Old 08-26-2013, 12:46 PM
Vanessa Graw Vanessa Graw is offline
Vanessa Graw
Mein Auto: BMW 645
Breaks/Rotors question
I need new pads and rotors, Ive gone through 2 sets of pads in 1 year (both front and back). I dont drive alot, so I know the mechanics are putting in the worse pads that dont last. They quoted me $350 for new pads and rotors this time around. I just replaced my rotors less then 2 years ago too. Some of this work is done by the dealership and some not. Ive spent thousands of $'s on my car this year already.
My friend has a mechanic thats been working on his cars for a while and does a great job. You buy the parts and bring them to him and he does the work, so you know what your getting. You basically pay the same price a different mechanic would charge you but are getting the best parts.
So my question is, can anyone suggest the best pads and rotors? Decently priced & whatnot.
22" wheels, not sure if that matters.
[IMG][/IMG]
Old 08-26-2013, 03:22 PM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I used Akibono ceramics to cut back on the break dust with Zimmerman rotors (to cut cost). I like them quite a bit. Yorgi has a great break DIY that he makes some recommendations in.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 08-26-2013, 04:17 PM
As Mulchman says, Yorgi has some great advice for pads. Since he is a guy who tracks cars his recommendations are excellent and outline what you need depending on what you are looking for:
http://www.bimmerfest.com/forums/sho...ght=brake+pads
Here are some other search results, there is a lot to read if you just keep searching, personally I do not have any input since I have had the same set of pads and rotors for the last 25,000 miles and 4 years:
http://www.bimmerfest.com/forums/sea...rchid=21094720
Old 08-26-2013, 06:55 PM
Vanessa Graw
Mein Auto: BMW 645
Awesome, I have alot to read. Ill be back in a day or 2 hopefully with no more questions. Thanks!
Old 08-26-2013, 06:59 PM
Ask away, everyone will be glad to help!
Old 08-27-2013, 12:19 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
+1 for Mulchman.
Akebono brake pads are an excellent choice!
Once a 6'er, always a 6'er.
Old 08-27-2013, 04:07 AM
castercorey castercorey is offline
Mein Auto: 645ci
I use EBC red stuff for my brakes.
A perissodactyl ungulate may be propelled toward a body of aqueous fluid, but such ungulate cannot be compelled or forcibly induced to imbibe such fluid.
Old 08-27-2013, 05:52 PM
Yorgi's Avatar
Yorgi Yorgi is offline
If you do not drive aggressively or if you want zero brake dust the I would recommend Akebono pads. Here are some of my recommendations...
Pads:
Akebono - zero dust, great price, slightly less braking power compared to OEM ($85 + $71)
StopTech Street Performance - very low dust, great price, similar braking power to OEM, much higher max temp before fade compared to OEM ($90 + $70)
OEM - very dusty, OK price, very good cold and hot bite ($119 + $107)
Hawk HPS - medium dust, good price, almost race pad stopping performance - more bite than OEM ($109 + $100)
Rotors:
OEM - the best by far but not cheap - $175 x2 + $143 x2
StopTech Cryo treated - next best after OEM (cryo will last longer) - $104 x2 + $98 x2
StopTech standard - will not last as long as cryo but cost less - $84 x2 + $78 x2
Centric - made by parent company of StopTech - better than other no-name budget rotors - $80 x2 + $71 x2
All of these parts can be bought from Tirerack. OEM pad prices are from Tischer - getbmwparts.com
I would look into why you are going though pads and rotors so rapidly considering you do low mileage. You either have a problem with your calipers sticking or your driving style is burning up the brakes (ie braking too early and not braking hard enough) Rotors should last for two sets of pads and pads should last 3+ years minimum if you are doing low mileage.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-31-2013, 03:42 PM
Vanessa Graw
Mein Auto: BMW 645
Hey guys thanks so much for all the brake advice. I took some of it and purchased the akebono front brake pads. Soooo I picked them up today (from Pep Boys) and inside of the box is 4. Did they make a mistake and just toss some rear pads in there too? Which ones are the front ones? I took a photo of each one (front and back).
Any help would be great.
Old 08-31-2013, 04:17 PM
ttuite ttuite is offline
Mein Auto: 650I cabrio
Two pads per wheel. Did you buy a new brake sensor? If it is not worn through, getting the old one out and re-using it is possible if you are careful. Spray some lubricant like WD40 on the sensor clip that is on the old pad and see it it will wiggle free. Follow Yorgi's PDF step by step and you will be proud of yourself when it is done.
Have fun
