Old 03-28-2013, 12:47 PM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
Well, you sold me. Just ordered one, in black. I was just noticing how ugly the factory cap was last night. My first "mod" on this car! Other than the ultimate cupholder, of course. Guess Im no longer a purist.
2003 540iT M Sport, Black Sapphire Metallic/Black leather, CWP, DSP, rear shades, Climate Comfort windshield
1988 325i 4dr/ 5Sp, Lachssilber Metallic/Black Leather
Old 03-28-2013, 04:24 PM
Originally Posted by Jason5driver View Post
Yes...!
Ever think about making a better/ less complicated Coolant Expansion Tank...?
He could start here:
- Does anyone have a BMW description of HOW the E39 M54 expansion tank actually works?
Diagram courtesy of JimLev on 3/27/2013
Old 04-17-2013, 06:42 PM
bin01123's Avatar
bin01123 bin01123 is offline
Mein Auto: 2013 535i
Just ordered mine too. I just did a complete cooling overhaul at the beginning of the year and I'd like to keep all those parts going as long as I can.
Old 05-22-2013, 08:49 PM
For cross reference, there is a related interesting discussion about the E30 expansion tank cap over here today:
- > E39 (1997 - 2003) > Radiator cap. lower bar?
Old 08-03-2013, 05:51 PM
I was doing some research for someone needing a coolant bleeding DIY, when I ran into this cryptic sentence:
Originally Posted by Aussie528iT View Post
The expansion tank does not have an overflow tube. Coolant is vented through the cap (cap is hollow inside) and any over flowing coolant will leave white stains around the top of the expansion tank. This is normal but leads some people to think their expansion tank is faulty and leaking
So, if the expansion cap is the one-way coolant overflow valve (with a two-way air check valve built in), then what is the purpose of the so-called expansion tank overflow tube that goes from the expansion tank neck to the top of the radiator?
Old 08-04-2013, 09:35 AM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
I thought that as the coolant was heated, it "expanded" and moved from cooling system (radiator) to the expansion tank. After the car is stopped (cools), coolant is drawn back into the radiator.
E28 & E30 expansion tanks have hoses that vent excess coolant to the ground.
Old 08-04-2013, 11:40 AM
Solo12 Solo12 is online now
Mein Auto: e39 530i e28 535is(Sold)
I just saw this discussion today and thought of an earlier post JimLev made about a 1.2 bar cap possibly presenting "a problem with the tu motors running at 108°C on very hot days". Here is the link.
http://forums.bimmerforums.com/forum...light=pressure
This stuff is a bit beyond me and I did not read through this whole thread, but I thought this info may be useful to some of you who understand better. If this is just cluttering up the thread with unrelated info, let me know and I will delete it.
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 08-04-2013, 12:15 PM
If that were true, then there would be no need for the expansion tank cap to vent the coolant, which, clearly, this thread indicates is what happens.
So, that leaves open the question of what the so-called "overflow" hose does.
Maybe that overflow hose might just an air-only equalizer?
Old 08-04-2013, 12:46 PM
gary@germanautosolutions's Avatar
gary@germanautosolutions gary@germanautosolutions is offline
Mein Auto: E39 528i, E60 M5
I can't 100% certain, but from my analysis of the system I've learned the following:
  1. The cap has a blow off valve (OEM calibration of 2.0 bar, GAS calibration of 1.2 bar) that vents excess pressure through passages in the perimeter of the cap.
  2. The cap has a 1-way check valve that allows air to pass in the opposite direction if the expansion tank pressure drops below atmospheric pressure during cool down.
  3. The little hose connecting the top of the radiator to the top of the expansion tank helps to bleed off trapped air in the top of the radiator. I also believe, based on the flow path of that hose through the pressure relief section of the coolant cap, that it also makes sure that an overfilled system will vent excess coolant, and after successive heat cycles, return the coolant levels to normal. In a normal system there is coolant flow through that hose and if the system exceeds the blow off pressure of the cap, the cap will vent both trapped air from the top of the expansion tank and coolant flowing through the little hose. That is why you see coolant residue on the top of the expansion tank if the cap vents. If the cap only vented trapped air from the top of an overfilled expansion tank, the system would over pressurize every time the car was run and the system would remain overfilled.
