E36 (1991 - 1999)
Old 07-21-2013, 07:13 PM
dwonda's Avatar
dwonda dwonda is offline
Insane in the membrane!
Mein Auto: 1996 328iS
What glue works well for door panels?
I need to take my door panels off again and reattach all of the plastic attachment points, the last glue I used I thought was going to work, but it didn't stand the test of time. To me it looks like the original glue used is very clear and very hard. Has anyone out there used a truly successful product for this? Thanks.
Old 07-21-2013, 07:32 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
Most epoxies or gorilla glue works.. It's often not the fault of the glue failing after time, but rather the poor quality of prep job was performed on the panel itself before the glue and parts were bonded.
You need to make sure to remove ALL of the previous glue before attempting to repair these fragile parts. It's just like a paint job. Quality comes through prep work.
Old 07-21-2013, 08:09 PM
dwonda's Avatar
Thanks, I'll keep that in mind. Love your pic btw.
Old 07-21-2013, 08:17 PM
Shigeta's Avatar
Old Soul
Thanks! You can check out my work HERE
Old 07-21-2013, 08:22 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
I used Gorilla Glue and it has been a bit over 2 years still holding strong. Used it on the glove box as well and that too is still holding.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 07-21-2013, 09:59 PM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
If you want a permanent fix, you can do what the dealerships used to do: windshield adhesive. Get a tube of the 3M windshield adhesive, put some heat to it (not a lot, just enough to make it nice and soft), get yourself a glue dispenser from Home Desperate, and apply only a small amount. Not a lot, just a small amount. Let set overnight, and permanent fix. Heat or Cold, windows open or closed, this stuff will not come off unless you manually scrub it off.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 07-21-2013, 10:03 PM
dwonda's Avatar
Cool, where can I find 3M windshield adhesive?
Old 07-21-2013, 10:06 PM
hnaz's Avatar
BMW CCA Member
Advanced Auto, Pep Wimps, Autodrone, etc.
My Previous Work:
Old 07-27-2013, 07:28 PM
Smoothops Smoothops is offline
Mein Auto: 1995 BMW 318i Cabriolet
I have to glue my door panels as well and I think I will use the glue that is used to glue mirrors to walls. That black stuff is tough as nails and readily available at Home depot.
Old 07-27-2013, 07:38 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Just in case anyone is thinking of trying it, one glue I know firsthand that does NOT work is glue used with a hot glue gun. It just doesn't bond to the material well, then hardens up and comes off. I thought it would be fine, so I used it the first time around because the videos on YouTube showing how to repair E36 door panels featured a hot glue gun. A few months later everything had come apart again, which meant I had to do it all over. Second time around I used JB Weld, and that stuff is permanent. There are probably numerous glues which will work well for this task. Gorilla glue, though strong, expands as it sets, which can make it messy and poke out in places where you don't want it to.
1998 BMW 328is
1966 Pontiac GTO
Old 07-27-2013, 07:58 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
+1 on the gorilla glue. a little bit of that goes a long way. also, it needs to be applied to a wet surface for best results. not sure why, but i had used it one some other applications and it makes a difference on how it bonds.
the windshield adhesive also would work, as i believe it is a butyl-base material. awesome stufffs.
just make sure the parts are clean and free of debris (*no* glue works with that), and follow directions.
be patient. it will not look good if you rush it. take your time and do it well and you will be rewarded with good results.
df
Old 07-28-2013, 09:14 AM
Nicky3 Nicky3 is offline
Mein Auto: 96 328is
I have always been partial to contact cement.
Old 07-28-2013, 09:22 AM
slow318 slow318 is offline
Mein Auto: e36 318i
I can vouche for Gorilla glue as well. I also lightly dampened the card and the brackets I was gluing back on.....that stuff expands pretty seriously though. My drivers side card nearly disintegrated coming off....damn window regulators.
Old 07-28-2013, 10:21 AM
hnaz's Avatar
BMW CCA Member
Well the reason why I say windshield adhesive is because it can withstand extreme temperatures, expanding and contracting of the vinyl, and pretty much anything. It's why the dealerships used it, plus one can goes a very long way, especially if you are replacing your windshield in the near or distant future. I swear by this stuff, as the BMW techs did way back when the E36's were having these problems in the late 90s.
I used Gorilla Glue once on the door pockets on my 318i, it came right off when I forgot to roll down the windows last summer. Never used it again. But this was my experience. And yes, I let it sit overnight, weight on top of the door pockets as well.
My Previous Work:
Old 07-28-2013, 11:39 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
I prefer quick drying Gorilla Glue (doesn't expand as much). I've also used JB Weld too.
