Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 06-02-2013, 09:39 AM
MI93740i MI93740i is offline
Mein Auto: 1993 BMW 740i
Help E32 window issues
Ok so I'm new to BMW went through every thread didn't find anything with the same issue as mine. My driver window is acting up quite badly. It's tools up and down but it stops about 1/2 in to a inch leaving a crack. Now when it stops at this point all you hear is popping from the window motor. I can manually pull it the rest of the way up but then it won't go down unless I pull it back to the cracked position. Also the drivers rear window works when ever it decides to never know if its gonna work.or not. Well if anyone knows what this problem is or knows how to fix it any advice would be much appreciated.
Sent from my Desire HD using BimmerApp mobile app
Old 06-06-2013, 12:58 PM
BMWFatherFigure's Avatar
Old School
No easy fix. Take off the door trims and check out the motors and arms. Once you can see it all it may be obvious. Check wires and plugs as well.
Current:
E38 Parts Car
Previous:
Old 06-06-2013, 01:12 PM
Re: Help E32 window issues
Yea I can hear the motor trying to turn it up and it slipping I'm guessing its something with the track I also now AMD then blow fuse 17
Old 06-14-2013, 03:36 PM
Old School
Has the track rubber become twisted??
Current:
E38 Parts Car
Previous:
Old 08-01-2013, 11:01 PM
whalepirot whalepirot is offline
Mein Auto: 745Li/735iL/Vette/R1100RS
could be that (most used) gearbox being worn out., like those last teeth gone
the rear could be the switch, or something else electrical, like that motor/gearbox dying.
Old 09-17-2013, 01:30 PM
Mahir Mahir is offline
Mein Auto: BMW 730i V8 1993
Hi there, I am also new to BMW and i have a problem with the windows (except the driver side) are not going up or down, when i press on the window key i notice there is a voltage consumption but no movement happen. Please help me with this problem.
My car is 730i V8 1993.
Thank you .
Old 09-19-2013, 08:41 AM
Old School
Mahir - try having someone push the window down as you press the switch.
Current:
E38 Parts Car
Previous:
Old 08-19-2015, 02:14 AM
rap16992 rap16992 is offline
Mein Auto: 523i Touring
I am having the same issue with my drivers window. Motor runs up and down, but window not. Can anyone point me to a good link showing exactly how to remove the door panel so I can get in and take a look? Thx!
