E36 (1991 - 1999)
Old 07-28-2013, 05:36 PM
Slowgan Slowgan is offline
Slowgan
Mein Auto: E36 325is
Exclamation Headlights and fog lights not working
Hello everyone, today I bought a 95 325is and the headlights and fog lights aren't working. The previous owner had angel eye lights on but took them off and put the OEM lights back on. I found a connector and a green/yellow wire as well as a black/green wire that were just sitting there next to the lights. Here is a picture of the connector. I can't seem to find where it should go in.
edit: I checked the headlight wires for power and there wasn't any. Any idea what to check next?
Old 07-29-2013, 08:53 AM
Slowgan
Anyone?
Old 07-29-2013, 11:20 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
I believe that connecter is for the alarm siren. As for the headlights not working the first thing I would check are all the fuses. Then I would check the headlight switch.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 07-29-2013, 11:29 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I'm pretty sure that is a fog light plug.
+1.
1998 BMW 328is
1966 Pontiac GTO
Old 07-29-2013, 11:57 AM
Slowgan
The corner lights are working which makes me think the switch still works. i think the lights worked when he had the other ones in. I checked the fuses and they were fine.
Old 07-29-2013, 12:11 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Are the bulbs good?
When I upgraded to glass lens H1 style headlight, I didn't have the high beam bulbs installed (truthfully, I hadn't purchased them) and this caused my fog lights to not work.
Just trying to start basic here...
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 07-29-2013, 09:34 PM
Slowgan
I did end up finding the passenger side fog light wiring was split. The headlight switch doesn't illuminate so I may pick up a switch at the jy and see if that does the job.
Old 07-29-2013, 11:03 PM
ZeGerman's Avatar
Warm Leatherette
Just FYI: Most headlight switches don't illuminate these days. It's not because the switch itself is broken, but just because the backlight bulb has burned out.
1998 BMW 328is
1966 Pontiac GTO
Old 07-30-2013, 09:38 AM
Slowgan
I got a new bulb for the switch and now the switch illuminates. I also got the head lights and fog lights to work. Thanks guys for the help!
