Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 09-12-2013, 10:39 AM
djcwardog djcwardog is offline
V-8 Driver
Mein Auto: 2007 650i 6MT
More Learning...
My new CIC stuff is due in tomorrow - three different suppliers: The CIC and various small pieces, the LCI trim plate, and the Pasternack cables. Should be a fun weekend!
I got into INPA some more and saved my UIF so I would have a solid record of the existing modules and when they were updated. Most have an update as of 7/11/2013 - when I took the car into the dealer for that purpose. However, the TEL/MULF, KLIMA, CDC (Dension in my case) and ZBE show the original 2006 date. With the "YYYYYYY" data, this indicates that INPA is not sure what VIN is associated with those modules, but all 35 run "OK". All of my CCC modules seem to have taken the update. They ran into the next day, 7/12/2013 and the service writer told me that it took them four tries to get the CCC to accept the coding. He went on to say that if this had been warranty work, they would have replaced the CCC after try #2. Then he told me that because the CCC ultimately DID take the coding, all was well.
So I think I will wait a day, put the CIC in with existing (old) controller, get that working, then try again with the new one. Of course, I have already modded the console opening to accept the new, so I WILL figure this all out and use it!
I also started working with Winkfp in comfort mode. I understand now how it works to examine modules and "flash" updates. Of course, I have not yet done any of that... It appears that, unlike INPA - where I can scan the entire car and get status on all 35 modules, with Winkfp, you need to know which module you want to examine/flash. Having read somewhere on these pages that our iDrive controllers have no ECU and are not "flashable" I take that to mean that the relevant module with our CCC or CIC is what gets updated? For example, with my CCC, setting a value for ZBE then running manipulation mode in NCS to write it to CAPPL, I see several CCC... modules being addressed in the coding, but not a ZBE... I assume it will be similar with the CIC - which may well just work with the new controller after I default code it to the car after editing my VO... Some threads mention adding $6VA to my VO, but I thought it was really just a matter of changing build date to #0909, FA_Write, then the normal process of default coding the newly found "CIC" module, and perhaps the TCU as well?
Looking forward to doing more in the days ahead.
Here is the text of what I saved from my INPA efforts last night:
U S E R I N F O R M A T I O N F I E L D
Date: 11.09.2013 19:41:17
Model: E60
Scope: all control module
JobStatus: OKAY
Quantity: 35
ADR Gen. name JobStatus ZB No. VIN No. Date
00 ZGM OKAY 9221210 CR46295 11.07.2013
01 SIM/SGM OKAY 9172018 CR46295 11.07.2013