"I'm a little rascal on my Little Rascal"
- unknown
Old 08-04-2013, 12:56 PM
We removed the manual clutch fan and disconnected the aux fans and tested both an M52 and M54 engine in real time while monitoring system pressures and temperatures up to full overheat temperatures (Gage pegged on full hot and dash warning displaying) and the system never exceeded 1.2 bar of pressure until temperatures exceeding 125 deg C.
Gary
- unknown
Old 08-04-2013, 01:03 PM
This is how almost all US manufactured cars work, and I think it is the simplest and therefor best way to do things. In this method the expansion tank is not pressuerized and has an extremely low failure rate. In most European cars the expansion tank runs at full system pressure and actually has constant coolant flow through it. That is why there is such a high failure rate in this type of system. The problem is compounded by BMW's choice of a 2.0 bar venting pressure for these cars.
Gary
- unknown
Old 08-04-2013, 03:58 PM
Thanks Gary.
I understood everything you said about the pressure cap, but, I just can't make sense out of the hose flow explanation.
However, this thread is clearly all about the pressure cap; so, I just opened a separate thread solely on the topic of how the overflow (aka bypass) hose works, over here:
> E39 (1997 - 2003) > Can someone explain the flow through the expansion tank so-called "overfow" hose?
Old 08-04-2013, 05:27 PM
Since the hose is attached the highest point in the system, and has a bleed screw port, it's the last and best place to bleed any remaining trapped air in the system.
The passage that the hose connects to enters a separate circuit between the two o-rings on the coolant cap. This is the return path of that hose flow into the expansion tank. Since this hose is passing coolant during normal operation, and that coolant passes through the cap just below the pressure relief valve, if the system pressure exceeds the cap rating, when the cap vents that pressure, it will vent both air and coolant.
This system helps to vent any steam first if the system has actually overheated, because the stream will enter the system at the top of the radiator. But also helps to rid the system of excess coolant if the excess pressure is caused by overfilling the expansion tank.
I hope this helps.
Gary
- unknown
Old 08-04-2013, 07:24 PM
I dug up my expansion tank autopsy photos (1) (2) (3) ...
Is this the start of that separate circuit in the expansion tank cap?
Does that hole in the expansion tank cap mate with this hole in the expansion tank neck?
Isn't that expansion tank filler neck hole the same hole that sprays coolant when the engine is off and the aux water pump is running with all the flap valves opened (as part of the normal bleeding procedure)?
ID:	389804   Click image for larger version
Old 11-26-2013, 05:50 PM
For the record, this thread (basically belonging here) was opened today:
> E39 (1997 - 2003) > Possible coolant reservoir cap failure
Old 11-26-2013, 06:37 PM
Studawg's Avatar
Ive had my GAS cap on for almost 15k miles now, all the way through a hot summer in SC and no problems. (Car has 116k now, some of the cooling system parts were replaced years ago, not even sure exactly which or when, although I know the radiator was replaced, and I replaced the fan clutch myself.) I will say the low coolant level warning came on just a couple weeks ago, and when it fully cooled down, I checked it and it was just a little low. I also noticed a little bit of dried coolant around the cap. I went to the dealer and picked up a gallon of coolant, ($24 :0 ) and it took maybe 6 ounces to bring it up to full again. All good. Probably less than 6 more like 4 ounces.
Old 04-03-2014, 06:02 AM
Wooz Wooz is offline
Mein Auto: 2003 530
WOW, this is an incredibly technical post, and after reading the entire post I still dont know if I should change the cap on my 2003 530i with 39K miles. I want to do anything i can to avoid the cooling problems that seem to happen to these cars. So Im hoping to get a clear yes or no answer. To protect my engine should I get the 1.2 bar cap?
