E36 (1991 - 1999)
Old 07-28-2013, 10:28 PM
crudstud crudstud is offline
Mein Auto: 1993 318i
rebuilt caliper installation not going well.
1993 318i. I am replacing rotors, calipers and pads on the rear brakes. With my old calipers and probably yours as well, the brake hose doesn't gradually become tight, it suddenly becomes tightened all the way. I installed rebuilt calipers today and when the hose was fully tightened, the calipers were not lined up correctly. Since i can't twist the sturdy brake hose, how do i adjust how i tighten the brake hose so that the caliper lines up and doesn't leak? The last attempt involved using a couple turns with teflon plumbing tape which i was careful not to wrap near the tip of the hose. At the present time, i haven't had time to bleed the system and check to see if that teflon tape trick stopped the brake hose from leaking. Any suggestions? Thank you.
Old 07-29-2013, 03:43 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
brass washers both sides of the fitting...
bolt thur washer hose washer tighten
15486372<-----
Old 07-29-2013, 11:17 AM
the parts guy at my auto store told me what to do. thanks anyone who read this. if interested, i'll tell you what he said.
Old 07-29-2013, 01:32 PM
hornhospital's Avatar
D'oh, You Kids!
Re: rebuilt caliper installation not going well.
Why not just post what he said? That's the purpose of a forum, to post helpful information. Well, that and good naturedly pick on each other.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 07-29-2013, 04:11 PM
Burning2nd's Avatar
Under the lift arms
pick"ing" ing ing.. ing on that end of that sir
(YAHHHH my first grammer nazi win)
15486372<-----
Old 07-29-2013, 04:13 PM
D'oh, You Kids!
Incorrect, sir. Pick, not "picking". I pick on you, not picking on you.
Quotes to live by:
Old 07-29-2013, 04:23 PM
Burning2nd's Avatar
Under the lift arms
damn... here i was thinking i won lol
Im offf.. shower shave bed.. Im beat
15486372<-----
Old 07-29-2013, 05:52 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
GGC BMW CCA #443004
Join the BMW CCA!
Old 07-30-2013, 12:28 PM
ok the parts guy said (as i suspected) that the threads of the brake line do not seal the caliper from leaking, therefore the use of teflon tape will never work. he said to tighten the brake line to the caliper and then apply PB Blaster to the nearest brake line connection back from the caliper and try to loosen it and work the two connections in there so to eliminate the twisting in the brake line which shouldn't be there. in my car, the connection is 20 years old! and it's hard to get to and so i just applied the Blaster and hooked up the caliper with a twist in the line and said screw it. It's working and the job is finished.