02 SZL OKAY 9115162 CR46295 31.08.2006
12 DME/DDE OKAY 7599082 CR46295 11.07.2013
1B VVT OKAY 7575654 CR46295 11.07.2013
1E VVT2 OKAY 7575654 CR46295 11.07.2013
20 RDC OKAY 6782800 CR46295 11.07.2013
23 ARS OKAY 6786139 CR46295 11.07.2013
27 PGS OKAY 9134707 CR46295 11.07.2013
29 DSC OKAY 6791109 CR46295 11.07.2013
36 TEL/MULF OKAY 9126534 ˙˙˙˙˙˙˙ 09.03.2006
37 AMP OKAY 9181743 CR46295 11.07.2013
3C CDC OKAY T411033 ˙˙˙˙˙˙˙ 14.06.2006
3D HUD OKAY 9190873 CR46295 11.07.2013
3F ASK OKAY 9185551 CR46295 12.07.2013
40 CAS OKAY 9147203 CR46295 11.07.2013
41 DWA OKAY 6965588 CR46295 06.07.2006
44 SHD/MDS OKAY 9137055 CR46295 11.07.2013
45 RLS OKAY 6980020 CR46295 04.08.2005
47 ANTTU OKAY 9185625 CR46295 12.07.2013
53 IBOC OKAY 9119363 CR46295 11.07.2013
54 RADIO OKAY 9142852 CR46295 11.07.2013
57 NVE OKAY 9164992 CR46295 11.07.2013
60 KOMBI OKAY 9197118 CR46295 11.07.2013
62 MOSTGW OKAY 9185627 CR46295 12.07.2013
63 MMI/CCC OKAY 9185623 CR46295 12.07.2013
64 PDC OKAY 9185139 CR46295 11.07.2013
65 BZM/SZM OKAY 9163848 CR46295 11.07.2013
67 ZBE OKAY 6963051 ˙˙˙˙˙˙˙ 18.07.2006
70 LM OKAY 9203082 CR46295 11.07.2013
72 KBM OKAY 9176069 CR46295 11.07.2013
73 CID OKAY 9151978 CR46295 11.07.2013
78 KLIMA OKAY 9122399 ˙˙˙˙˙˙˙ 31.07.2006
8B NVC OKAY 9141606 CR46295 11.07.2013
A0 CCC OKAY 9193874 CR46295 12.07.2013
djcwardog: 2007 650i 0440/LCGE, 6MT, Sport, Nav, HUD, NiVi (w pin swap in CIC), HD Radio (from CIC), CDC, SiriusXM. Coding: no lawyer screen (CIC), fan speed LED seen on "auto" (with an LCI-IHKA), turn signals in HUD. Complete: CIC.C1A retrofit>E90.SSD >E90-E60 merged CIC.trc >CMEDIAR.C05 coded Combox, w/ ConnectedDrive, Plug-In, etc., Verde 19" wheels, DINAN CAI, BAVSOUND Stage One Speakers and Ghost Underseat Subs, DIRAC 752 Individual Audio retrofit amp (up from L7).
Old 09-12-2013, 10:43 AM
DIY'er
Mein Auto: 2004 545i
There are two things you have to add to the VO--I'll try to find them again shortly. Then the date change also. That date is for without combox--you have to use a later one for combox (not sure of the exact date, sometime late 2010 I believe)
Old 09-12-2013, 11:00 AM
V-8 Driver
More Data
More details from my INPA session:
I D E N T I F I C A T I O N
Date: 11.09.2013 19:45:18
Model: E60
JobStatus: OKAY
Quantity: 35
ADR Gen. name JobStatus SGBD GROUP Part No. VarI DiaI CoI HwI SW-No FSV SW-No OSV SW-No MCV SW-No res Date Supplier Name
00 ZGM OKAY KGM_60 D_ZGM 9221210 4D56 0BD0 5 00 9.95.12 3.5.10 0.16.108 0.0.0 05.09.2006 Loewe => Lear Karosserie Gatewaymodul
01 SIM/SGM OKAY ACSM60 D_SIM 9172018 4D51 0B20 34 12 44.50.0 4.0.0 0.20.182 0.0.0 30.08.2006 Autoliv Airbag-Elektronik
02 SZL OKAY SZL_60 D_SZL 9115166 4E42 01C8 34 07 35.0.0 4.0.1 0.19.163 0.0.0 31.08.2006 Kostal Schaltzentrum Lenksäule
