Multiple codes after oil service reset - Bimmerfest - BMW Forums
Old 08-28-2013, 08:18 PM
mikewerks's Avatar
mikewerks mikewerks is offline
Mein Auto: 02' 745i
97' 540i - Cant catch a break today...... Did the oil and inspection light reset using the proper reset tool and got these fault codes. Please note knock sensor codes were present previous..
P 1385 knock sensor code for cylinder 7 and 8
P 0330 Knock sensor Circuit Malfunction on Bank 2
P 1384 Knock Sensor 3 Circuit
P 0325 Knock sensor 1 Circuit
P 0135 Oxygen sensor bank 1
P 0155 Oxygen sensor bank2
P 1186 Oxygen heater circuit bank 1 sensor 2
P 1187 Oxygen heater circuit bank 2 sensor 2
P 0130 O2 sensor circuit
P 0150 O2 sensor circuit
P 0156 rear O2 sensor code..
Unbelievable! I did have Knock sensor codes on before this and they are included in the list of shame. I was going to replace the knock sensors this weekend and now possibly the PCM? I did reset a few times but all codes came back in short order... I assume no way to "reset" the PCM? Any guidance would be GREATLY appreciated.
How much do I write the cheque for this time?
Old 08-28-2013, 08:27 PM
mikewerks's Avatar
Mein Auto: 02' 745i
Neglected to mention car still starts/runs good and power seems not to be affected..
Old 08-29-2013, 04:18 PM
mikewerks's Avatar
Mein Auto: 02' 745i
Follow up: Found the issue it was the 20 AMP O2 sensor fuse located in the E-Box. Replaced fuse and all returned to normal. Now to do the knock sensors, timing chain and guides next weekend.
