E30 (1982 - 1993)
Old 09-01-2012, 03:35 PM
Jayboy85 Jayboy85 is offline
Mein Auto: 84 318i
Oil light flicker
I have an 84 318i and my oil light started Blinking. It only blinks when I'm stopped at a light or stop sign when it start driving it turns off. I recently changed the oil oil filter and air filter is also changed the oil pressure switch. Is this something major or a simple fix?
Old 09-01-2012, 04:42 PM
downhiller's Avatar
livin large
oil pump could be goin downhill. it is a 28 year old car with most likely a stock motor.
Old 09-01-2012, 07:50 PM
Mein Auto: 84 318i
Is that something I can do myself or is it better to take it to a shop?
Old 09-02-2012, 03:47 PM
downhiller's Avatar
livin large
just a matter of dropping the oil pan and removing the old pump and putting a new one in.
Old 09-02-2012, 03:49 PM
Mein Auto: 84 318i
Thanks Thank
Thank
Old 09-02-2012, 08:30 PM
downhiller's Avatar
livin large
another thing you can do is do another oil change and throw in a heavier oil. but after thinking more about it, you should look into testing the oil pressure. it could be a bad sensor.
Old 09-02-2012, 09:29 PM
Mein Auto: 84 318i
I just put in a new oil pressure switch. Should the wire that connects to the switch have power?
Old 09-02-2012, 09:36 PM
Mein Auto: 84 318i
A
I changed the oil pressure switch with a new one. How can I check if that's working correctly.?
Should the wire that connects to the oil pressure switch have power?
Old 09-03-2012, 12:31 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Cool Testing for pressure
Buy a "manual" oil pressure gauge
This you then thread into the oil pressure SX socket & see what it reads cold & then hot.
Then if it is the pump (could also be exessive bearing clearance) you can compare readings once swapped out.
I am not saying that you need to make this a permanent fit. I usually stick it under the windscreen wiper blade for testing. It is a good idea to remove the wiper fuse when you do that, as your fellow pedestrians might not see the funny side of being sprayed with hot oil
Ah yes, I do the same with Fuel pressure etc.
These gauges are not expensive...
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 09-03-2012, 05:12 AM
BMWFatherFigure's Avatar
Old School
Those are the tests I would make. Light is only a guide. Switch earths out the globe when oil pressure low.
Old 08-01-2013, 06:15 PM
RemSteele RemSteele is offline
Mein Auto: 87 E30, 88 E28, Jeep 00
Flickering Oil light
Just looking for an outcome. I have a flickering oil light and I'm about to to replace my "rack". If I have it down it would be a good time to drop the oil plan and replace the oil pump
Just looking for an update on your fix if available.
Thanks,
RJ
Old 08-02-2013, 08:11 AM
Old School
Depending on the engine and your skill level you can replace all the crank bearings 'in situ' with the sump off. That and an oil pump change will give you top oil pressure for a few years to come. Run the engine in carefully though as you are bedding the crank to the bearings. Change the oil (not filter) after the first 500 miles.
Current:
E38 Parts Car
Previous:
Old 08-11-2013, 06:16 PM
Update, it appears to be the oil sensor.