12 DME/DDE OKAY N62_TUE D_MOTOR 7566706 3551 0020 17 01 255.255.255 255.255.255 0.14.122 255.255.255 25.08.2006 Bosch Motorelektronik ME 9 8 Zylinder N62 TUE
1B VVT OKAY VVT_B1_0 D_VVT 7575656 3932 0014 0 20 6.255.255 0.255.255 0.6.143 0.0.0 24.08.2006 VDO Variabler Ventiltrieb Bank 1 8 Z. N62, 12 Zyl. N73
1E VVT2 OKAY VVT_B2_0 D_VVT2 7575656 3932 0014 0 20 6.255.255 0.255.255 0.6.143 0.0.0 24.08.2006 VDO Variabler Ventiltrieb Bank 2 8 Z. N62, 12 Zyl. N73
20 RDC OKAY 6782800 4547 1000 0 02 10.1.0 3.10.3 0.18.56 0.0.0 18.08.2006 BERU Electronics
23 ARS OKAY ARS_70 D_ARS 6786139 505A 0252 18 32 8.12.0 5.6.0 0.23.146 8.12.0 31.08.2006 Temic Aktive Rollstabilisierung
27 PGS OKAY PGS_65_2 D_PGS 9134707 4B5A 0261 4 00 9.16.0 3.3.0 0.12.30 0.0.0 01.09.2006 Siemens Passive Go System
29 DSC OKAY DXC8_P D_DSC 6791109 4D52 0BC3 12 03 5.21.0 0.0.0 0.16.93 60.41.67 25.01.2006 Bosch Dynamische Stabilitätskontrolle Plus
36 TEL/MULF OKAY TELE60_2 D_TEL 9126534 454F 0631 9 12 9.6.10 255.255.255 0.18.23 0.0.0 09.03.2006 Motorola Telefon ECE,US,Japan Variante
37 AMP OKAY AMP_60 D_AMP 9181745 464E 0670 3 A22 8.9.0 3.1.3 0.9.114 0.0.0 28.08.2006 Harman Kardon Top HIFI Verstärker
3C CDC OKAY 0411033 5446 0F40 0 A16 0.192.6 0.0.0 0.10.41 0.0.0 18.07.2006 Alpine
3D HUD OKAY HUD_60 D_HUD 9190879 454A 0680 5 05 5.137.0 35.242.5 0.21.170 5.89.1 01.09.2006 VDO Head-Up-Display
3F ASK OKAY ASK_60 D_ASK 9185546 4945 0A00 10 91 6.17.0 0.0.0 0.10.148 0.0.0 31.08.2006 VDO Audio System Kontroller (im CCC)
40 CAS OKAY CAS D_CAS 9147203 5341 06A0 6 C3 2.2.5 3.3.0 0.0.0 0.0.0 01.09.2006 Siemens Car Access System 2
41 DWA OKAY DWA_63 D_DWA 6965588 484A 0750 5 07 5.15.0 3.3.0 0.16.87 0.0.0 06.07.2006 Gemel DWA Sirene und Neigungsgeber
44 SHD/MDS OKAY SD_KWP D_SHD 9137055 4858 0351 7 C1 5.4.5 3.2.3 0.11.172 5.4.2 08.07.2004 Siemens Multi Drive Schiebehebedach
45 RLS OKAY RLS_E65 D_RLS 6980020 4A4B 0360 6 72 6.3.40 3.2.4 0.10.158 99.5.0 07.07.2005 Kostal Regen- Lichtsensor
47 ANTTU OKAY ANT_60 D_ANTTU 9185625 4946 06D0 12 05 7.7.0 0.0.0 0.10.148 0.0.0 18.08.2006 VDO Antennentuner im CCC
53 IBOC OKAY IBOC60 D_IBOC 9119363 5243 0460 0 02 3.13.0 3.1.2 0.14.132 0.0.0 21.03.2006 Visteon Digital Tuner US
54 RADIO OKAY SAT_60 D_RADIO 9142852 4854 0860 0 02 3.23.0 3.1.2 0.14.152 0.0.0 21.03.2006 Visteon Satellitenradio US
57 NVE OKAY NVE_65 D_NVE 9165000 4D42 01B0 5 05 229.0.32 3.3.50 0.16.117 4.2.57 23.03.2006 Autoliv Night Vision Steuergerät
60 KOMBI OKAY KOMB60 D_KOMBI 9197123 4855 06E0 6 04 105.81.3 3.3.0 0.16.109 0.0.0 05.09.2006 VDO Intrumentenkombi
62 MOSTGW OKAY CCCG60 D_MOSTGW 9185626 464D 09D0 8 42 5.104.43 3.3.0 0.10.148 0.0.0 01.09.2006 VDO MOST/CAN-Gateway (im CCC)
63 MMI/CCC OKAY CCC_60 D_MMI 9185623 464C 06F0 7 98 6.52.3 0.0.0 0.10.148 0.0.0 04.09.2006 VDO Car Comunication Computer
64 PDC OKAY PDC_65_2 D_PDC 9185139 4C57 0421 2 01 9.15.0 3.3.30 0.12.95 0.0.0 04.09.2006 Valeo Park Distance Control
