Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 02-20-2013, 05:33 PM
745-boy 745-boy is offline
Mein Auto: BMW 745i
Seven11 hei what body kit is that the gray 7 series?
Old 02-20-2013, 05:34 PM
Mein Auto: BMW 745i
Originally Posted by Seven11 View Post
u can get a great deal on the 06-08 750's
Old 03-07-2013, 07:27 PM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
So after a couple of days taking my car apart i'm finally to the hood release cable..anyone know what tool i need to reach the inside of the cable through these tiny cutouts?
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
Old 08-02-2013, 07:22 PM
johnriley johnriley is offline
Mein Auto: 2005 745i
Broken Hood Latch cable 05 745i
Thank you so much for your instructions on opening the hood. Had to take out the washer fluid tank as well but then pretty smooth.
Thanks again
Old 08-07-2013, 04:08 PM
sandman83 sandman83 is offline
Mein Auto: 745Li
Is this what needs to be fixed when you feel no tension in the inside hood release
Old 09-06-2013, 07:04 PM
Boing745's Avatar
Boing745 Boing745 is offline
the cleanest1
Mein Auto: E66
I did everything that's in the video and nothing is happening at all, I pulled on the latch from underneath as hard as I could and it didn't budge. Im out of options, please help
Old 12-06-2013, 02:43 PM
LittleJimmy LittleJimmy is offline
Mein Auto: 2003 730d
Hood Bonnet cable failure E65 RHD 730d
I thought it worth posting on my efforts to release the bonnet (hood for you State Siders) on my 2003 Right Hand Drive 730d.
Keif's photos, videos and thread were the key along with pictures of the latch mechanism. Thanks heaps.
The drivers side latch is most easily reached via a ~4" oval shaped hole in a black pressed steel panel below the latch. However on my 7 the hole is filled with the air intake so access is hard.
The panel with the oval hole also has a much smaller oblong hole higher up directly behind the latch. By putting a finger in the oblong hole and reaching down I could move but not release the latch arm into which the cables terminate. You can feel the cable going from the drivers side to passenger side latch as well.
By pressuring the cable through the oblong hole with a screwdriver, or something, you can trip the passenger side latch. Half the job done!
With a combination of finger through the oblong hole and a hook made out of a coat hanger wiggled in from the headlamp side I was able to trip the drivers side latch. Not easy! Study images of the latch mechanism to design the hook which is inserted under the cable bracket on the side of the latch. You can then feel and align the hook on the latch arm with your finger stuck in the oblong hole. Then simultaneously push the latch arm with your finger tip through oblong hole, pull on wire hook and lift and wriggle bonnet. Success at last!
Now for the mistakes I made.
Take notice if the opening mechanism starts clicking or the travel gets longer. You really don't want to do this job.
This is a two person job. One person pulling the cable and the other lifting the bonnet.
The first time it does not open it should be possible to open it by gently pulling on the cable while simultaneously lifting. Make good use of the opportunity should you get it open easily!
Do not force it, as I did, and pull the cable end through the latch arm fitting. New latch required.
As Keif says, the real issue is the plastic bracket in the drivers footwell. Check it and replace it if necessary!
I hope this helps somebody and thanks to the others on here for relaying their triumphs and tribulations.
G
Old 12-15-2013, 08:16 PM
Boing745's Avatar
the cleanest1
Mein Auto: E66
G
I fixed mine, had to replace both locks and now everything works fine. I had to pull my cable with some pliers and pull it really hard for it to open and it did, took me forever and it was a pain but I got it.
Old 01-18-2014, 05:15 PM
JAC2424 JAC2424 is offline
Mein Auto: 2006 BMW 750I
I have a 2006 750 and i am having trouble getting to the latch. Please help.
Kief I am located in Houston TX as well
Old 07-22-2014, 11:05 AM
kelvin2014 kelvin2014 is offline
Mein Auto: bmw 750i
Hi jac2424 im in the same situation the hood doesnt open anymore maybe due to a cable failure, how did you solve the problem I also have a 750 thank you
Old 07-22-2014, 02:04 PM
msantosm msantosm is offline
Mein Auto: 730d
I am exactly the same. Could someone post some pics?
Old 08-06-2014, 07:12 PM
Fetichini Fetichini is offline
Mein Auto: 750Li
Great thread Kief! My 2006 750Li is at the dealership right now for this very problem because I was unsuccessful with releasing the hood on my own.
I got a call back today from them stating all of the cables are good, and the latches under the hood on each side are bad. They quoted me $1050 to fix the latches. I'm going to request the part numbers and get more specifics.
