors? I would start there.
Don't be gormless; get some gorm!
![/I][/FONT]
HTML code is Off
