Z3 passenger seat moves. - Page 4 - Bimmerfest - BMW Forums
Old 09-18-2013, 06:29 PM
marty505 marty505 is offline
Mein Auto: 99 Z3 M Coupe/99 540i
As if there wasn't enough info. out there on this here's a write-up from across the pond on how to do the seat bushings. http://www.zroadster.net/forum/viewt...402&highlight= I bought my bushings from a fellow in England who makes them and plan to put them in this winter.
Old 09-18-2013, 06:38 PM
pieceofwork pieceofwork is offline
Mein Auto: 97 Z3 2.8 Automatic
Originally Posted by vintage42 View Post
http://www.whalenshiftmachine.com/in...f78814e34fbdf2
http://www.bimmerdiffs.com/products/...mod-fix-kit-z3
I would think any of the replacement bushings are good for life. The original bushings are some kind of rubber or plastic that liquified with age, or perhaps from exposure to the screw lubricant. The old bushings just disappeared into a butyl-like goo that takes a long time remove. I started removing the bulk of the residue with a screwdriver blade, then softened the remainder with gasoline and wiped it out with paper towels, then used carb cleaner spray to remove the last traces.
I studied all the DIYs and videos, and would just add a couple of tips:
1. Run the seat back to access the front nuts, then forward to expose the rear bolts, then run the seat back to put it over its rails so they don't stick out.
2. Tilt seat inward and use a 2x4 block between the seat and the sill to hold it up while unplugging the connectors. After this point, do not use the car's key. Those who do use the key, are those who forgot to run their seat back, so they do that and trigger their airbag light.
3. Seat is heavy, get a helper to lift it out and in. Failure to get a helper allowed my sharp seat rail to cut through two towels and scratch the rocker panel going back in.
4. As soon as screws are out, use a nail or pencil point to count the threads showing on each screw and write it down. Should be the same on both, depends on where you stopped the seat going back, mine were 20.
5. When screwing the new bushing holder back on the screw, count the threads again to put it back where it was.
6. When replacing each re-bushed screw, insert the flexible drive rod into it and then insert the end of the screw into its guide hole inside the rail, which will then direct the drive rod into the motor at the bottom. If the screw won't hold the end of the flexible drive rod, put a little tab of duct tape on the end of the rod and jam the rod into the screw's hole.
7. Note that the guide hole has a plastic insert that can come loose. Must use the insert because it centers and acts like a bearing for the end of the screw. If the end of the screw won't go into the plastic insert, tap it in.
I would add: do not 'over grease' AKA the youtube video where the rod threads are slathered in grease. IMO, too much grease is almost worse than too little, it attracts contaminates and you can easily get grease on the carpet during the re-install.
Also my passenger seat had a plastic bushing on each threaded rod, which I assume was to prevent the seat from traveling too far forward (air bag safety measure?). Not sure why it was there, but I did put it back in.
Old 09-19-2013, 01:32 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by pieceofwork View Post
I would add: do not 'over grease' AKA the youtube video where the rod threads are slathered in grease. IMO, too much grease is almost worse than too little, it attracts contaminates and you can easily get grease on the carpet during the re-install....
It does not matter how much grease is slathered on the rods because no excess is left on the rods after the threaded block is run up and down the threads. I can't imagine not doing that ;-)
The BimmerDiff kit came with enough lube to do two seats. It is a strange lube, stiff and sticky. Not a grease, but a thin spreadable sticky material that would stand up in its container and then level itself like silly putty. There is not enough to slather, and a little goes a long way. It is the perfect lube for seat screws and scissor jack screws.
The DIYs do note the plastic bushings on the ends of the passenger rod. I haven't done that seat yet and will be curious to see them.
Old 09-20-2013, 08:35 AM
Elderuser Elderuser is offline
Aging Gracefully
Mein Auto: 1998 Z3 2.8; 2003 530i
Elderuser
Originally Posted by EOD Guy View Post
Yes,
PM with your email address, I'll send you a detailed power point slide show on how I fixed it.
Thanks. Nokaoi37@gmail.com
Old 10-09-2013, 06:45 PM
Mungo So Cal Mungo So Cal is offline
Mein Auto: 01 Z3 - 15 535D - 16 X1
Would someone still following this thread email the ppt? Hoping for something a little more clear than the waycool version. Pm me and I will reply with my email. I have a set of replacements on the way from bimmerdif (with tilt hw). Hooray!
Old 10-09-2013, 07:00 PM
vintage42's Avatar
BMW CCA 1405
I got the combination kit, too. I did the driver seat OK. But I could not disconnect the passenger seat airbag module because it was anchored up tight under the seat. so on that seat I only did the tilt mod. Later I read that the module can be removed from the seat bottom by twisting it 1/8 turn and pulling it down.
As for PPT you ask for, I have not heard of it, and wonder if you will ever get it. If you don't get it, I can post a half dozen DIY links on the seat bushings.
And, unlike BimmerForum, the Search function works really well here, so you can find them yourself.
Old 10-09-2013, 07:27 PM
I have come across many walkthroughs as well and tips related to the walkthroughs. I hope the prep pays off!
Old 10-10-2013, 07:31 AM
Are you replacing the bushings in your exsisting seats? Someone was kind enought to send me the PPT, but I've since deleted it, suggest you post your email up in this thread - it might take a few days but you'll get it.
