545i e61 n62b44 engine - Bimmerfest - BMW Forums
Old 09-19-2013, 04:56 AM
waffenwagen waffenwagen is offline
Mein Auto: 545i
hi all
i`m new to bimmerfest i just wanted to know if anyone has had this problem and urgently need help i have a 2004 e61 5 series with the n62b44 v8 engine that is sucking air through the dipstick tube and is smoking and idle rough.
Old 09-19-2013, 09:29 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
a. put the dip stick back in. There is supposed to be vacuum there
b. is it running rough when you have the dip stick out? If so, there's your problem. Having it out is causing a massive vacuum leak.
c. what color is the smoke? Only at idle when sitting a while or all the time?
Old 09-19-2013, 02:32 PM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
Buy my 2000 8E 61 535 wagon. Problem solved!!!
2014 Audi A7 Prestige E61 SOLD 10/4/13! [/B]- 2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius. Escort 9500ci, Dinan S2 Tune (378HP, 417 ft/lb Torque), RD Sport Sway Bars. Conti DW and Michelin Xi3 snows. LED Angel Eyes, Matt Black Grill. Ext warranty until 2017!!!, 67K miles. Original owner. Fanatically Maintained, BMWCCA Member. Jersey
Old 09-19-2013, 03:20 PM
Cre8 Cre8 is offline
That's Rad!
Mein Auto: 05, E60/545i
Welcome! Cool user name!!!
Old 09-20-2013, 12:23 PM
bugsd bugsd is offline
Mein Auto: '13 335i
smoking at idle
Reinstall your dipstick, vacuum there is normal. With the dipstick out you've created a vacuum leak and this will disturb the crankcase ventilation system and cause your engine to burn oil and idle rough. If after replacing the dipstick you still have smoke at idle, (you will need to drive for a day or two to clear the oil residue from your intake manifold), you probably need to replace your valve stem seals. There is an excellent shop in El Cajon that has tooling to replace the valve stem seals and clear the auxiliary air holes without disassembly of your engine.
Old 09-23-2013, 03:49 AM
Mein Auto: 545i
545i engine
hi
many thanks for your reply i live in the uk...is replacing the valve stem oil seals a huge job?
and for the dipstick vaccum and smoke, i thought it was an osv problem as ive done the ccv valves.
best regards