65 BZM/SZM OKAY SZM_60 D_BZM 9163848 4653 0990 3 07 6.11.0 3.3.60 0.21.26 0.0.0 10.04.2006 Eaton Schaltzentrum Mittelkonsole
67 ZBE OKAY ZBEH60 D_EC 6963051 4559 07F2 0 05 5.0.5 3.3.60 0.16.142 0.5.5 23.01.2003 Alps Zentrale Bedieneinheit High (this is the old controller)
70 LM OKAY 9203082 5352 0D60 53 06 4.60.0 4.0.5 0.16.112 0.0.0 07.09.2006 Loewe => Lear
72 KBM OKAY KBM_60 D_KBM 9176069 4554 0730 8 C5 7.8.0 3.2.4 0.22.250 0.0.0 22.06.2006 Siemens Karosserie Basis Modul
73 CID OKAY CID_60 D_CID 9151978 4552 0740 3 20 121.65.0 3.1.2 0.10.131 0.0.0 30.11.2004 VDO Zentrales Info Display
78 KLIMA OKAY IHKA60 D_KLIMA 9122399 474E 0791 9 09 5.19.255 3.3.20 0.16.105 0.0.0 31.07.2006 Preh Klimabedienteil
8B NVC OKAY NVC_65 D_NVC 9141607 4E44 0C90 0 07 0.0.35 0.0.0 0.0.0 196.80.17 28.07.2006 Autoliv Night Vision Kamera
A0 CCC OKAY CCCA60 D_CCC 9193871 4B49 0930 12 98 8.106.1 0.0.0 0.10.148 0.0.0 04.09.2006 VDO CCC Applikation
I was getting constant notes that my SG level was 5 (or 6) and that was higher than the INPA level, 1.041 or something like that... I figure that to mean that I need an updated INPA program? EDIT - my INPA is version 5.0.6.0. dated 7/20/2013 (from Chris when he sent me the new v49 datens perhaps), so is there an even newer one? Thanks for helping me get this retrofit done. I did all the coding required the last time and no joy - hope for better this around! If I really felt like it, I would go out there now, put the new controller in (move the wires, etc...) and rerun these INPA queries - that would clearly ID the exact module (ZBE), yes?
EDIT - to compare before and after module ID through INPA, Here's the same info right after install and initial coding yesterday, note count of modules dropped from 35 to 25, some of the same named modules appear now with different s/w dates, CID is now up to a 2009 date (from 2004...) and the CIC-related modules like CCC, etc. now show a date of 5/30/2013 - probably when the exchange CIC was recoded by BMW. More fun for today to get the ZBE2 read and updated among other things:
Date: 13.09.2013 13:33:54
Model: E60
JobStatus: OKAY
Quantity: 25
62 MOSTGW OKAY 9239242 5643 10E0 0 00 6.7.12 6.0.7 0.0.0 0.0.0 30.05.2013 Becker
63 MMI/CCC OKAY 9253418 5555 10F0 19 00 6.11.7 6.0.7 0.0.0 0.0.0 30.05.2013 Becker
73 CID OKAY CID_90 D_CID 9211969 4941 0A30 15 39 153.69.16 4.2.0 0.31.71 0.0.0 03.02.2009 Alpine Zentrales Info Display
92 VIRTSG92 OKAY 9180490 5749 0000 0 31 0.0.0 0.0.0 0.0.0 0.0.0 30.05.2013 Becker
A0 CCC OKAY 9239246 5651 1100 0 00 6.7.12 6.0.7 0.0.0 0.0.0 30.05.2013 Becker
Note there was no ZBE2 with both new date and $6VA. It appeared with #0909 update... I WILL WORK TODAY TO CONFIRM FACTS FURTHER AND UPDATE... Error messages associated with trying to get both new and old iDrive controllers to work with the CIC...