Old 08-06-2014, 09:36 PM
Mein Auto: 730d
I got my non bmw and myself to fix it. It wasn't too hard. Release bumper (I had to release it as someone crashed against it) then took the wippers liquid bottle out and got to the cable. We have opened it and the realease cable can be adjusted (sensitivity) so we didn't had to change anything.
Old 09-07-2014, 07:49 PM
Pimpin745 Pimpin745 is offline
Mein Auto:
Damn keif where u located I need some help with my 7 sounds like your a Beast with fixing on then 7s I don't know anything lbvs
Old 01-24-2015, 10:23 AM
r100hys r100hys is offline
Mein Auto: 2004 745LI
Help needed!
I know this thread is old but im loosing the will to live!
RHD 2004 745LI
So i can pop centre latch, i can pop passenger latch but cant pop drivers side nor can i get anywhere near it. what do i do?
I've sold the car and need to check fluids but i cant open the bonnet. ive tried taking the handle off inside the car and pulling on the cable but nothing happens.
Old 02-21-2015, 06:33 PM
Graham E39 528i's Avatar
Graham E39 528i Graham E39 528i is offline
Conservative Modder
Send a message via Yahoo to Graham E39 528i
Mein Auto: BMW 760Li (2008)
I'm having a big issue with a failed hood release mechanism. I am very appreciative Keif of your fine instruction & photography.
My car is a 2008 760Li with about 2500 miles on it (honest!, ultimate driving machine my ass). I took off all the plastic parts underneath the engine and there is nowhere I can wriggle an arm up to lever anything. I can't even see a cable mechanism.
Should I follow your lead on investigating this, by taking apart the cabin lever first? Or should I remove the white plastic tank (on the driver's side) and pursue a path up to the hood releases?
Graham
OEM BBS Style 42 (18x9) | Conti DW 245/40-18 | KraftStab Strut Bar | Bilstein Sports | Vogtland Springs | Eibach Sway Bars | Mason Sway Bar Links | e36 M3 Steering Wheel | Biarritz Blue Metallic | Nimble & Graceful
Portland BMW Club Member
Old 04-27-2015, 01:55 PM
Kingair001 Kingair001 is offline
Mein Auto: 750Li
Just replaced my hood / bonnet cables this morning together with a buddy of mine
Couldn't pop the hood anymore . . .
So I ordered the 3 cables and the mechanism before we started . . . just in case off . . .
Total was less than 60 bucks
Took us less than an hour to get it fixed !
And I put a lot of WD40 on the latches . . .
ID:	506311   Click image for larger version
ID:	506312   Click image for larger version
ID:	506313   Click image for larger version
Old 06-16-2015, 07:12 PM
skyebaby22 skyebaby22 is offline
Mein Auto: '93 BMW 325; '03 745
Originally Posted by Keif View Post
Two latches, one for each side. You should see the cable leading into the latch on the side of the car that the hood release lever is on. Unsure about any differences due to it being RHD. Will try to take a picture in a bit.
Hi Keif, I've read through the thread and I cannot find the info for opening the hood when the lever "inside" the car will not prop up the hood. Can I remove the lever and brackets inside the car on the drivers side floorboard to get to the cable?
Thanks for your time.
Old 10-10-2015, 12:12 PM
robbzdoz robbzdoz is offline
Mein Auto: Bmw 750Li 2006
Thank you Bro your videos are going to do it for Me I just know it.. Hood won't pop open inside car is OK thanks again for your Kool Pictures.. when I can get a jack I Know My hood will open I so happy I can have a piece of mind. Cause all that grill stuff lol You know can't be done on My 2006 750Li. May you have a blessed day Keif.
Old 11-11-2015, 05:04 PM
Susanna08 Susanna08 is offline
Mein Auto: Bmw 750LI
Does this also apply to the 750ok
Old 06-17-2016, 05:59 PM
chemiztry chemiztry is offline
Mein Auto: 2005 BMW 745li
2005 745li Hood Release Cable Help
Hi,
My hood release cable had broken on the driver side rear, so I purchased all 3 new cables and found that the 2 on the driver side was broken and replaced them. However upon putting it back together, using the handle release it is still not opening.
It will open when I pull the cable inside with some vice grips so it appears that the handle is not pulling the cable far enough to pop the hood open.
Any advice would be greatly appreciated.
Thanks,
chemiZtry
cable, hood, latch, manual, release
HTML code is Off