Old 04-03-2014, 06:24 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
The only thing the cap does is vent the cooling system when the pressure exceeds the rating of the cap.
Being in Phoenix where it is HOT in the summer you could possibly exceed the rating of a 1.2 bar cap when there is really nothing wrong with your engine or cooling system.
The 2 bar cap will vent at ~29.4 PSI
The 1.4 bar cap at ~20.5 PSI
The 1.2 bar cap at ~17.6 PSI
If you want to change caps I'd go with the 1.4 bar cap.
I have a pressure gauge on my radiator and have seen it at 16 PSI many times here is MA where we rarely get into the high 90's.
Old 04-03-2014, 11:03 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Jim, it probably depends on the car as well. The v8 produces more heat than the i6. Therefore, if you have an v8 maybe the 1.2 bar cap is a tad on the low side.
Since I replaced the cap with the 1.2 bar cap, I never had to top up the coolant, and it's been a while. During the summer months, it can be hot as well here, not as hot as Arizona, but stop-and-go in hot temps will raise the temp of the engine & coolant more than in the cold months, and will cool off slower while driving. The coolant level was still undisturbed.
I wouldn't buy the 1.2 cap for my X5 with the 4.4 engine. That thing runs "normally" about 10° C hotter than my e39, sometimes a few degrees more.
Old 05-22-2014, 07:27 AM
In addition to the heat in Phoenix, I would think that overfilling the expansion tank would have an additional pressure effect.
I just started to wonder if that overfilling-plus-heat exceeding the 2 bar would "only" effect the expansion tank.
Could that excess pressure due to both overfilling_plus_high_heat also crack the plastic radiator?
Old 05-22-2014, 10:52 AM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
I've been a advocate for not doing the lower bar cap because of the increase chance for boil-over. PS can someone post the link to jimlevs test
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 06-26-2014, 03:00 PM
Here is a link to the JimLev results:
http://www.bimmerfest.com/forums/sho...9&postcount=78
See also:
- What is the proper coolant level bobber stick height (1) & what to do when your expansion tank coolant level sensor float bobber stick is MIA missing in action (1) & where to find leaks when the CHECK COOLANT LEVEL is lit on the instrument cluster (1) & where does the coolant level sensor cable go (1) & what is the o-ring size for the coolant level sensor (1) & what is the temperature of the coolant when the thermostat opens under normal conditions (1) & how to modify the cooling system expansion tank 2 bar cap to 1.2 bar to vent at a lower pressure (1) & how to retrofit a coolant level sensor to an E39 that doesn't have it (1) & what is the most often recommended coolant (1) & tricks for efficient flushing (1) bleeding (1) and a coolant refilling DIY (1) & some behr/hella cooling system autopsy photos (1)
Old 08-13-2014, 08:37 AM
This related information was posted today:
> E39 (1997 - 2003) > Will the next person who replaces his expansion tank please cut it open & compare?
Originally Posted by Speedex750 View Post
We've burst yet another tank, the weld between the body and lid sections this time. The car doesn't like sitting stationary on hot days in a motorway hold up.
This failed tank had similar symptoms to one previously, it was bulging and looks like it had been over pressurized and / or too hot. After three failed cheepy tanks I decided to go for a genuine BMW one this time, but not wanting the flash too much cash around I got a second hand one, pre-loved, from a 2000 E46. One of the attractions of this was that it came with a filler cap, the big horseshoe clip and the level sensor in the bottom – more bits to play with. I did notice that the tank had BMW molded into it as well as BMW and a Meile label and seemed better made; the weld between the body and lid was much cleaner, identifying numbers etc molded in - it did feel better quality.
I was pleased to find on delivery (how did we manage pre Ebay?) the cap was a 1.4bar one. I've come up with a theory that maybe our cap wasn't relieving when the engine got hot and the pressure built up. There must be millions of Bimmers that have no problems with a 2bar cap but I can't see the point of having such a high pressure and the 1.4bar cap, presumably functional, suited my theory. Also as part of my theory I wondered whether we'd got too much coolant in. When it was running previously the bobber was at the top and lightly kept on the stop by the coolant level, so maybe a tad over full? I remember before all these problems started that the level could be very low with the bobber right down in the tank – but everything ran OK without overheating.