Old 07-28-2013, 03:33 PM
fwman1 fwman1 is offline
DailyDriver
Mein Auto: 1993 325is
What if you want to re-glue the card without removing the door? I've been considering a way to use ratcheting tie down straps to apply even pressure to a template made to match my door card glue points. Of course, I'd provide some protection for the outside of the door as well. When I searched this subject, I found several hits on carpet glue. The windshield adhesive sounds like the best bet to me from what I've found so far. Gorilla glue is great stuff, but one drop where you don't want any glue (in an enclosed area with difficult access) can ruin your day. We use it in my Radio Control Airplane hobby, but cautiously, lol.
Old 07-28-2013, 06:02 PM
jayjaya29's Avatar
Come at ///M3
Mein Auto: 97 M3
You dont need to remove the entire door to glue everything back together. You can pop the interior card apart and glue off the car. Once dry simply reinstall.
Old 07-28-2013, 06:20 PM
DailyDriver
I have had my drivers side off once. It would seem that to get a perfect alignment you'd have to do the glue work and install the card back on the door as it dried. I may have missed them, but I don't recall seeing any key or index marks to aid in aligning the pieces. For example, my pockets have separated from the part that holds the clips...Maybe I've missed something here....I had it off the replace the door check.
Old 07-28-2013, 07:11 PM
jayjaya29's Avatar
Come at ///M3
Mein Auto: 97 M3
I used the original glue residue/marks when gluing everything back together. No problems.
Old 08-09-2013, 01:30 PM
One that seems to work
I just glued my door cards with LaPage construction adhesive, the one that is 8 times stronger than the regular glue. The stuff is thick, requires a lot of force to dispense it with a caulk gun. I used clamps to keep the pieces in place and gave it 24 hours to cure. The bond is extremely strong and the stuff cures to a plastic-like consistency. Just make sure you have your brackets in their perfect place, as it would be hard to detach them. The cards were installed a few days ago and I left the all black car in the sun, to test for temperature resistance. So far the cards are firmly adhered. Hope I help someone with this 10 cents.
Old 11-13-2013, 09:15 PM
janggeungulk janggeungulk is offline
Mein Auto: two wheeler
Gorilla Glue or Rubber glue is the best method I have found when reattaching door parts. Try and get some clamps on it and let set for several hours.
Old 11-13-2013, 10:19 PM
Dunzo Dunzo is offline
Mein Auto: 1995 318ti
Is that what it looks like to actually drive an E36? I wouldn't know, been garaged for 1.5 years now
dwonda's Avatar
I ended up using some sort of epoxy. This time I really took the time to sand EVERY surface to be glue. Which was quite time consuming as a lot of it was scraping off old glue with a chisel to save time. Its been a couple months now, and I recently took off my door panels to replace a couple broken clips that I didn't have at the time I replaced the door panels, and I'm happy to say that everything is still real solidly glued.
My advice in this department (not that anyone is asking) would be:
1. Be careful when removing the two door handle screws and screw covers, it would suck ass to lose them.
2. Don't forget to remove the inside door handle trim before you start reefing on the door panel.
3. Be aware that there are wires connected to the tweeters and side view mirror adjustment on driver side door.
4. Also be aware that the door panel might get hung up on the door lock nub.
4. Remove ALL previous glue, and sand all surfaces to be glued.
5. When using epoxy, pay close attention to how much time you spend mixing it, because it has a huge affect on how quickly the epoxy sets and you need time to spread it, and there isn't an easy way back once you've started.
6. Don't take shortcuts and not replace all the broken plastic clips. This is kind of like a house of cards, if there is weakness in one spot it will cause other spots to prematurely fail, and your repair will last longest when everything is repaired, and at the same time.
7. When mounting the door panel again, it is best to begin at the top with the metal clips along the top edge of the door. Assuming you mounted the plastic piece these clips fit into in the correct position, everything else should go smoothly.
8. It will go even more smoothly if you make sure the plastic clips on either side of the one you are wanting to push in, are already partially in the metal holes on the door. Only paying attention to them one at a time, can cause the clip on either side to break because it might not be aligned to go in the hole since, there is plenty of wiggle room with these plastic clips.
9. When putting the door handle screws back in, use a magnetic screwdriver if possible, because the screw has to travel a certain distance without the guide of your finger to get to the hole, and it would suck to have the screw drop into the door panel you just spent time on snapping back to your door.
10. Enjoy the solid shut of your door, and the quieter ride of your bimmer.
Old 11-13-2013, 10:49 PM
dwonda's Avatar
Wow, I have to admit I never clicked on that link. Those are some beautiful photos, WOW. I love photography, and would love to know more about what you do for a living.