Old 10-10-2013, 03:50 PM
Yes, I will replace at least the driver's side. After more poking around, I did find a briefing for download on the waycool site. I am pretty sure it is the one mentioned here. Thanks for the tos guys. Will let you know how it goes!
Old 06-25-2014, 09:17 AM
HDMIKE HDMIKE is offline
Mein Auto: 1996 BMW Z3
Seat Bushings
New here and have a question please.
I recently replaced the seat bushings on my 1996 Z3. One seat went perfect but I lost track of the thread count on the other seat. Is there an easy way to start over so that both rails are even? I thought about just screwing both skewers on to about 4 or so threads which should put the seat in the fully back position and even. Will this work? Thanks so much for any help.
EMail: hdmike@bryanonline.net
Old 06-25-2014, 09:52 AM
Paul P Paul P is offline
Mein Auto: 1997 Z3
Seat Bushings
The point is to get them even so it wont bind when it moves. I just measured mine with a ruler and then one wouldn't go together far enough for the bolt to go back in so I just rotated it half a turn and it just fell together. I also had a driver seat belt light on before and after reseating the connectors and having it reset again it never came back. Wish you had someone close who had done this because it's simple afterwards, not as big a deal as I thought. Good luck, Paul Another thought, I disconnected my battery because the seats still have power with the key off. Hardest part is cleaning the raw rubber from the old bushings and sanding the new ones to fit. You also need help to hold that seat while you do the connectors.
Old 06-25-2014, 10:00 AM
Seat Bushings
Thanks Paul,
The concept sounds simple. I will give it a shot and just ensure they are even once bolted in. I have a power supply hooked up to the seats, so I should be able to test for any binding issues.
Thx again...
Old 06-25-2014, 10:13 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by Paul P View Post
... get them even... I just measured mine with a ruler... You also need help to hold that seat while you do the connectors.
I counted threads with a pencil tip before removing the screws, and screwed them back the same number of threads. I used pieces of 2x4 under the seat to prop it up while doing the connectors.
Old 06-30-2014, 02:53 AM
Cheddar57 Cheddar57 is offline
Mein Auto: 2001 Z3 3.0i Roadster
Can I get the powerpoint also?
Old 07-11-2014, 08:31 AM
TheUSC_2001 TheUSC_2001 is offline
Mein Auto: 1999 BMW Z3 M Roadster
Sorry, forgot to reply to my post. Replaced with Whalens and worked like a CHAMP! Highly recommend.
My Baby - 1999 Z3 M Roadster
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=301105&dateline=1370375960
Eric
Old 07-26-2014, 04:57 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
I got a new version of PPT so here is the PDF file
I use a piece of alum from Tractor Supply Store or Home Depot to make my bushing, I only used one thick one instead of two skinny ones, basically I cut the alum to the same size as the old rubber bushing drilled a large hole in it, like the old bushing ..... done.
.... Good luck to all
Old 08-09-2014, 07:38 PM
DebbyA DebbyA is offline
Mein Auto: BMW Z3
Just joined and I have the seat movement problem with my 97 Z3. Please send the instructions that you have thanks. z3debby@hotmail.com
Old 08-09-2014, 08:26 PM
JustinHalverson JustinHalverson is offline
Rdster Justin
Mein Auto: 1999 BMW M-Roadster
There are a lot of internet posts on how to do this. Here is one:
https://zroadster.org/articles/how-t...s-bushings.51/
Old 08-10-2014, 06:52 AM
BTCPO BTCPO is offline
Mein Auto: 96' BMW Z3 Atlantic Blue
Seat Movement
I recently had my seat bushings replaced. What a joy to drive this car with out all the seat slop back and forth! If you have this problem, get r fixed and you will enjoy this great car so much better.
BTCPO
High Point NC
96' Z3 Atlantic Blue
Old 08-10-2014, 07:22 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
According to the reviews for the bushings on the Pelican Parts website their bushing kit needs no modification. Has anyone used their parts? is the notation correct?
http://www.pelicanparts.com/catalog/..._pg2.htm#item3
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 08-10-2014, 07:53 AM
vintage42's Avatar
BMW CCA 1405
I don't see how any of the "kits" would need modification. There's just four plastic squares with holes in them.
Old 08-10-2014, 12:35 PM
The first time I looked at bushing kits they needed to be sanded down a little bit to fit properly.
Old 09-23-2016, 06:28 AM
Flyboy_John Flyboy_John is offline
Mein Auto: Z3
Has anyone considered cutting the end of the bushing to make it look more like a u then slide it over the rod vice unscrewing the rod completely? Wouldn't this eliminate the need to count the turns facilitating the adjustment and symmetry problem? Just a thought.
Old 09-23-2016, 07:30 PM
vintage42's Avatar
BMW CCA 1405
Perhaps you have not seen the carrier into which the bushings go. The bushing is under a lot of compression. What you suggest would let the bushing push out as easy as it was pushed in.
Name:	Bushing carriers.jpg
Old 09-24-2016, 01:53 AM
Mein Auto: Z3
What you say makes total sense. I just ordered the replacement bushing and will tackle the job once they arrive. Thanks for the comment.
