Old 08-05-2013, 09:47 AM
md1_61 md1_61 is offline
Mein Auto: 2006 325CI
When I shift into D the car goes to M2
Hey guy I have a 2008 335I. I removed the steering wheel trim to repair the peeling. Fixed it reinstall, test all the buttons and everything worked. Got in the car this morning to go to work and backed out the drive way and put it into drive going down the road I notice the car was in M2. but the shifter was in D. Tried the paddles and it will shift to M1 but that is it, won't shift back up, if I put the floor shifter in M it will not change. I can cut the car off and started it back up place the shifter in d and it show M2 again. I am going home at lunch to check fuses could I have mess something up in the steering wheel? any ideals?
Old 08-05-2013, 10:13 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
At a guess, one of the paddle contacts is being "made" in the pull/upshift position. It thinks you're calling for an upshift immediately upon entering D, but never sees the contact break, so it won't push further than that. At a guess, it will go to M3 when you hit redline.
Not knowing what you did the the wheel makes it hard to diagnose over the net. As a "get me going" fix, I think taking the airbag off again (with ALL appropriate safety actions [battery cable off, etc.]) and unplugging the two connectors for the paddles within the steering wheel would let you (a) drive [with non-functional paddles] and (b) start looking for the closed contact with a VOM. Also check if one of the paddles is jammed in the pulled position.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 08-05-2013, 11:50 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
Mein Auto: 335i
sorry to hear
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
Old 08-05-2013, 12:28 PM
Thanks you lead me in the right direction. The rubber from the steering wheel was pressing on the right paddle switch, not the paddle itself. Had to take the trim off a few times and push the rubber from the wheel down it was very soft. But now all is good again thanks for the insight.
Old 08-05-2013, 01:14 PM
Zooks527's Avatar
Glad to have helped.
