The X5 SAV Forum
Old 03-21-2009, 05:25 PM
01x5 01x5 is offline
2001 X5
Mein Auto: bmw x5
Question Window problem!!
Hello...My passenger side window seems to be makin a loud noise when it gets half way down and gets stuck when its on the way back up half way i have to use my hand n help it back up! Anyone ever have this problem? Thanks
Old 03-22-2009, 09:40 PM
Bigfoot's Avatar
Bigfoot Bigfoot is offline
Professional Lurker
Mein Auto: 2011 BMW Z4 35is
Cool
This is a VERY common problem. Your window regulator will need to be replaced.
My advice: Once you are out of warranty, use your windows only if absolutely necessary.
Old 03-23-2009, 03:31 PM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
+1, for some reason BMW uses lousy window regulator suppliers. I have heard that M-B also has the problem. Perhaps, with climate control the use of windows is getting obsolete LOL!
Old 08-20-2013, 10:59 PM
edsx5 edsx5 is offline
Mein Auto: 2003 bmw-x5 4.4i
Did you have window tint removed recently? I did on mine and I could not clean the adhesive left behind by the film in the window channel. The window would get stuck and make a loud pop as it got loose from the adhesive everytime I rolled the window up or down. Check for obstructions in the window channel.
Old 08-26-2013, 02:10 AM
leejim leejim is offline
Mein Auto: 2005 X5 4.4 V8
Window regulator failures.
Hi for what its worth, I have never had a regulator or motor failure on my X5 2005 or any of the Rental cars I service. I spray all the window channels with silicone spray with windows down and then run them up and down and then on the glass in the channels you will see straight away how much faster they travel. It does not attract dirt and grime either.
Old 08-30-2013, 08:07 AM
Sohail-SAAF Sohail-SAAF is offline
Mein Auto: X5, E550, A6, F150, RX350
On my BMW X5 2006, driver side window won't go up until I use a nose pliers to pull it up and simultaneously use up knob, it works fine opening but once it opens all the way it wont close until I use a plier to pull it up a little.
Old 10-17-2013, 04:27 PM
cowartdo cowartdo is offline
Mein Auto: 2006 x5 3.0
The regulator failure causing this situation is the clip holding the cable to the window. There are two clips. they are connected. A plastic one which frequently breaks. cost about 2 dollars on ebay. and the larger metal and plastic clip. This one has a groove that the cable slides into.. The cable has a holding device( remind me of a weight on a fishing line). the "weight" fits into a pocket which gives the window bracket something to hold onto as the cable moves up and down the channel. If the pocket becomes broken or even too large and the cable has too much play, then the window can move front to back a fraction of a inch as your roll it up and down. This movement can cause the window to get stuck in the down position. Dealer wants to sell new regulator for 300 dollars. found the clip on ebay for 11.00.
