Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - Current)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 08-22-2013, 07:11 PM
ShakeDaddy's Avatar
ShakeDaddy ShakeDaddy is online now
Mein Auto: 2013 650i Coupe
Added BMS Stage I
Installed the BMS Stage I tune today on my 650i.
After lot's of DD and plenty of posts from the guys on the F10 5'er site it was obviously the best choice best for my N63Tu.
I'll be honest I felt more comfortable with these guys to install than me. We have a great speed shop here in Phx Metro called VividRacing, check it out: http://www.vividracing.com/catalog/p...d9vi185tgp61g6
There are 4 or 5 informal thread regaring the BMS Tune here on the Fest in the F10 section.
I'll post more a little later. SD
2013 650i Coupe N63TU
Original Owner-Delivered 10/2012
M Sport/Imola Red
Individual Leather/Opal Merino
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Summer Tires Only//RFT No Mas\\
Hankook Ventus V12 Evo2
Old 08-23-2013, 05:37 AM
Tuesday Tuesday is offline
Mein Auto: .
I have been real curious how the TU would react to the stage 1 - looking forward to reading your opinions.
Old 08-24-2013, 01:51 PM
ShakeDaddy's Avatar
BMS Review
Well Iíve had a few days with the BMS Stage I Tune on my N63Tu 2013 engine that comes along stock at 445hp/480hp.
I didnít add this on without a lot of research and confirmation. The BMS Stage 1 ECU Tune is a relatively simple install snapping on your left and right TMAP Sensors. This system remaps boost, timing and fueling to increase hp/tq and reduce turbo lag.
I had been waiting to for Dinan to come out with their Stage II for my motor and in the meantime kept reading about the very positive reviews of the BMS product. With the guys on the 5íer and 7íer boards, the reviews have not been favorable.
First start up after install and it was obvious this already strong engine was even more of an animal. Power is across the board, low end torque is increase and high end hp is evident immediately. There is no messing around with full throttle in Sport Plus, best to be ready for an active rear end. AND donít do a full throttle stomp going around a corner unless you have plenty of room to slide and know exactly what your doing. I canít tell you exactly how much more hp/tq Iím now getting with the BMS and the exact numbers really doesnít matter to me or I would have done a prior Dyno. To guess itís 475hp/525tq and the butt meter is definitely increased.
Iím not really interested in maxxing this car out and creating issues with related components, just looking for a sweet bump in hp/tq and BMS delivers all day.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 08-25-2013, 08:56 AM
badblack550xi's Avatar
badblack550xi badblack550xi is offline
Chilling
Mein Auto: F10 2013 550i xdrive
good write up =D
2013 F10 550ixdrive Carbon black metalic / BMS Stage 2 / AR Down Pipes/ 3" Custom Exhaust/ M5 mufflers and diffuser. WR 11.895 @118.69
Old 08-25-2013, 07:05 PM
ShakeDaddy's Avatar
Originally Posted by badblack550xi View Post
good write up =D
Yes and did I mention BMS over Dinan saves you 3+ LARGE.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 08-30-2013, 02:31 AM
Ace535i's Avatar
Ace535i Ace535i is offline
Mein Auto: I'm still dreaming....
Can you still get the BMW extended warranty with the mod?
Old 08-30-2013, 06:38 AM
Chilling
tested a stock 2013 650xi 4door coupe 0-60 was 4.9 in a fairly humid weather that motor is strong next he will get BMS stage 1 and will be owning me 0-60 most likely.
Old 09-01-2013, 10:05 AM
mclaren's Avatar
mclaren mclaren is offline
Chairman of the Bored
Mein Auto: 2014 M5
I think the 3k is warranty related. I'm thinking about doing this, I gather you had a speed shop do your install. What did they charge ? I read the installation guide and it looks like it's something I could do. Which harness is required A or B ? As you said this looks perfect for a nice butt boost without stressing anything.
Old 09-01-2013, 12:03 PM
ShakeDaddy's Avatar
It's harness B for the 2013 engine and the install was 30 minutes of shop labor. Need to learn how to disengage if the need should arise.
This week remove the charcoal filters and was also dropping in high flow airfilters by BMC, but they sent the wrong size so their going in next week. The removal of the extra charcoal filter is a must since they are used in North America only.
