Old 09-20-2013, 03:11 AM
Showpony01 Showpony01 is offline
Mein Auto: BMW 740il E38 1995
[B]95 BMW E38 740il steering problem[/B]
Hi all hope you can help my 95 740il e38 has a bad steering box sound between a wer and growl that is very loud and travels up the steering wheel. I have changed the pump as it was leaking through front seal and thought that it was the problem. there does seem be noise coming from it as well although I expect that it is just straining to push the box as it is heavy to steer.
I have checked the servo and it measures 8.3 ohms and the voltage when running is 6.89 volts I also cleared the gme of errors but this did not help.
Are there any suggestions has anyone had the same problem.
I have read in the forums that the only things that most people have is heavy steering with no noise except for low fluid which I have plenty and new.
I don't want to buy or replace the box but if I have to has anybody got one for sale.
Old 09-20-2013, 07:48 AM
ou18 ou18 is offline
Playing Mechanic At Home
Send a message via AIM to ou18 Send a message via Yahoo to ou18
Mein Auto: 1997 740 IL
does it sounds something like this user has posted...
1997 Black 740IL (w\ badass Phone in console)
Old 09-20-2013, 08:00 AM
give this thread a read, not sure its the same issue, but here are some tests he did to identify his problem...its a starting point..
http://www.bimmerboard.com/forums/posts/497761
Old 09-20-2013, 06:18 PM
Unhappy Hi ou18
Hi there, Thanks for your response, it sounds very much like your recording, any ideas on what it is would be appreciated.
HTML code is Off
