Old 09-21-2013, 10:33 AM
Bret_T Bret_T is offline
Mein Auto: '14 435i & '03 S2000
M Sport Brakes Question
I was at a local dealership yesterday. They have two 4-Series coupes. One has the optional M Sport Braks and the other doesn't. I looked at them and found that the calipers are the same. In fact, everything looked identical except for the paint color. What's the real difference between the M Sport Brakes and the regular brakes?
Liberalism: Failure is always proof that more is needed.
Old 09-21-2013, 12:22 PM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
The 4-series might be different, but here's a breakdown of the 3-series I saved from a post over on another forum.
Original Brakes on "high power" models (335i)
Front rotor: 340mm brake rotor with 4 piston caliper
Rear rotor: 330mm brake rotor with 1 piston caliper
Original Brakes on "low power" models (320i/328i)
Front rotor: 312mm brake rotor with 1 piston caliper
Rear rotor: 300mm brake rotor with 1 piston caliper
M-Sport Brake Option (2NH) (Blue M calipers)
Front rotor: 370mm Brake Rotor with 4 pistons (for on "high power" models)
Front rotor: 340mm Brake Caliper with 4 pistons (for "low power" models)
Rear rotor: 345mm Brake Caliper with 2 pistons (on all models)
M-Performance Brake Kit (Yellow, Orange or Red M calipers)
For a "high power" car (all that have 4 piston front brake calipers as factory standard):
Sizes are the same as M-Sport 2NH option but all rotors are dimpled and slotted
For a "low power" car (all that have 1 piston front brake calipers as factory standard):
370mm front rotors, 345mm rear rotors - all dimpled and slotted
Separate Rotor Upgrades
For upgrade of the original brakes with 340mm rotors, one can buy OEM BMW replacement dimpled and slotted rotors.
Front rotor: 340mm = Part Number 34 10 6 797 602
For upgrade of the with 2NH M-Sport Brakes, one can buy OEM BMW replacement dimpled and slotted rotors.
Front rotor: 370mm = Part Number 34 10 6 797 603
or
Rear rotor: 345mm (all models) = Part Number 34 20 6 797 598
Old 09-22-2013, 05:14 PM
chiefneil, thanks for the detailed explanation. Based on what I saw and the details you've provided, it appears that the front M Sport Brake brakes for the 428i are the same as the regular front brakes for the 435i. Of course there's no way to see if the pads are different.