As you say the BMS is really a great butt boost mod for extra hp/tq to our engines. Remaps timing, fuel and adds 2.5lbs of boost. The difference is dramatic.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 09-06-2013, 01:19 AM
jsherm jsherm is offline
Mein Auto: 650i
Added BMS Stage I
Where did you buy filters from?
And this is the first I've heard of the charcoal filters...
Just ordered the stage 1 w/ B harness!
Old 09-06-2013, 10:13 AM
ShakeDaddy's Avatar
$195 for the pair not each. They are pre-oiled and are for the life of the car, washable. First class construction. 50% more airflow and 30% particle filtration improvement. Remove the Charcoal filters when putting in the BMC Flat Panels. Goes great with the BMS Stage I.
http://www.vividracing.com/catalog/2...150714441.html
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 09-06-2013, 11:48 AM
Mein Auto: 650i
Added BMS Stage I
Nice!
And they had $10 off coupon code to make it $185!
Old 09-06-2013, 11:54 AM
Mein Auto: 650i
Added BMS Stage I
BTW did the filters change the sound of the car? I already have Megan racing mufflers on the car.
Old 09-06-2013, 11:57 AM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2012 650 Coupe
Added BMS Stage I
And any noticeable performance gain?
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 09-06-2013, 03:45 PM
ShakeDaddy's Avatar
Last week Vivid ordered the wrong filters so all I did was have the charcoals removed and yes there was nice pop under high rpm shifting from the engine compartment. Next week the filters will be dropped in and I'll write a comment or two.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 09-06-2013, 04:05 PM
ShakeDaddy's Avatar
..........And as we know this is not a Giant Mod but without a doubt brings more air into the intake.
I've read that the filters alone will create 8-10hp and also removing the charcoal filters will probably give a little bump too.
Bottom line is the N63 motor is restricted with 2 filters stacked on top of each other and freeing that air up can only be a good thing.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 09-06-2013, 08:40 PM
Mein Auto: .
So you did feel like you noticed a difference with removing the charcoal filters? I'm inspired to give this a shot.
Old 09-21-2013, 07:19 AM
Mein Auto: 650i
So I may have screwed up??? I ordered the filters mentioned above (BMC Flat Panel Replacement Filter BMW M6 13-14) but my car isn't an M series... I figured the intake filters were the same, guess not. These defiantly don't fit a 2013 650i non M.
Old 09-21-2013, 11:14 AM
ShakeDaddy's Avatar
I had the same issue, come to find out BMC does not make the pre-oiled drop in filters for the 650i but only make them for the M6. K&N also does not make one for our cars so we are stuck for now with the paper filters. I would really like to go with the washables when someone make them for our cars. I got to see the BMC filter for the M6 and it is a high quality product. Just wish they made one for our cars. Would think this will probably come out soon.
Now on the charcoal filters they are stacked with the air filters only on the North American 650i's and do create less air for these engines. They are a polution device when the 650i is shut off during cool down. Definitely remove them for improved air flow and performance.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 09-25-2013, 03:07 PM
Mein Auto: 650i
Added BMS Stage I
I swear with the BMS, no charcoal filter and Megan exhaust I got to be near 500hp, right? Basically 55hp bump over stock...
Old 09-25-2013, 03:44 PM
ShakeDaddy's Avatar
What?? You found the BMS filters for our 650i's?? I was told by Vivid Racing they are not manufactured for our engines, only the M6. Where did you find them?
How are you liking the Megan axle back's?? Would love to hear.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 10-09-2013, 12:03 PM
Mein Auto: 650i
Added BMS Stage I
Any chance my BMS is causing a vibration (see other thread I posted) when going up hill?
Old 10-09-2013, 02:32 PM
ShakeDaddy's Avatar
My best guess is this vibration is caused by something besides the BMS Tune. Never had anything like your describing.
M Sport/Imola Red
20Ē 373 Wheels
Full LED Lighting
BMS Stage 1
96 Octane
VR Power Pedal
Dinan Shockware
M6 Spoiler
Old 10-09-2013, 03:42 PM
Mein Auto: 650i
That was my thought too... The vibe seems to be in the front middle of the passenger compartment.. in that I don't feel like it's one tire or anything. I noticed it a couple days ago and it's gotten more pronounced but still intermittent. All tires are ok on pressure, I put in 93 gas, so just trying to narrow it down. I am going out of town for 4 days, then will check it out when I get back I guess!
