Steering Wheel Position - Bimmerfest - BMW Forums
Old 09-12-2013, 04:51 PM
jere jere is offline
Mein Auto: 2004 330Ci; 2011 535i
Our new F10 appears to have new design philosophy for steering wheel position timing. Our E60 would position the steering wheel for the driver when the key fob was clicked for "Open". Our present F10 positions the steering wheel when the driver pushes "Start". This is a particular problem for my wife, who is short, after I, who am tall, have driven the car and have left the wheel positioned almost all the way out. The seat moves forward when she clicks "Open" on her key, but the wheel stays out until she presses the "Start " button. She can hardly get between the wheel and the seat to get in the car. Has anyone else seen this problem and/or know of a fix?
Old 09-12-2013, 07:10 PM
fjacobs1000's Avatar
fjacobs1000 fjacobs1000 is offline
Let's drive!
Mein Auto: '14 F10 550, '14 F31 328d
my first thought was - "your wife drives your car?"
ůmine does too, and it makes me nervous. she does damage
sorry if i offend
Old 09-13-2013, 05:56 AM
Smile Steering Wheel Position
Actually the F10 535i is my wife's car, stick shift and all. She loves the 5 series, this is her second one. To head off further stereotype conclusions, we both are definitely senior citizens. BMW lovers come is all forms. No offense taken.
Old 09-13-2013, 01:47 PM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
You can turn off the auto seat position when you unlock the car I believe.
Old 09-13-2013, 02:53 PM
X-Men, you may be right, but then she couldn't reach the clutch pedal to start the car. Or, if she had to manually punch some buttons to get the seat and wheel into position what is the point of the memory settings. The real question is why did BMW change the timing for the wheel repositioning when the F10 came out. Or maybe there is a fault in the software program. Anyone know if there is a fix available?
Old 09-13-2013, 03:30 PM
Gilgorm Gilgorm is offline
Mein Auto: 2012 535i X-drive
OP, your description is correct.
Have you tried moving the wheel before you get out of the car. My fob is set to lift the wheel to its highest point after I turn off the car. It remains in that position for when the second fob moves the seat. I do not have the second fob set to move the wheel to the high position as it isn't needed.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
Old 09-13-2013, 03:39 PM
I think the wheel remain in its highest position for easy entry. What BMW should have done is program the wheel to its highest position as well retract the wheel all the way in after the car is shut off.
Old 09-13-2013, 04:40 PM
douggie douggie is offline
Mein Auto: 5
Seating positions are definitely personal choices, but I suggest that you might want to drive with the steering wheel a little more retracted. This will give you more space between your upper body and the steering wheel. This reduces the chances of the air bag hitting your face when it goes off.
Old 09-13-2013, 06:31 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
I have a 2011 535i. I didn't think there was any choice other than the wheel moving all the way up when you shut down the car. I don't think it's a fob setting.
I don't have the exact issue, but here's what I do. Many mornings, I have to jockey my and my wife's car around because mine is in the (1 car) garage, and hers is in the driveway. I don't like having to move the wheel up while the engine is running, when I jump out during this procedure. When I park in the evening, I do 1 of two different things. If I move the wheel up most of the way before I shut down the car, that is the "new" position it moves to when I start up in the morning. When I'm done moving the cars around, I just press (and hold) my memory 1 position button to move the wheel into my final preset position. The other way to accomplish this is to move the wheel just slightly down after I shut down, and the wheel has already moved all the way up. The wheel stays in this position after I restart.
So, OP, to overcome this issue, just push the wheel backward after it moves up when you shut down. This will pre-position it further from the seat as it moves forward. Your wife may then have to press her memory button for the wheel to go to the final, correct position.
One note: My wife doesn't drive my car, so I only use my fob. I don't have the seat set to automatically move when unlocking the car. Even so, my steering wheel operates as you describe.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
