2000 bmw m5 loss of.power? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 07-05-2013, 11:30 AM
Limarxy Limarxy is offline
Mein Auto: 2002 bmw 530 1985 bmw 635
hi my boddy has an 2000 m5 80000miles this car drives as if it has 250hp does not have what it.takes to.be m5
check engine code for carbon buildup
spark plugs are wet in fuel running too.rich
and where oil cap is aways bunch.of.oil.around it as if a back.preasure in.the valves or.something
can any one had this issue?
Old 07-05-2013, 11:37 AM
Re: 2000 bmw m5 loss of.power?
code 0411
secondory air injector incorect flow
what does it mean
Old 07-07-2013, 12:26 AM
ard ard is online now
Resident Curmudgeon
Go to m5board dot com
READ THE FAQS
Become a member.
Old 08-05-2013, 05:07 PM
turned out to be a fuel pressure regulator we were able to.figure out after the car would not idle for more rhen 2 min anf if you press gas pedal engine dies. so i checked preasure test at the regulator showed 10psi
Sent from my SCH-I405 using BimmerApp mobile app
