Old 06-17-2013, 10:26 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by london_2012 View Post
No papa, I haven't tried removing any thing, besides i wouldnt know which one is the code for cdc. do I have I have to remove it?If so what do I have to do? Please help me with some steps from scratch incase I'm doing it wrong, i Really appreciate your help.
go into VO delete the CDC Option from the VO . then write to the
CAS & also the LMA . After that go back & add the +naux .
after you have +naux in the VO , go back & add the CDC back
to the VO .
Then all you need to do is the coding to the MMI .
Old 06-18-2013, 11:36 AM
london_2012 london_2012 is offline
Mein Auto: 7 series
to the VO .
Papa thank you so much for taken time reading and replying to me and every one here, we really appreciate every second of your time, I'm just a little confused about deleting the CDC from VO. To start with all my values in the VO are given as $ followed by 3 digits, so I don't even know which value represents the CDC, can I ask why it's necessary to delete CDC ?
Also second important question, you said write to CAS and LMA, can I ask what to write to them?
Thank you ever so much, hopefully with your help I will get to some where with this installation after been trying it for 4 months now!!
Old 06-18-2013, 02:04 PM
PAPER's Avatar
CRISP & CLEAN
Ok now I have to suggest you find someone in your
area that can do the coding for you .
No disrespect but if you don't understand what I am
telling you to do , Then you should definitely not be
trying to code your car .
AS for why delete CDC then put it back in the VO , I
was given that info by a Master tech who claims for
some reason the CDC option disrupts things when
adding to VO . I have not personally done it because
I have not had any problems when adding to or deleting
from the VO .
Old 06-20-2013, 05:53 AM
7SeriesFilm 7SeriesFilm is offline
Mein Auto: 745
after researching I found the cheapest way to install av is with the dension gateway 500. Selling for $230 on amazon. I think that's the way I'm going with mine.
Old 06-27-2013, 07:48 AM
omar 18st omar 18st is offline
Mein Auto: 2002 745i
paper how much 4 the aux cable? i need 1 asap
Old 07-20-2013, 01:50 AM
Salmantheman Salmantheman is offline
Ms. AWesome ;)
Mein Auto: E66
THANKS PAPER ... All sent with my AUX... thanks a zillion
-Hood Cable changed (thank you Keif),
-Idrive issue with Fm Module (thank you PAPER),
-Added Facelift ASK and MMI Dashsoft (Thank you ACE)
-Battery, Alternator, Compressor, Front Fan, Silly repainted, L7 Restored and the list goes on
Old 07-27-2013, 11:39 AM
Crowgasm Crowgasm is offline
Mein Auto: 2005 BMW 745i
Hi there,
did you ever get this set up? I'm looking at some Dension products as a solution for this (2005 745i with no aux port) and they look viable. I wouldn't want to install it myself so I'm curious if anyone here has and how easy/hard it was and how well it works.
Old 08-22-2013, 01:56 AM
OMOYANGHEDE OMOYANGHEDE is offline
Mein Auto: bmw
what's the price for the NAV. DVD?
Old 08-22-2013, 07:24 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
"If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM "Paper" for price .
Or if you Need an AUX Plug for your car hit "Paper" up "
this is from his signature
Old 08-23-2013, 05:23 AM
Tenn's Avatar
Tenn Tenn is offline
Mein Auto: 2007 BMW 750Li
Whats the $ price including shipping for my '07 750Li and what method of payment do you require? My zip code is 37043.
Thanks,
Tenn
Old 09-13-2013, 03:40 PM
Mr.Propcio Mr.Propcio is offline
Mein Auto: BMW 745i
FM radio and speakers not working
Hi.
I just bought BMW 745i and from the start the radio is not working on FM only(CD, AM works) also the speakers are not working some at all ore wary wary quiet the only one working properly is the front wright.
Can you guys know the reasons for this problem?!!!
Sorry and rear wright window is not working, I can hire the click after pressing the button but nothing is happening!
Old 09-13-2013, 03:42 PM
Mein Auto: BMW 745i
Sorry I wright this in the wrong place, first timer
Old 09-13-2013, 09:33 PM
PAPER's Avatar
CRISP & CLEAN
Re: Correct & complete aux install
Originally Posted by Mr.Propcio View Post
Hi.
I don't know why you would come in this
topic with your problem ???
It sounds like you need a new Ask unit &
Logic 7
Old 09-15-2013, 02:37 AM
eibbed eibbed is offline
Mein Auto: bmw 760li
I have a 2006 is there a way of telling if you have the upgraded MMI ?
Old 09-16-2013, 06:16 PM
cisco150 cisco150 is offline
Mein Auto: 02 745I
If its an 06 you have the new ask and mmi unit
Old 09-17-2013, 02:24 PM
Is there a definitive way of telling though my MMI doesn't have the AUX option at all displayed and I understand some 06's didn't come with upgraded MMI or ASK.
Old 10-17-2013, 08:23 PM
Eute Eute is offline
Mein Auto: BMW 745i, X5
Simple Aux without MMI integration?
Paper--with your helpI have determined that my January 2002 E65 does not have the Facelift Ask and MMI required to have a fully integrated Aux working off the iDrive MMI and the volume controls. I would be satisfied, forgive me, with a simple input to play my iPhone through the amp and speakers. Did your prior Aux work-around work that way before you apparently upgraded to the Facelift Ask/MMI fully coded to the display? I ordered my E65 new after seeing it displayed at the 2002 Detroit Auto Show and it was one of the first delivered to our area. It is still going strong with 120K, a third party coolant pipe kit, one new hydraulic stabilizer bar and an OEM Bluetooth update. I appreciated your Aux videos.
Thank you,
Eute
Old 11-01-2013, 08:43 AM
louis maeshiro louis maeshiro is offline
Mein Auto: 05.E66 760Li
Thank you for the other day.
I haven't solved yet, VO +NAUX add, I can't use AUX.
Isn't match the ask unit?
Is everyone change the new ask?
Please tell me ask unit parts No. which works AUX with your car.
I am searching ask unit with MODE & FM. AM. Button which matches AUX.
Old 11-01-2013, 03:32 PM
PAPER's Avatar
CRISP & CLEAN
I believe you have been told multiple times on
This site & on the YouTube channel that
You need a FaceLift Ask unit .
Sent from my C6833 using BimmerApp mobile app
Old 11-04-2013, 04:33 PM
lilgee620 lilgee620 is offline
Mein Auto: bmw 745i
Hey I was wondering could you give me some input on a aux install thanks
Sent from my SPH-L720 using BimmerApp mobile app
Old 11-04-2013, 05:07 PM
PAPER's Avatar
CRISP & CLEAN
What kind of input ?
Old 11-05-2013, 11:42 PM
BMW_745Li BMW_745Li is offline
Mein Auto: 2003 745Li
Hi Papper
Do you have Facelift MMI and Facelift Ask for sale?
Old 11-05-2013, 11:46 PM
PAPER's Avatar
CRISP & CLEAN
Originally Posted by BMW_745Li View Post
Hi Papper
Yes I do .
Old 11-06-2013, 11:52 AM
Yes I do .
Hi Papper...
Im interested in purchasing the facelift MMI and facelift ASK unit
Can you please provide me with prices also if you plese make it clear for me wich kinds of those modules are good to go with for example ASK unit manufactured 13-06 is good while 02-06 is not.
Old 11-06-2013, 11:53 AM
Hi Papper...
Oh if u need to PM me my email is m.shehranian@gmail.com
