Old 09-11-2013, 04:28 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: E39 540, E36 328is, E83x3
Installed
ez install..
the curt hitch is very nice..
the oem bimmer wiring harness is more then the hitch..
Specializing In BMW, Audi, Mercedes Benz ,Volkswagen, Volvo
15486372<-----
Old 09-11-2013, 07:26 PM
elevatorguy925 elevatorguy925 is offline
Sanity is over rated
Mein Auto: Silver 2006 BMW X3
I agree it is not a big deal to install a Curt hitch. I went with the aftermarket harness and it didn't work although stated it would. To do again I would go with the factory harness and not go through the headache of the aftermarket part.
Silverstar upgraded headlights
Velocity motoring vb3 19" 9.5 wheels
Yokahama S drive tires
Upgraded stereo system
Dice Mediabridge
Hitch install
Old 09-12-2013, 02:17 AM
Burning2nd's Avatar
Under the lift arms
the factory one clicked in to the harness came with the grommet, then has the module that plugs in right in front of the batter
Although i did not install that..
It was so hot yesterday.. and we had contractors at work so i was out side All day long.. I was just so kicked.. I just wanted to get it on and then take a shower..
only thing is that the curt doesnt have the holder for the big plug.. So ill end up making something and welding it on to the hitch to hold the connecter..
looks tacky with the zip tie
15486372<-----
Old 09-13-2013, 09:15 AM
Burning2nd's Avatar
Under the lift arms
I Fabricated this bracket .. Here it's not painted but I will weld this on to the curt hitch to make it able to hold the oem harness ..
There was a 80$ difference for this bracket between the BMW brand hitch and the curt hitch
15486372<-----
Old 09-16-2013, 02:49 AM
Burning2nd's Avatar
Under the lift arms
All done
electrical done.. bracket welded on
all mounted
but the cover in half then trimed to fit... the left side needs a little more cutting to cover the connector
15486372<-----
