The X5 SAV Forum
Old 09-19-2013, 05:20 PM
rwink181 rwink181 is offline
Mein Auto: X5
Need to replace my Fan Clutch
Hello Everyone I need to know if replacing the fan clutch can be done by a novice. I see where it goes but I'm not sure what's going to happen once I get her apart. If you have experience replacing one I would appreciate your input. I have a 2003 X5 3.0 E53.
Old 09-19-2013, 11:45 PM
white_lancer white_lancer is offline
Mein Auto: E53 X5 2004 3.0 SPORT
If you mean the viscous clutch on the engine fan then this is a very easy job. I did mine two weeks ago. It took 15 minutes to do. The hardest part is undoing the 32mm nut which holds the clutch to the water pump. I purchased a 32mm spanner from ebay for 6 and used a large flat bladed screwdriver to wedge between two of the 4 bolts on the front of the water pump. the 32mm nut is a left handed thread so undoes in a clockwise direction looking from the front of the car. once the nut is loose fully unwind it and you can simply lift the fan and viscous clutch out from behind the radiator. there are 3 allen bolts holding the viscous cluth to the fan. the replacement is simply the reverse.
E61 2.0D Auto
Old 09-20-2013, 08:16 AM
tmvE39/E53/Z32's Avatar
Mein Auto: Dinan //M5, Dinan 4.8iS,
I feel that need to be emphasized for a novice. I have a little trouble when putting it back on the WP thread: tight space makes it hard to line them up.
FYI: 1 1/4" open wrench fit on that nut too.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 09-22-2013, 07:28 PM
Mein Auto: X5
Thank you both you were right on. took me 1 hour and a half but had success.
fan clutch, trans failsafe message