First set of ZBE2 errors, trying to have CIC work with new controller, after default coding:
[13:25:16.665] [2013-09-13] [SERIE] 2020 Error LFCDHDIA.CPP (A_E65.IPS/IPO) CDHapiResultText 1
[13:25:16.665] [2013-09-13] [SERIE] SG antwortet nicht IFH-0009: SG nicht angeschlossen oder meldet sich nicht ZBE_60_2
[13:25:16.775] [2013-09-13] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6
[13:25:16.775] [2013-09-13] [SERIE] SG antwortet nicht CODIERINDEX_LESEN
[13:25:19.486] [2013-09-13] [SERIE] 2020 Error LFCDHDIA.CPP (A_E65.IPS/IPO) CDHapiResultText 1
[13:25:19.486] [2013-09-13] [SERIE] SG antwortet nicht IFH-0009: SG nicht angeschlossen oder meldet sich nicht ZBE_60_2
[13:25:19.597] [2013-09-13] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6
[13:25:19.597] [2013-09-13] [SERIE] SG antwortet nicht CODIERDATEN_LESEN
Here was the second set ofZBE2 errors I got with old iDrive controller back in place:
[21:33:52.253] [2013-09-13] [SERIE] 2041 Error CDH.C CDHCheckIdent 3
[21:33:52.253] [2013-09-13] [SERIE] Falscher SG-Codierindex A_E65: CODIERINDEX = 00h ZBE_60_2.C04: CODIERINDEX = 04
[21:33:52.365] [2013-09-13] [SERIE] 2041 Error COAPI2.CPP coapiRunCabd 6
[21:33:52.365] [2013-09-13] [SERIE] Falscher SG-Codierindex SG_CODIEREN
Third and last try before retiring for the night yielded this:
================================================== ==============================(3)
[21:35:56.818] [2013-09-13] [SERIE] 2020 Error LFCDHDIA.CPP (A_E65.IPS/IPO) CDHapiResultText 1
[21:35:56.818] [2013-09-13] [SERIE] SG antwortet nicht IFH-0009: SG nicht angeschlossen oder meldet sich nicht ZBE_60_2
[21:35:56.934] [2013-09-13] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6
[21:35:56.934] [2013-09-13] [SERIE] SG antwortet nicht CODIERINDEX_LESEN
[21:35:59.573] [2013-09-13] [SERIE] 2020 Error LFCDHDIA.CPP (A_E65.IPS/IPO) CDHapiResultText 1
[21:35:59.573] [2013-09-13] [SERIE] SG antwortet nicht IFH-0009: SG nicht angeschlossen oder meldet sich nicht ZBE_60_2
[21:35:59.686] [2013-09-13] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6
[21:35:59.686] [2013-09-13] [SERIE] SG antwortet nicht SG_CODIEREN
So, more fun for today. Any insights/files/links appreciated!
Last edited by djcwardog; 09-14-2013 at 06:31 AM. Reason: UPDATE for new UIF run after CIC installed
Old 09-12-2013, 05:35 PM
V-8 Driver
Tried It...
I coded ZBE to "low", moved the wires to plug in the new controller and tried one more time - INPA told me all 34 of my modules were fine... Yes, down from 35 last night as the ZBE fell out, not even recognized... I find it hard to believe that one of my CCC modules (all updated just a few weeks ago) would need to be flashed to see the new controller. No worries, the CIC should go in tomorrow and we will take it from there.
Old 09-14-2013, 07:10 AM
V-8 Driver
Plan for Today
Ok, because I now have all the parts and it is fairly easy to swap CCC for CIC and reverse, I think I will:
1) Park under the sun (a gorgeous day here!) and revert back to old CCC with old controller.
2) Return the VO to old entries (#0906, no $6VA, default car...).
3) Run UIF and edit to the ZBE value in CAPPL, get the old controller to work with CCC and then based on the ZB# numbers it shows, using Winkfp to flash update the CC6260 module to reflect ZB# 9185636.
