Old 08-02-2013, 05:00 AM
glenlivet glenlivet is offline
Mein Auto: bmw320d msport coupe
windscreen washer reservoir
My son has a leak at bottom hose fitting on his windscreen washer reservoir ( 2005 330d ).
would like a p/n for the "o" ring/grommet on this hose. He also has a fault with the passenger wing mirror , which no longer dips when reversing.Thanks for any help with these problems.
Old 08-02-2013, 07:24 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Go to realoem. Com for the part no. If its the grommet around the pump these are sold at the parts sites and shouldnt need part no. My mirror does the same. Wondering if the works need some lube like white lithium or similar.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 08-02-2013, 05:17 PM
cvx5832 cvx5832 is online now
Mein Auto: 325Ci, 325Cic, C300
You sure it's the grommet, and not the pump? Over the years I've noticed it's either the windshield washer pump internal seal, or the headlight washer hose that connects to the fitting that connects to the headlight washer pump, that leaks.
Old 08-03-2013, 12:20 AM
Thanks for the input lads , further investigation appears to be necessary in both cases.
Mirror on l/h side does not adjust at all.
Car is not always available as my son uses it daily.
Old 08-03-2013, 12:36 AM
lgr122 lgr122 is offline
There was that kind discussion about mirrors some while ago.
Might bring you some thoughts about what to do.
http://www.bimmerfest.com/forums/sho...297&highlight=
Old 08-03-2013, 02:18 PM
jimvideopro jimvideopro is offline
Mein Auto: 2006 330CiC
A new washer pump is about $20-$25 at oembimmerparts.com. A 1 out of 10 on the difficulty scale.
Old 08-04-2013, 02:25 PM
That seems to be about my level of difficulty and price range I will pursue this course of action. Thanks to all who replied with relevant information.
