Old 09-01-2013, 04:00 PM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
UPDATE Guibo replacement all done. (Guibo Help! Keif ANYONE!)
Replacing my guibo joint and I just pulled the drive shaft off. However, at the rear diff, the CV joint cam apart. Instead of the flange that attaches to the diff. It seems the shaft plate (just behind the CV joint), is seized on. It looks like there are a couple of slots to pry it off but no luck. The CV joint lost a lot of grease and the large bearings dropped out. FML. It was going so well too.
ANYONE?
2008 Lexus LS 460
20" TSW Strip Wheels on Staggered Falken FK452
Old 09-01-2013, 04:14 PM
roadfrog's Avatar
UPDATE: I got the flange off, so now I just need to reassemble the CV joint. Any tips? Type of grease? Can the CV joint even be put back together without issue?
2008 Lexus LS 460
Old 09-02-2013, 11:20 PM
roadfrog's Avatar
All done. I managed to find a local wrecker who was open on a holiday Monday! He sold me a complete driveshaft for 300 bucks. While I was there I bought the hydraulics for my trunk which recently went ti*s up.
Everything went back together without a hitch and the 2-1 clunk when coming to a stop is gone. Silky smooth! The old guibo was shot. When you shook it, it rattled. You wouldn't know by looking at it that it was screwed. Visually, it looked great.
As for the trunk, it now operates fast and strong. 200 dollars for that.
All that's left now is to get the passenger seat airbag sensor problem rectified and then some custom coding!
2008 Lexus LS 460
Old 09-03-2013, 10:08 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Glad you were able to sort it out. Do you plan on coding out the passenger seat occupancy sensor or do you plan on actually fixing the issue?
Old 09-03-2013, 01:29 PM
roadfrog's Avatar
I may buy the bypass module on Ebay. I think its about 60 bucks or so and disables the warning lights.
2008 Lexus LS 460
Old 09-03-2013, 04:33 PM
kjruben kjruben is offline
Mein Auto: BMW 760Li V12
How do you code it out?
Old 09-03-2013, 08:44 PM
roadfrog's Avatar
Having it done remotely through Tripl3o Coding. they do any or all codes you want (ie: disable DRL's, etc).
2008 Lexus LS 460
Old 09-04-2013, 04:34 PM
DFEL750I's Avatar
Mein Auto: 750I
Check this thread out
http://www.bimmerfest.com/forums/sho...seat+occupancy
Old 09-04-2013, 08:39 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Re: UPDATE Guibo replacement all done. (Guibo Help! Keif ANYONE!)
Hey road frog before you changed guibo did u have a thump kinda hesitation when coming to a stop right at the 1000rmp like the tach bouncing then settling down normally?
Sent from my DROID RAZR HD using BimmerApp mobile app
Old 09-05-2013, 07:28 AM
roadfrog's Avatar
Johndade:
Yes and a very distinctive "clunk" or "thump". It is now dead quiet and buttery smooth. Also, shifting from P to R is quieter and smoother.
2008 Lexus LS 460