Comparing the three level sensors we've now got, two genuine BMW and one repro; they're all identical in the reed switch position. The centre of the glass phial of the switch is 2"/50mm up from the flat flange. So our low level light coming on isn't the switch; it's either the magnet in a replacement tank being weaker or the float that carries the magnet can raise a fraction further out of range of the reed switch compared to a genuine BMW tank. Jumping ahead – the replacement tank with the switch it came with doesn't bring up the low level light – success! If you are having low level light problems, especially after replacing your tank, try cutting out the reed switch (carefully, the glass is very delicate) and extend it up about ¼" soldering in with some copper taken from domestic cabling. Make sure it's not too long and won't go fully into the pocket.
So, after fitting new O rings to the two bottom tank connections, it's all been installed. Lubricating the various O ring connections on previous changes has made getting the tank separated and replaced a more reliable smooth process. It's now also got the 1.4bar cap on and we've filled it to the bottom position on the bobber to get a bigger expansion capability in the air space. It seems to be running fine and we're keeping everything crossed we've got a more robust set up this time. One thing we're going to do if stuck in a traffic jam is switch on the air con. Stationary this should bring on the cooling fan in advance of the coolant temperature rising and triggering it.
We'll let you know of further developments.
Old 01-14-2015, 01:48 AM
There was an interesting set of related posts today over here ...
> E39 (1997 - 2003) > Leaking coolant from the expansion tank cap
Originally Posted by mgs View Post
I was thinking about replacing the cap into a lower bar I saw it on this website coz I was planning to order it for my disa valve repair kit. If you got time to check it out.
http://germanautosolutions.com/bmw_s...12_bar_cap.php
Tell me what you think about it
The 2 bar cap does not cause high pressure in the cooling system. Conversely, the 1.4 bar cap could enable boiling in the event of a mild overheat and this will exacerbate the problem. See this post for an explanation.
http://www.bimmerfest.com/forums/sho...88&postcount=7
It is an often repeated misconception that the 2 bar / 30 psi rad cap on our E39s causes high pressure in the cooling system.
Rather, the pressure in the sealed cooling system is entirely a function of temperature. I realize that this is rather counter-intuitive for many. But any thermodymamics text will make the point that in a fixed volume system, pressure is a function of temperature only; it is impossible to increase pressure while temperature is constant or vice versa. Until of course the rad cap opens which limits further pressure increase, but then it's no longer a closed system.
The I6 engine's normal operating temp ~95C & the V8's ~105C are in the range used by every OEM, although the V8 is at the upper end. At 100C, coolant has a pressure ~10 psi. As long as the engine is not overheating, the cooling system temperature, and therefore pressure, is no higher than any other brand.
I can speculate on a reason for BMW to use a 2 bar rad cap. If the engine does run overtemp, one absolutely does not want the coolant to boil. Boiling creates vapour bubbles in the cylinder head which reduce heat transfer from the hot head into the (relatively cooler) coolant and will cause hot (as in extra, very hot) spots that can damage either the head or head gasket. The 2 bar cap prevents boiling until temperature reaches ~140C and perhaps minimizes or avoids permanent damage. Well before 2 bar of pressure is ever reached, the overtemp warning is lit &/or dinging; the driver should have the engine turned off. So think of the 2 bar cap as "idiot protection" not as excess pressure and premature failure.
Before the flames start I don't dispute that:
1 many people suffer premature cooling system failure - but this is not caused by 2 bar / 30 psi pressure at normal operating temperature.
2 NPG+ does run at low, almost zero, pressure compared to the standard ethylene gylcol / water mixture.
Old 01-14-2015, 04:39 AM
pudl's Avatar
pudl pudl is offline
Mein Auto: E39 530dAT 2001
I'll just leave these here. Stolen from engineeringtoolbox.com
