Old 07-27-2013, 04:40 PM
VAMurph VAMurph is offline
Mein Auto: 2000 528iTouring
How to remove dip stick tube?
Doing my CCV and need some help with how to remove the dip stick tube on my 2000 528it? I took the bolt off the arm securing the dip stick tube and tried pulling up on the it and it won't budge. It will spin. Does this thing screw off or do I need a little more forceful when pull up on it?
Thanks! Any help is appreciated
Old 07-27-2013, 05:02 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Pull harder and add a slight twist to break it loose.
Old 07-27-2013, 06:26 PM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i, 2005 X3
Re: How to remove dip stick tube?
As hard as it is to remove, it's harder to replace. Make sure you a replacement oring on hand. It is very easy to cut. Use oring lube and lube both the oring and the hole.
Sent from my MB855 using BimmerApp mobile app
Old 07-29-2013, 05:02 AM
Boy you were not kidding! It was hard to get back in,especially with the new o ring installed. As you said with plenty of lube it finally went in. Thanks for the responses.
Old 07-31-2013, 11:13 PM
See also:
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