From checking my earlier saved work and the UIF from 9/11/13 it looks like a few ZB#'s may be worthy of examination. Before installing the CIC, ZBE was 6963051, MOSTGW was 9185627, MMI/CCC was 9185623, and CCC was 9193874. Also, my VIN last seven appeared on all modules except my CDC, KLIMA, TEL/MULF, and ZBE - all those had "???????" as the value instead of "CR46295". Granted, the CGATE and the CC6260 do not appear directly, but perhaps I know enough now to look at things with WinKFP - after restoring all the CCC stuff back in. In any event, here's hoping that I can get at least ZBE and CC6260 sorted out.
4) Proceed from there if I can get new controller working with the CCC...
5a) I also read a thread where advice was to keep the VO as was with the CCC - for me #0906 - edit the CAS (only) to reflect #0909 - but NOT to proceed with an FA_Write into CAS and LMA. This worked for the poster to allow edits to the actual modules in the car and not the default (some phantom) that are shown when FA_Write is done to CAS and LMA for a later build date date of #0909, The explanation went on that any time you wanted to update the CIC later, one would have to make this edit again (each time).
So, after I do (revert to, temporarily) the CCC stuff, I may try that trick next...
5b) If 5a does not work, go for the full FA_Write and default coding after step 4 is confirmed to work... If controller still not recognized, I may need to replace it.
If I get things going - others have provided CIC Coding to Disable iDrive Disclaimer:
CIC Module
LEGAL_DISCLAIMER_TIME
kein_ld
More to follow!
Old 09-18-2013, 08:50 AM
dbond dbond is offline
Mein Auto: E60
For your old iDrive controller (ZBE HIGH) to work with CIC you need to dumb it down (convert to ZBE LOW). Program it with ZbNr 6941801. Reason: CIC does not support haptic feedback found in ZBE High.
Old 09-18-2013, 10:28 AM
DIY'er
I thought he was trying to get the new, CIC style controller working? I could be wrong though.
Old 09-18-2013, 10:38 AM
V-8 Driver
You are both correct!
My eBay "new" controller was returned for full refund. I have another coming tomorrow. In the meantime I wanted to get the original one to work so I could explore all menus, see why nav is grayed out, etc... Suspect this to be a virgin CIC (exchange unit from dealer) with no VIN and no FSC's in it. I used Tool32 to C_FG_Lesen on CICR.PRG. I got a "90..." and no VIN. I tried to "Schreiben" with my VIN plus check digit as seen when I run NCS (18 digits), unit still works (I didn't brick it) but nav still gray - and my emulator is in place... Does it matter if I do this stuff with it in or out? I kept it out for all that fun...
Just seeing dbond post his advice, I was literally about to go out to car and try "dumbing down" my CIC "high" controller and report in. Still will...
When I get new controller, I just run Winkfp again, and see if it is (or do so) flashed up to the preferred #9185636?
How in Hell do I get FSC's (any - using emulator, yes?) into my car assuming I got the VIN issue resolved?
Old 09-18-2013, 11:30 AM
V-8 Driver
Thumbs up Yes!
dbond - you are awesome! There were just 2 numbers to choose from under ZBEH60. It had been at 6963051 and based on your advice, I just flashed it down to the other choice, 6941801.
The old iDrive controller now works - and it retained its haptic feedback. I can now use everything in the car... Nav is still grayed out - and the CIC panel does not light up...it did before. I suspect a bad connection in the PnP emulator harness - perhaps even to pin #14? I'll check it out...
So, I have a remote coding appt with B-R for next Tuesday to get the CIC up and running with a VIN in it... They will want more dough - and for me to hook up to an ICOM A+B+C - if I desire to import FSC codes into my CIC. If I go through all that, why use an emulator at all? Can't I just use a different VIN and matching (or even my VIN with a set of not matching FSC's for nav and voice - does it matter?) set of FSC's so my emulator can take over? It's already bought and shipped to me from Germany... Then I would need US maps and yet another FSC code to activate them...correct?
