Water Leaking on Rear Trunk Cover. - Bimmerfest - BMW Forums
Old 07-29-2013, 12:49 PM
bigblack06's Avatar
bigblack06 bigblack06 is offline
Mein Auto: BMW X5
Ok, I don't know how best to describe it but when it rains, two-three days in a row water seems to accumulate in the middle of the cover. The problem is I'm not sure where its dripping from as there is no water residue on the ceiling or sides. Anyone else having this problem or seeing this, kinda making me frustrated
BMW X5 2013 35i Premium Black Sapphire Black Nevada Leather Tech Package, Cold Weather Package, Convenience Package, Xenon Headlights, Automatic Highbeams, LED Fogs, LED Interior Lights
2014 Lexus GS 350 F-Sport:http://www.clublexus.com/forums/buil...or-spring.html
"Faster, faster, faster, until the thrill of speed overcomes the fear of death…" – Hunter Thompson
Old 07-29-2013, 01:20 PM
mpabner mpabner is offline
Mein Auto: 2014 Space Metal Gray X3
Have not seen this and it has been raining almost every day for about 4 weeks now.
Old 07-29-2013, 06:52 PM
Liverman's Avatar
Liverman Liverman is offline
Mein Auto: '14 X3 35i / '03 F350
Some ideas:
1. Could be condensate if you have the air con on high and the humidity is high
2. Take paper towels and wipe inside the ceiling, rear windows along any path from the outside to the area where it pools and see where the towel picks up moisture. That will give you a clue as to the path.
Greg
Our BMW: '14 X3 35i, Deep Sea Blue, Black Nevada Leather, Fineline Wave Wood, Satin Aluminum Roof Rails, Premium Pkg, Cold Weather Pkg, Navigation System, Driver Assistance Pkg with ALL them cameras, Premium Sound
Our truck: '03 Ford F350, 7.3L turbo-diesel, 4WD, Lariat package, Lear topper, cow catcher, Blue over Grey (Go Rice!)
"Old Faithful's just a fountain compared to the glory of true love" -- John Prine
Old 07-30-2013, 07:26 AM
bigblack06's Avatar
Mein Auto: BMW X5
Originally Posted by Liverman View Post
Some ideas:
Thanks for the help, I decided to drop it off at the dealership.
Old 07-30-2013, 03:13 PM
guyver626 guyver626 is offline
Mein Auto: x3 35i
Please follow up with us and let us know how it was resolved.
Old 07-31-2013, 09:17 AM
bigblack06's Avatar
Mein Auto: BMW X5
Yep I will keep you all posted.
Old 08-02-2013, 09:00 AM
bigblack06's Avatar
Mein Auto: BMW X5
Ok the update from the dealership is that there was no fix at this time as they could not duplicate the problem. I'm gonna have to take pictures and video in order for them to fix this problem.
Old 08-03-2013, 09:37 AM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
First dry the area completely with a fan to prevent mildew smell and allow a neutral test. I would then lay some cardboard over the area. You need to determine if the water is dripping down or soaking up from the bottom. Drips will show splash patterns on cardboard. Perhaps a run through a touchless car wash would allow you to quickly duplicate the source.
By the way have you ever used high pressure washer wands on your X3?
1979 Porsche Tobacco Metallic 911SC
1996 Porsche Guards Red 993 C4S
2005 Porsche 996 Turbo S
2003 BMW Ti Silver M5
2013 BMW X3 35i Carbon Black M-Sport
Old 08-03-2013, 05:12 PM
BaxTax BaxTax is offline
Mein Auto: 2004-X3
Sorry to hear about your problem. My 2011 did the same thing. Apparently the rubber molding needs to be adjusted, it apparently did not properly seal and needed to be tweaked abit.
Haven't had a problem with it since.
Good luck.
Old 08-03-2013, 08:34 PM
slambmw slambmw is offline
Mein Auto: x3
I had a GM car years ago with a similar problem. The dealership had difficulties locating the problem and after a few months of complaints, it was the wheels spinning in the rain and splashed into a defective underbelly seam that caused the water build up. The rest of the car was dry except this area.
Not sure if you have the same problem, but it is difficult to locate.
Old 09-04-2017, 05:38 PM
MonaLisa MonaLisa is offline
Not Sabine Schmitz...
Mein Auto: BMW X3 35i, Z4M
Old thread, but I've had this same problem recently. After heavy rains (or even carwash) would find a puddle of water on top of the cargo cover. Normally garaged kept, but lately have had to park outside and noticed it happening. Could not for the life of me find where the water was ingressing from, no signs of water on the headliner and the door seal is not damaged or perished. Today, seeing it was about to rain, I pulled the plastic trim off the top interior of the liftgate, where you can access the third brakelight housing, and watched it from inside during the downpour. It appears that the water is leaking in from the left bottom of the third brakelight housing. Before I pull more stuff apart, has anyone seen this before or have any advice? The brakelight assembly is not broken and is functional - is there a gasket in there around the opening I could try replacing before I order a new light assembly? Would trying some silicone sealant be an option? Thoughts, anyone?
....but would sure like to be
Old 09-05-2017, 07:21 AM
SneakyRussian SneakyRussian is offline
Mein Auto: X3, 340i
hi all, I have had a similar issue with my 2011 X3. Dealership was able to diagnose the problem as a worn out/defective rubber seal that belongs to the brake light that is on top of the trunk. The bad news: seal is not sold on its own but only as a part of a light assembly (you all knew this already, not your first year dealing with BMWs), the Good news: the whole thing was $125 with labor.
hope this helps!
