Looking to get some great BMW parts for your car? Get the latest info on sponsor group buys, new products or simply ask a site sponsor a question here!
Old 09-10-2013, 12:09 PM
Blauparts Blauparts is offline
Blauparts
Mein Auto: BMW
Blauparts: $10 Off + Extra 5% Off BMW Transmission Fluid for 6 Speed 83 22 0 142 516
$10 OFF ALL Cases Of Ravenol ATF + Free Shipping
Enter Coupon Code ATF913 at checkout for an additional 5% Off SELECT ATF Cases
Having gained formal approval from ZF, Ravenol of Germany was at the forefront of developing transmission fluid for the new sophisticated generation of transmissions. Ravenol 6HP is a fully synthetic PAO automatic transmission fluid particularly designed for the 6 speed ZF transmissions.
Ravenol 6HP Automatic Transmission Fluid (ATF) Technical Characteristics and Features:
Meets or exceeds BMW OEM requirements.
High performance fluid with excellent anti-wear, corrosion resistance, oxidation and thermal stability.
High viscosity index assures proper lubrication in severe hot and protection in cold weather.
Controlled friction properties equals smooth and efficient shifting over the fluids life.
Manufactured in Germany to exacting quality standards.
Technical Specifications: http://www.automotoroil.com/pages/technical.html
6HP Transmission Fluid / Gear Oil Specifications:
BMW 83 22 0 142 516, BMW M 1375.4
ZF TE-ML ZF S671 090 252 /3 /5, ZF-6HP19, ZF-6HP26
FORD MERCON SP XT-6-QSP (6R60, 6R75, 6R80)
Jaguar C2C 8432
Land Rover TYK500050
Meets Audi Vw fluid specifications for 09E and 09L series inline mounted 6 speed tiptronic transmissions.
Audi Vw automatic transmission fluid OE part number G 055 005 A2 equivalent.
6 Speed Tiptronic Transmissions Requiring M-1375.4, BMW 83 22 0 142 516
BMW ZF-6HP
E53 3.0i, 4.4i, 4.6is, 4.8is
E60 525i, 525xi, 530i, 530xi, 545i, 550i, M5, E60N 528i, 528xi, 535i, 535xi, 550i
E61 530xi, E61N 535xi
E63 645Ci, 650Ci, M6, E63N 650Ci
E65 745i, 750i, 760i, Alpina B7 Sedan
E66 745Li, 750Li, 760Li
E70 X5 3.0si, 3.5d, 4.8i, E70N X5 3.5dX
E71 X6 35iX, 50iX
E82 128i, 135i
E83 X3 2.5i, 3.0i, E83N X3 2.5i, 3.0si
E84 X1 28i, 28iX, 35iX
E85 Z4 2.5i, 3.0i, 3.0is, M3.2
E86 Z4 3.0is, M3.2
E88 128i, 135i
E89 Z4 28i, 30i, 35i, 35is
E90 323i, 325i, 325ix, 328i, 328ix, 330i, 330ix, 335ix, M3, E90N 323i, 328i, 328ix, 335d, 335i, 335xi, M3
E91 323xi, 328iT, 328xiT, E91N 328i, 328xiT
E92 328i, 328xi, 335i, 335xi, M3, E92N 328i, 328xi, 335i, 335is, 335xi, M3
E93 328iC, 335iC, M3, E93N 328i, 335i, 335is, M3
Consult your service manual and confirm the specific fluid requirements for your model. BMW automatic transmission fluid levels should be checked at regular intervals. Changing your BMW automatic transmission fluid helps extend the life of your transmission by properly lubricating the main shaft bearings and synchros. The intervals depend on your operating conditions.
83 22 0 142 516 BMW ATF - 1 Liter
83 22 0 142 516 BMW ATF - Case of 12
Blauparts BMW Categories:
BMW Shock Kits
BMW Automatic Transmission Fluid Filter Kits
BMW Motor Oil
BMW ATF Fluid
Website:
www.blauparts.com
* ATF913 coupon code valid on select ATF part numbers only. Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. One offer per order. Offer Ends 09/15/2013
83 22 0 142 516, blauparts, bmw atf, bmw transmission fluid