Such fun - and thanks for getting my current rig to function fully... I love all those menus in there... Can't wait to see the 3D nav though....
Old 09-18-2013, 01:16 PM
DIY'er
Depends how they are doing it--who is doing it? If they are installing real BMW FSC nav FSC codes specific to your VIN, then yes, no reason for an emulator. However, I THINK there is a much cheaper way of doing it where they install the FSC for another VIN (that they probably grabbed off another CIC somewhere along the way). That way there is no real cost for the code, just the cost to install it (and the expertise of knowing how the heck to do that without frying anything)
Who is doing the coding/FSC install??
When you try to update the maps it will ask for a code before it will begin the installation, that is the other FSC code you will need. For that one, you can get them online for $20-50. ~$100 for an unlimited lifetime code to update as many times as you want in the future.
Where are you located? I was going to say you could use my ICOM if you need it if you're near by
Old 09-18-2013, 01:54 PM
V-8 Driver
I am in central KY, about halfway between Louisville and Nashville...off of I65. If you are willing to trust me I am good for the shipping expenses both ways if you mean it...? Would I need any more software that what we have talked about on these posts...? It's Bimmer-Retroft who actually offer the remote coding service alone for cases like mine where I sourced everything myself (well, w your help of course!).
I was trolling around my menus and I saw a number "9126534" come up as a reference for me to use in calling BMWAssist to turn on my service... Before it always had the last 7 of my VIN... Hmmmm - a VIN or a TCUM part/ZUSB #...? I gotta go buy some plumbing stuff right now (taking the Bimmer - a suitable parts chaser...) but I will check my saved UIF's later and see....
Old 09-19-2013, 06:12 AM
DIY'er
I'm not sure exactly how bimmer-retrofit does it--you can use an ICOM with INPA/NCS/Winkfp and you can use it with BMW's ISTA software, so I'm not sure which one they would need. Can you find out?
If they are using INPA/NCS/Winkfp then you wouldn't need anything else (well, you'd actually need another program, I believe it was called iTools, but I'm sure they can send you that if that's the only roadblock). If they wanted to use ISTA then yeah, would need a lot more software
Let me know which they are going to be using or what they would need software wise. I am open to lending it out, at worst if you paypal'd me what I could replace the unit for, then I'd just refund it once it came back. If I traveled that way more I'd just bring it with me but I'm more down south
Old 09-19-2013, 06:31 AM
V-8 Driver
Remote Control...
Just thought this through a bit more... Likely they don't care what software is resident on MY computer - beyond the remote connection stuff they link you to for download and install before the session - it's the physical connection between running laptop and the car... Makes sense, but I plan to email them today after I get the new controller. I am heading to my PO Box in a few.
This is a small town, I live 700 yards from the PO, yet they don't deliver mail to houses that close... No worries, the Postmaster is cool and he even holds on to mis-delivered UPS or FedEx packages. Plus - trvia here - UPS often subcontracts out their delivery to the USPS - rural areas. smaller packages? So you get a label that shows UPS starting it and USPS getting it - to my PO Box...
I will install the new controller, default KOMBI to clear out the empty Service menu items (or is there a better way?) in the CIC, then use INPA to run a new UIF, Ident, Vehicle Info, etc. set of screens. I will send those to Vlad and ask what else he sees needing to do to get the CIC fully up - then we can focus on the FSC issues... I'll even delay the session if needed so I can have an ICOM rigged up to do it... I already noticed that with my Dension the default CIC/CID display setting have a tab for "album" but the field is not populated. There are a few settings in CIC that I may try to enable, one at a time, to see if I can get this in there. If so, I may not even need the ComBox/6FL. Especially since reading on B-R's website that 6NR - the real point of combox for us, yes? - does not work with iPhone 5... Really?
Old 09-19-2013, 09:30 AM
DIY'er
Yeah, I would think that they're going to give you something to download but just check and make sure. If the ICOM is the only thing holding this whole retrofit up we'll try to work something out that makes it cheap for you
Also, I'd love to get an idea of how they actually install the FSC code
Old 09-21-2013, 01:55 PM
DIY'er
That Schpenxel DIY is so detailed. Can't wait to see his Combox DIY.
