318i starting trouble - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 07-28-2013, 01:30 AM
rob9 rob9 is offline
Mein Auto: 318i
I've had a problem with my 97 318i (auto) for the past month. One night it wouldn't start, so I called road side assistance and they got it started using some starter fluid.
I made it home and had my mechanic have a look at it and he couldn't find the problem.
Same thing happened a week later, this time I got it towed home. My mechanic replaced the fuel pump and it started working again.
A little over a week later it wouldn't start again, I popped the hood and wiggled a few fuses/relays, turned the key from off-acc a few times and pumped the accelerator while I tried to start it. After dying a few times (turning on then shutting off) I let it crank with the accelerator all the way down and then it fire up and started.
I know it is related to the fuel > engine. From looking around online I think it could be maybe the crankshaft position sensor, but to be honest I have no idea.
At the moment the car will start. I would like to have it fixed before I get stuck far from home again.
Any advice for a car noob?
Old 07-28-2013, 04:42 AM
Mein Auto: 318i
No experience at all
Old 07-28-2013, 05:02 PM
Mein Auto: 318i
Thanks for taking the time to help
Old 07-28-2013, 06:34 PM
Mein Auto: 318i
I'm looking at taking it to a shop at the moment
Old 08-01-2013, 12:02 AM
Mein Auto: 318i
Found someone in my area that only services BMWs, car is there now. Just hoping the problem happens when its there so they can figure out what is causing it
Old 08-05-2013, 05:37 AM
Mein Auto: 318i
No check engine light on.
Got the car back today, they checked for faults and they found EWS faults. It seems when I had a spare key cut (not by BMW), in the process of programming the key, something has gone wrong/come loose so that every now and again the car won't start.
I'm happy because the guy didn't charge me anything although he had the car at his shop for 3 days. I guess now I'll either have a look at trying to find the cause of the problem or a way to bypass the EWS.
Thanks for the help Jon
Old 08-05-2013, 05:57 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Call up Turner Motorsports. Get the color and last three big digits on your DME (405, 413, etc) and ask them for a chip with the EWS delete. It will cost you $299.95 with free shipping.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 08-05-2013, 02:17 PM
Mein Auto: 318i
Thanks I'll look into that
Originally Posted by SCJon View Post
If you have the original key still, just go to BMW and have'em cut the spare. It'll cost about $75-$100 but it's better than a tow. No problem on the help! Glad he didn't charge you either. I'd remember him (mechanic) for anything you need in the future since he passed on the chance to shaft you this time.
I wish. Most places here tried to charge me upwards of $600 for a key with unlock/locking ability and around $400 for a normal key! Thats the reason I got someone else to cut one
Old 09-03-2013, 04:10 PM
Smoothops Smoothops is offline
Mein Auto: 1995 BMW 318i Cabriolet
I'm in a no start situation here too. I took the seats and carpet out to replace rusty floors, then replaced the starter on my 318 automatic tranny. The car started before replacing the starter. I had to take out the intake manifold and all of the connectors for several sensors. I was careful and methodic and managed to replace the starter and re-connect everything. The connectors for the sensors only reach the right connector and the wires had their bends pointing out where they go. The two camfhaft position sensor wires are not the same lenght, so it was easy to see that the longer wire goes to the connector further up in the plastic connector block that goes in the middle of the intake manifold. I'm pretty sure I got all of the connections right. The fuel system was de-pressurized as the fuel rack had to come out. Now the car will not start, it will crank until the cows come home and there is spark on the wires (I also installed new spark plugs), but although it fires sporadically, it will not start. I have some mechanical experience, but never worked on a BMW before, so I'm in a lot of misery I wander if I misconnected the two camshaft position sensors. Would someone give me some pointers?
