Old 08-03-2013, 10:13 PM
Rosie06330i Rosie06330i is offline
Billy Rose III
Mein Auto: 2006 BMW 330i
Car won't start
2006 330i auto.
Lights turn on, locks work, windows roll up & down, everything electronic works but the car will not start. There are no warning lights showing an issue either. It's like the motor isn't recognizing the push button.. It has started after waiting an hour, and then I drive home and park it, and then it won't start again. And it's not like the ignition just keeps turning. The motor doesn't make a sound. Please let me know your inputs
Old 08-04-2013, 07:08 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Input: Read Codes
Old 08-04-2013, 09:17 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Could be your starter. Or the wiring going to your starter.
I believe there is separate, fused circuit going from the battery distribution panel, to the starter. Have that checked out.
There was a recall for the positive battery connection at the fuse panel but your model year does not fall under this recall. The symptoms are very similar though.
Has the car ever stalled on you?
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 08-04-2013, 12:07 PM
Billy Rose III
Car won't start
@fdriller9
No the car has never stalled on me before. The car doesn't even go into full accessory mode where all the lights on the console turn on and you're able to use the dome lights.