Here's the details on the plug and play harness at least.. I haven't tested mine yet, but should work
http://www.bimmerfest.com/forums/sho...d.php?t=723325
Old 09-22-2013, 06:02 AM
Mein Auto: E60
I can program your CIC and load necessary software/bits if you ever got stuck just PM me. You will need to ship it to me. We can work on your CIC together via a video conference call. BTW, I used to live in Louisville until 2 weeks ago.
Old 09-22-2013, 07:20 AM
DIY'er
Could you help me update software on mine to new enough to use combox?
Old 09-24-2013, 03:02 PM
V-8 Driver
See Schpenxel's post, page 9 for my description of how Vlad at BimmerRetrofit got me sorted - even loaded FSC's in using my USB cable remotely...
Old 09-26-2013, 10:33 AM
V-8 Driver
Finally got a Controller to Work
I put up more details in that other thread, but I wanted those searching under the 6ers forum to see this part also. Here is my first attempt to fit a 2-D object (the 999 cover that everyone uses) into a 3-D hole. You can see the relative widths of my OEM vs. the new. Even worse, the OEM is widest at a different point than the new. For now I cut some edges off of my OEM switch cover and slid them in to fill in the air gaps in my console. Not perfect, but it is secure and works great. I came up with a range of other plastic parts (from a 5er and I think a base from a 3 series - was snapped on my latest controller) thinking that I may be able to shape something that looks tidier. The custom car stereo crowd loves this step of the process and I have done some nice installs myself...
The 6er begs for a top-notch "sano" install and some folks cut more out of their console to allow the entire cover to rest down in the opening with uniform trimming around that. Then they have the console recovered - black leather...
For me, I wanted to try (for this first fitting anyway) to get the switch plate to flush mount. Perhaps if I heated it up, it might bend enough to take up some more contour? Too bad we don't have a choice that provides a wider band around the edges.
Old 09-26-2013, 10:40 AM
V-8 Driver
Apparently, I only get to attach one photo per reply, so here is a shot of several variants besdies the ...999 switch cover that we typically use for our 6ers... Maybe I can make it a bit smoother without any more console cutting - or new leather... Of course, I don't have extended leather, so this could be a good excuse to go that route...and maybe some Chateau Red Leather accents...!
Old 11-24-2014, 06:38 AM
V-8 Driver
Just over a year later...
Two weeks ago I started to do the icom and WinKFP flash update routine. I got it all working until my Module 63 coding failed on first try, went through all the screens, waited, etc... Then it was stuck in program mode - 62 does that although I had not yet gotten to the part where I flashed 62 or AO. My icom works fine. While I thought I had sufficent power to the car from a charger, I think the lesson here is that voltage cannot be allowed to start dropping and a robust garage battery charger is not sufficent - find a good 30Amp unit like the pros use. That probably was my issue, resulting in the car failing to accept the 63 flash even though all screens came and went as others have described. Anyway, I sucked it up and shipped the head unit to Quebec, CA and the B-R folks finished what I started. It should be here today via DHL. Left their bench last Friday, out for delivery today? Thats fast!
While folks complain about businesses making money on this stuff, I think they treated me fairly. When doing the flash upgade they will not stop at Datens 41. Instead, they insist on flash upgrades only to the latest datens, 53 I think. While going past 42 requires an FSC to activate 6NR, they did the upgrade and coding of my HU for $250 CA and the FSC and activation part for another $100 CA. Recall that they got my initial FSC's for nav, etc. loaded into my unit while doing a remote coding session with me last year. Obviously, an emulator is still needed.
I look forward to final steps. I did the USB updates to CIC and Media last year. May want to run those again, - connect thumb drive to USB port in glovebox for firmware (not module) updates only.
cic, combox, hd radio, ihka, parts, retrofit, vent control module
