bmw 635csi engine rebuild in progress - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 02-17-2012, 10:34 PM
Limarxy Limarxy is offline
Mein Auto: 2002 bmw 530 1985 bmw 635
i started it as a replasing a oil pan gasket and $2000 later in just parts i rebuilding the motor.
new parts are
fuel filter
oil filter
belts
all gaskets
vacumm tubes
starter
alternator
coil
distributor cap and rotor
sparkplug wires
sparkplugs
air mass senor
waterpump
clutch fan
etc
suspension
all new german arm controls
bilstein struts with H&R springs
all new brakes
cross drilled rotors
short shifter
wheels
are new 19x8.5 front mire II and 19x9.5 rears wraped with federal all season tires
stereo system
pioneer dvd/nav with infinity speakers and lagacy amp and 10"sub with an amp as well
new seats are comming soon and new paint job in 1 month. Click image for larger version
Old 02-17-2012, 10:36 PM
putting the head back tomorrow. cross my finngers and hope i set the block and head in right way so i dont srew up the valves or timing.
more pic comming tomorrow
should i upgrade the exhaust?
Old 02-18-2012, 07:41 AM
coolcars coolcars is offline
Mein Auto: 633 bmw 1984
nice very nice.....Iwould change the exhaust
Old 02-18-2012, 08:44 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Smile Engine rebuild
As a long time specialist on BMW 635 csi engines I must strongly advise you to do the following mod to save premature camshaft wear, Remove both of the camshaft oil spray bar banjo's and get a local machine shop to mill a 2 mm groove around the area where the three oil outlet holes are because the problem is is that not all of the outlet holes can or will line up with the axis of the camshaft spray bar so it will starve parts of the camshaft of oil, Please believe me a handfull of $ will save you an expensive camshaft replacement, I've carried out this mod hundreds of times on BMW m20 and m30 engines, Peter.
Old 08-29-2013, 12:48 PM
warshp warshp is offline
Mein Auto: 1985 635CSI
Oil leaking out of oil pan on my 1985 635csi
I found a super nice 635csi that had been siting for 10 years and bought it for 500.00, It had a broken fuel line and after replacement it started right up. A little lifter noise but other than that it runs great, I repalced or repaired all that was worng like lights and rotors and brakes. I finally finished installing a universial temp gage last night and took it for a test drive. Drove great but when I got home oil was running out of the gasket of the oil pan. Any ideas on what I should do. Can you get the oil pan out with out removing the engine. Do you think I should run a engine flush through and change oil and add a seal swelling addative to see if I can get it to stop. It runs so good I hate to pull the motor at this point. Thanks for any help.
Old 08-29-2013, 08:05 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
OP: I really admire your diligence and perseverance.
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 08-29-2013, 10:44 PM
Re: bmw 635csi engine rebuild in progress
i would do a top end wich will require a new valve cover gasket and vavle adjusment you can easy diy just set the valve the manuf. spesf. check a the vacume tubes and harmonica rubber intake tube for cracks send us some pics
Sent from my SCH-I405 using BimmerApp mobile app
Old 08-29-2013, 11:11 PM
HTML code is Off
